Question about Microsoft Windows XP Home Edition
Cant install because i dont seam to have a working windows instal
My windows install dose not work, I cant find a good patch that dose not cost me a lot of monney. I cant seam to find my windows disk to try and do a Fix Install. can you help me
    Novelist:
  • 159 Answers
Microsoft can replace your CD/DVD for what I believe will be a relatively small amount of money:
http://support.microsoft.com/kb/326246
However, some computers cut deals with Microsoft so Windows cannot be reinstalled -- it can only be "restored" so your hard drive resembles the way it came out of the factory ... which wipes out everything else on your hard drive. My Acer laptop is like that, and there's not much you can do about it except back up your important files to another drive or DVDs, then restore the hard drive, then reinstall all your programs and copy over your data files like music and documents.
Posted on Dec 05, 2008
Why cant i play zoo tycoon 2?
Method 1.
Let us first download and install the patch for this game and then try playing and check if it works.
Here is the link to download the patch.
http://zootycoon.com/Downloads/patches.htm
Method 2.
If you are unable to play the game or install the patch perform the below steps.
a. Click start and type msconfig in search bar and press enter.
b. Select boot.
c. Go to Advanced options.
d. Place a checkmark on Check maximum memory and increase it to the maximum.
e. click ok and the apply and ok again.
Method 3.
Try playing the game in clean boot state and check if it works.
Refer to the article below for steps about how to start your computer in clean boot state.
How to troubleshoot a problem by performing a clean boot in Windows Vista or in Windows 7
http://support.microsoft.com/kb/929135
Note: When the troubleshooting is over do not forget to reset the computer to normal startup. Follow the step 7 in the above article.
Hope this helps.
May 15, 2012 | Microsoft Zoo Tycoon 2: Zookeeper...
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
How to solve ploblem it's error number 0xe0000227 realtek
here goes amed
There is really only 1 way to install the Realtek HD Audio drivers properly. No matter what all other forums say. Service Pack 3 is the main culprit as the drivers see that its above SP2 and dont install. I personally face this situation and was really distressed because it looked like either i will have to reinstall Windows Xp or have my new supercool and super monster computer without sound. Imagine having a monster PC with a motherboard with HD Audio and your driver doesnt install.
Both scenarios were something which i would never have approved of. Anyway so i Googled. I got 10s of solutions but most didnt work. Only 1 worked and i will put it here hoping that Google dear will catch it and people who face this problem installing the Realtek HD Audio 0xE000027.
  1. First Step is to make sure all instances Realtek Audio and its associative softwares are uninstalled from add remove programs and device manager. This includes Intel High Definition audio.
  2. On your PC change the CSDVersion registry key to Windows XP SP2:
    HKLM\SYSTEM\CurrentControlSet\Control\Windows\CSDVersion value=200
This problem arises as the patch thinks that SP3 includes a better version of the patch itself and hence doesn’t install itself.
3. Download the latest drivers from the Intel website, navigate to the KB888111 patch.
4. But before installing the patch, goto your device manager and disable the UAA. Now uninstall the UAA.
5. Install your patch now.
6. Install the Realtek drivers now and things should work.
7. Change the SP version to 300 again.
If it didnt work, try once again. Hopefully Error 0xE000027 is fixed now.
Jun 05, 2010 | Microsoft Windows XP Professional With...
I cant install the Patches for gangland
it's long time since the last post here, anyway I have a problem with this game's patch,
I want to install latest patch which is 1.4
it's said for installing that, these versions are needed :
1.0.2 , 1.0.3 , 1.1.0 , 1.2.1 , 1.2.2 , 1.3.0
I have downloaded and installed 1.1 and 1.2.1
but couldn't install 1.3
seems 1.2.2 is needed, but couldn't find it anywhere, can anyone
May 28, 2010 | Whiptail Interactive Gangland for Windows
Heat pump makes a lot of noise at start-up a slow start kit dident help, and a compressor blanket helped some..this is a new unit..where is the quiet and so on the sales paper said it would or the no...
IS, UNIT NEAR WINDOW I ALWAYS POSITION THEM AWAY FROM LIVING SPACES. THE PROPER LOCATION IS JUST AS IMPORTANT AS INSTALLATION SOME THINGS INSTALLERS DONT PAY MUCH ATTENTION TO WITH TODAYS SCROLL- SCREW COMPRESSORS NOISE CAN BE A PROBLEM A GOOD INSTALLER WOULD TAKE CARE OF THIS AT NO COST TO HOMEOWNER, THE CHEAPEST PRICE ISNT ALWAYS THE BEST CHOICE.
Feb 03, 2010 | Heating & Cooling
Black screen !!!!!!!!!!!!!!!!!!!( with age of empires 3 )
Use Uniblue Driver 2009 Cracked form loadevery.com
Please Vote 4 ME
Sep 24, 2009 | Microsoft Age of Empires III: The Asian...
I cant connect my samsung tocca light with my pc via usb cable.it says cannot find windows sofware.just installed pc studio
ya for that you require an patch to your windows when you get that just say search in net option and download the patch then it would work
Jul 27, 2009 | Computers & Internet
When installing new patch, it gives me a patch error
sounds like your being blocked by your anti virus or ... do you have windows vista? If so right click on the icon and run as admin
if its anti virus go here
http://www.topazcandy.com/tech-candy/2009/4/30/firewalls-world-of-warcraft-and-you-part-1-norton-security.html
Mar 23, 2009 | Blizzard Entertainment Warcraft 3: Frozen...
Hp officejet 5610v all in one insallation software for windows vista
Try this link. It is the full intall file for the all in one being run on a Vista Machine. It worked fine for my installation.
Muck around on the site for a bit, and you can also find the same install file for Windows XP.
Good Luck
http://hp.driversdown.com/hp-drivers-download/HP-Officejet-5605-5610-5610v-5610xi-All-in-One-Driver-080.001.237.000-for-Windows--Vista-(32-64)_9168.shtml
Jul 22, 2008 | HP OfficeJet t45 All-In-One InkJet Printer
Microsoft Windows XP Home Edition Logo
49 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
