Question about HP xw6600 Workstation with 650W 80 PLUS Energy Efficient Chassis w/ LP2465 24-inch Flat Panel Moni... PC Desktop
Boot Sequence How Can i change boot sequence in HP Proliant ML 330 Server
    Problem Solver:
  • 5 Answers
F5 or f6 keys
Posted on Dec 06, 2008
Cd start server primergy b210 fujitsu siemens
In order to change the boot drive you have to change the boot settings in BIOS, or sometimes you can get a separate boot menu which allows you to change this setting on a one-off basis. During the boot sequence you need to press the "F12" button during the POST testing to bring up the boot menu if one is available, otherwise you need to press the "Del" or "F2" button during the POST process to bring up the Bios screens. Navigate to the BOOT option and alter the boot sequence, save the settings, exit BIOS and reboot.
Feb 18, 2014 | HP Compaq ProLiant ML110 G4 Server
Boot failed
Is the optical drive a DVD drive?
Have you set the machine to boot from the optical drive?
Frequently the HP boot sequence is accessed by touching the Escape key on boot.
Dec 12, 2013 | HP ProLiant DL120 G6 Rack Server System...
How to boot from CD hp proliant ML 110 G6 sever
Check BIOS for boot sequence. CD-ROM / DVD should be 1st.
Jul 20, 2012 | HP ProLiant ML110 Server
HI. I RECENTLY got a hp proLIANT ML 330 G3 server. It did not come with any OS.. IT had only cd drive.. so i burned SERVER 2003 IN usb and i want to server to boot from usb.. when even i switched it on it...
I am sorry to advise you I have had the exact same issue with a ML330 G3, and it doesnt support USB boot , There are 2 work arounds, 1 is to burn 2003 to a CD as opposed to a DVD and then boot from the standard drive, the other option is to swap out the internal IDE CD Drive to a IDE DVD drive, these are pretty cheap to purchase and easy to fit, the key to fitting is that the ribbon that fits in the back of the drive has a stripe down one side, The side with the Stripe always plugs in nearest to the Power plug that you also plug into the drive.
If this helps, please can you provide positive feedback
Regards
Andy
May 21, 2011 | Computers & Internet
How to enter in bios to boot change sequence in ProLiant ML 530
Press F10 during post boot if you have smartstart installed in the partition. If not, you need to boot from SmartStart CD.
May 08, 2010 | HP Compaq ProLiant ML530 Server
HP ML 110 G2 will not boot from CD. How do I fix
Try updating the firmware and BIOS for the server. Most likely you have a drive that simply isn't recognized by the revision level you are currently running. If that doesn't work, try swapping another drive in to see if it fixes the problem.
Jun 24, 2009 | HP ProLiant ML110 Server
Harddrive array sequence causing system in booting
If the only drive you changed was the drive that failed and all the others are in the correct sequence, then that's a good thing.
The next question is, did you have this system setup in a RAID Array and if so, what RAID configuration were you using (RAID 0,1,5, etc.)? Some RAID configurations allow you to replace a failed drive and not lose data, but I will need to know more about how you set the system up in order to help you more.
Jun 18, 2009 | HP ProLiant ML370 G4 Server
I need driver hp proliant to install
If you are installing an OS from scratch, download the Proliant SmartStart CD for your server from HP. You simply boot from this CD and follow the instuctions to load your OS. Smartstart will configure your drives, pre-load drivers, and gracefully pass control over to the OS installer.
Jun 09, 2009 | HP ProLiant ML110 Server
How can i change boot sequence in HP proliant ML330 Server
  1. Power on the workstation, and press the F10 key during the initial boot process to enter the Computer Setup (F10) Utility.
  2. Select your language from the list, and press the Enter key. In the Computer Setup Utilities menu, four headings are displayed: File, Storage, Security , and Advanced . Other headings might be displayed, depending on the workstation.
  3. Use the right arrow key to select Storage .
  4. Use the down arrow key to select Boot Order , and press Enter .
  5. By using + and - key you can chang the sequence
  6. To apply and save changes, press the F10 key, and select File>Save Changes and Exit .
  7. Restart your system
Dec 04, 2008 | HP xw6600 Workstation with 650W 80 PLUS...
Scassy Card for Compaq Proliant ML 330 is defective
I have allredy missing scassy card for Compaq Proliant ML330
what can i setup my server
Feb 05, 2008 | HP Compaq ProLiant ML330e Server
HP xw6600 Workstation with 650W 80 PLUS Energy Efficient Chassis w/ LP2465 24-inch Flat Panel Moni... PC Desktop Logo
108 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
