When using HDMI input from Blue Ray DVD Player DMP-BD-35 I see black bars at the top and bottom of the TV screen 9JVC LT-37DS6BJ) despite changing the aspect ratio of the DVD player
  • RalphPip Dec 04, 2008
    Thanks Gerry
    I'll try changing the aspect ratio on the TV. If that doesn't work I need to change the resolution from the Player - right ?
    (I've tried the latter on it's own - it didn't help)
    Genius:
  • Televison & ... Master
  • 1,673 Answers
The aspect ratio is higher from the player that what the TV can take in the resolution level that you are set up in. This is normal with some HD TV sets.
I have see this type of thing with some models of HDTV sets, and with low end Extended Defination TV sets.
Jerry G.
Posted on Dec 04, 2008
Why is there no power to DVD box?
Check your power cord and plug for damage, do a wiggle test with DVD plugged in and see if it comes on while moving and bending wire plug. press the helpful button
DVD power supply repair tips
Press Release Consumer Electronics Video Audio Camera TV
DVD Player Repair Guide Covers Every Detail
Jan 26, 2016 | Televison & Video
Blue ray disc player suddenly will not play blue ray disc?
If you can't get a menu picture from blu ray, check output jacks going from player to tv. if you a picture from blu ray menu, then you may need to clean the lazer eye in blu ray player.
Aug 03, 2015 | Panasonic DMP-BDT300 DVD Player
Why won't my blue-ray player DMP-BD87 play blue-ray disc's any more?
Because Blue-Ray isn't what it's cracked up to be. In fact no TV studio will even consider using one.
Mar 07, 2015 | Panasonic DMP-BD871 Smart Network Blu-ray...
How can I change the language on a sam-sung blu-ray player?
How To Reset Your Blu-ray Player To Factory Defaults (BD-C & BD-D Models)
Page 1
Page 1. Reset Your Blu-ray
  1. Power on your Blu-ray player and tune your TV to the input where the Blu-ray player is connected. For example, if the Blu-ray player is connected to HDMI 1 press the TV input/source/line button to tune your TV to HDMI 1.
  1. Remove any disc from the player and then press and hold the Stop button on the front of the player, not the remote, for about 8 seconds or until the front display reads 'SETUP'. 'Resetting all settings to default values...' is displayed on your TV screen as the Blu-ray player powers off and resets.
    1. The Blu-ray player is automatically powered on after the reset and the select Language screen is displayed.
Aug 16, 2014 | Samsung Televison & Video
Can i connect dmp-bd871 to a home theater system
It will depend on your home theater system and TV. If your system accepts HDMI in from other devices and HDMI out to the TV, connect an HDMI cable from the blue-ray player to an HDMI input on home theater system. Then connect another HDMI cable between the home theater system and the TV. This will provide the best video and audio experience.
Another option is connect the HDMI cable from the Blue-ray player to the TV. Connect the audio output of the TV to the home theater system. (This will depend on the TV as well as the home theater system. Some TVs have digital audio outputs; others have analog outputs. If your home theater system doesn't have the same input as the TV's output, you would need a converter as well as the digital and analog audio cables. This is an example of one for digital to analog: http://www.gefen.com/kvm/dproduct.jsp?prod_id=4907 .)
If you do not want to get the best picture from the Blue-ray player and your home theater system has analog audio inputs, you can connect the composite video out to the TV. Then connect the audio outputs from the player to your home theater system. (This means only an SD picture will be provided to your TV.)
Panasonic has the manual for the DMP-BD871 here: service.us.panasonic.com/OPERMANPDF/DMPBD871-MUL.PDF .
I hope this helps. Please add a comment with the other devices in your entertainment system or their inputs/outputs. Then I can add specific information for your system and any tips for setting up the system.
Nov 26, 2012 | Panasonic DMP-BD871 Blu-ray Player with...
Can I hook my cable box into my Sharp Blu ray player
Curious why you would want to do this since both cable box and BluRay generate output signals. I doubt a single line pass-through would work since the last device on the link would override the signal with its own content when turned on.
If your TV or media system accepts multiple inputs, I would route each device to a separate input on the TV/MS and switch between them with a remote. I run HDMI lines out from both my cable box and BluRay box directly into the TV as two different lines and it works fine.
Jun 29, 2012 | Panasonic DMP-BD77 Blu-ray Disc Player -...
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
When connecting my Blue Ray DVD Player (Panasonic DMP-BD35) to my JVC TV (LT-37DS6BJ) I get large black bars at the top & bottom of the screen despite changing the aspect ratio on the DVD. The TV...
It all depends on the dvd that you are watching you cant change it to anything bigger than what is was recorded.
You will have to just watch it like it is. I have the same thing with my dvd player its really thin picture its annoying
Dec 04, 2008 | JVC Televison & Video
Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
Jul 22, 2008 | Samsung BD-P1400 Blu-Ray Player
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Electro Med Services...
