Question about Hotpoint Aquarius WMA52 Front Load Washer
I am trying to fit a new drum belt on a hotpoint aquarius vtdoo reverse action
  • Hotpoint Master
  • 3,463 Answers
You need to remove the top cover, remove the right hand side panel,ease the drum forward and fit the new belt.
It is very difficult to fit the new belt without the proper tool avialable from Hotpoint.
It can be done without the tool, but be prepared to stuggle
Posted on Dec 04, 2008
Hotpoint aquarius ctd00 condensor dryer drum not turning in reverse direction, belt seems to be ok
The reversing tumble action is controllerd by the timer, so it could be contacts in timer.
It is useable running in one direction.
Check for loose or broken wires to motor as well.
Hope this is off some help to you.
Dec 07, 2009 | Hotpoint Dryers
Fitting new belt
Remove top cover and lower rear panel of washer
With some help, tilt washer forward, and fit belt round motor pulley first,slowly ease belt onto drum pulley and feed slowly round, turning pulley at same time, it will be very tight, so watch your fingers, you can align the belt after it is fitted. Please rate my solution.
Thanks.
Aug 19, 2009 | Washing Machines
Hotpoint Aquarius WMA32 - belt slipping off?
Probably it wasn't fitted properly. make sure the belt is tight when fitted, and at least 2 groves from either side at the motor shaft.
Jul 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Fitting a new drive belt to a hotpoint aquarius
Remove lower rear panel, tilt washer forward, getting someone to help, and fit belt round motor pulley, then fit belt round drum pulley, slowly turning the drum pulley round as you feed the belt on, it is very tight, and you might think the belt is to small, but this is normal, as the belt stretches, just persist, but be careful you do not trap your fingers. Good luck.
TRhanks.
May 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Belt on a hotpoint wf250
open it up, see wat thensions the belt, loosen that up and fit new belt. retension
Apr 19, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Drum not turning
no brushes in those motors you need new one or different dryer
Mar 11, 2009 | Hotpoint Dryers
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Belt replacement
belt is a streach fit
put belt onto motor pully first then feed belt round drum pully
Aug 16, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Belt has come off
I have fitted a replacement belts on a few older machines (Hotpoint WMA series). The procedure is likely to be very similar on yours.
Check your belt for wear - if it fits really easily it may already be stretched and will come off again quickly. A replacement is less than £20.
1/ Turn off power and disconnect.
2/ Check you have Turned off power and disconnect.!
3/ You best course of action is to open the lid. You will need tools. Torx set etc. Look for little finger nail size plastic covers over torx heads on the sides. Remove lid (push back and lift).
Once opened you will see large drive wheel connected to the back of the drum and the drive motor is at the bottom. Use a torch if its dark!. You will need to ensure the belt is fixed around both of these. This is not easy to do. And try not to pinch your fingers.
It may help to remove the concrete block on top of the drum to give you more room. Use large spanner. (You must remember exactly how this is fitted to refit)
4/ Dangle the belt around the motor spindle and lightly pull it to stop it sliding off. Next pull the belt round one side of the drum wheel. Gently rotate the drum until the belt is looped round the drum wheel and the drive motor at the same time. Sounds easy? it's not.
Regards
Nov 17, 2007 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint Aquarius WMA52 Front Load Washer Logo
340 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
