Question about HP Compaq nc6000 Notebook
Screen is complete blackout when I turn on my hp compaq c6000
When I turn on my hp compaq nc6000 laptop, the screen doesnt show, as in total monitor blackout, no flickers, only black out screen.
  • 2 more comments
  • Anonymous Dec 31, 2008
    I have the same problem.
    the battery to 0%.
    but I charge him.
    how do I fix it?
    by Jeremy, Netherlands
  • eagle338
    eagle338 May 11, 2010
    ok.. Do you hear it starting up? I mean the windows start up sounds.
  • Nicolas
    Nicolas May 11, 2010
    If you hear that the laptops starts, try to connect a separate screen to it and see if that screen goes on.
  • Anonymous Mar 28, 2014
    computer comes on but monitor does not comes on
You either have a screen that has gone and needs to be replaced or a cheaper fix and usually a more likely one is that the inverter in the screen has gone out. The inverter is quite cheap, around $34.00. Try it
Posted on Dec 04, 2008
Maybe it motherboard should be replaced.
the monitor is not the problem. because sometimes he starts to
Posted on Dec 31, 2008
  • holoworld
    holoworld Dec 31, 2008
    maybe it motherboard should be replaced.
The LCD screen intermittantly flashes
It could be the on/off switch that turns on/off the monitor when you open and close the lid. If the hinges are lose, damaged due to a drop, jar or have dust, dirt, etc. it will get stuck. If you have canned air clean around the hinges. Also there is a ribbon cable behind the monitor and a backlight at the bottom of the monitor. This video will give you the idea: http://www.youtube.com/watch?v=2Yi6GNFcP3w
Dec 15, 2012 | HP Compaq nc6000 Notebook
What the solution of laptop hp compaq nc6000 when turn on won't start up
Hit escape as you turn on the pc. Continue hitting the button until the startup screen shows. Also Try Hitting Contol alt delete all at once and hold down until startup screen shows. Be sure you have absolutley no usb ports being used during startup
Nov 13, 2012 | HP Compaq nc6000 Notebook
My laptop had virus, i then formated it and it function fine but one day when i boot the laptop(HP Compaq nc6000) vertical lines(combination of blue, yellow and green) displays on the monitor and since...
That is what I like to call hardware failure... Your monitor is broke...
If under warranty:800-474-6836
If not under warranty:
http://www.laptopscreen.com/English/model/HP-Compaq/HP~COMPAQ~NC6000/
Tutorial on how to repair it:
http://www.laptopscreen.com/index.php?section=products&brand=HP-Compaq&series=HP%20COMPAQ
May 09, 2011 | HP Compaq nc6000 Notebook
Laptop powers on but display does not power...
Hook a external monitor to the video output on the back of the laptop, if the monitor works! there is an issue with the computer display. The inverter board is bad, or the back light behind the LCD screen. If both displays show black, it is the Video Graphics Board that is part of the motherboard.
Jan 13, 2011 | HP Compaq nc6000 Notebook
My hp laptop has power but its screen was totally blackout
the fault might be from the screen flex or screen inverter.
To confirm this, connect your hp laptop to an external monitor and if there is a display, then the screen inverter or flex is the cause of the problem and it needs to be replaced for there to be a display on your hp laptop screen again.
But if there is no display when you connect the hp laptop to an external monitor, please let me know.
Take care.
Jul 04, 2010 | Computers & Internet
Starting problem
Starting problem Answer hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan... (More) hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan starting up with one glowing orange light next to a lightning bolt like symbol. IWhen I turn ON my laptop first time HP Compaq nc6000, sometimes the orange LED will just light up and nothing happens, sometimes when I get lucky I will be able to goto Windows. when start work properly.
Jan 31, 2010 | HP Compaq nc6000 Notebook
I can't get wifi on my HP Compaq nc6000
Typically, this means your wifi card is toast, however there are a few things we can try first. Is the light turning on to show that you Wifi connection is on? If it isnt, then make sure whatever switch or knob is set correctly. If this doesnt work then you can reinstall the drivers, but since it isn't even showing up then I doubt this will work. Even if the drivers are not installed, usually windows will at least see there is something there.
Jul 16, 2009 | HP Compaq nc6000 Notebook
My monitor doesnt show anything on the screen
This could be due to bad solder connections, or it could be that parts have failed. In either case, there's nothing that you'll be able to do to fix this yourself unless you have some electronic soldering and TV service skills. LCD monitors have become so cheap today that it is completely ridiculous to pay a shop to repair the monitor (if you can find one that will even try). Just replace it.
Apr 08, 2009 | HP Compaq FS7600 17" CRT Monitor
Screen will not power on
try pluggin an external monitor to the laptop. If you see the screen then your filament ribbon might need repair or replace.
May 06, 2008 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
1,021 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
