Question about HP iPAQ RX3715 Pocket PC
Problem with passing the allign screen test
Hi! I have a hp iPAQ rx3715 and I can`t pass the allign scren test. I push the target, but it stops moving after two moves. I made a hard reset, but it didn`t worked. In fact, somebody told me the pda was in a very cold room for a while, and when it was turned on, a message "too cold" or something like that appeared on the screen. Who knows what problem it is? I really want to fix it!
    Novelist:
  • 198 Answers
Salut, daca esti din Romania, inscrie-te te rog pe www.phpbbplanet.com/matzahajuta.. e un forum specializat in genul asta de probleme. Vei primi un rezolvare in aceasi zi. PDA-ul tau se poate repara. PS. eu administrez forumul ala, dar prefer ca acele informatii sa ne fie accesibile si noua romanilor pana sa ajungem pana pe site-urile de afara.
Posted on Feb 07, 2007
  • 1 more comment
  • felix timar
    felix timar Mar 25, 2014
    Salut. Multumesc,dar nu prea am optiuni sa ma inscriu pe pagina oferita de tine......Intra o pagina cu titlul. Free forum hosting by phpbbplanet.com. Dar mai departe pauza...poate ma ajuti si cu asta.:)
  • felix timar
    oare e scris corect acest link ?
  • felix timar
    felix timar Mar 27, 2014
    Salut. Te rog ajuta-ma cu acest site .nu o gasesc deloc.Imi apare doar pagina oficiala www.phpbbplanet.com.nici urma de forum.
Manual for RX3715 I paq
Hi,here is the link that you can download the manual..
Take care and thanks in advance for rating me.
HP iPAQ rx3715 PDA
Supplementary Guide for HP rx3000 / rx3100 / rx3400 / rx3700 / rx3715 http://h20000.www2.hp.com/...Fc00264003.pdf
http://www.retrevo.com/support/HP-rx3715-PDAs-and-Handhelds-manual/id/393ag912/t/2/
Oct 22, 2010 | Computers & Internet
My Ipaq rx3715 won't charge. "AC only"
its obsolete now, why use this thing?
wait for battery? then post?
or go to HP and ask them,
we are not HP, this is chat bs boxes here.
ever heard of HP? this is the official HP forum, try it?
If HP cant help you who can,
learn this ,when compelled to mess with obsolete products
buy 2 of them for like $3 on fleabay (most are in the trash now)
then mix and match parts, all day.
its obsolete, so doing tests on it lacking full spares is impossible.
why not buy a $3 used smart phone from same place,
https://h30434.www3.hp.com/
Aug 04, 2017 | HP iPAQ RX3715 Pocket PC
Touchscreen problems (HP RX or HX series)
If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3715 (or RX3115) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Best regards,
May 25, 2009 | HP iPAQ HX2110 Pocket PC
Ipaq 3715 tapping problem
have you downloaded any viruses? if not try another hard reset is the screen cracked?
Jan 07, 2009 | HP iPAQ RX3715 Pocket PC
Pass the align screen
Hey :), id be happy to help. You see, I too have a Ipaq except I had Ipaq 4350. Now, I too had the same problem you are having. The reason why you can't pass the align screen step is because somehow you have damaged your screen. And I have come to the conclusion that HP Ipaq's screen is extremely sensitive, ( because I never did anything that bad to my screen for it to be damaged) soo I'd recommend for you to call HP and see if they can repair your problem or give you another one. Thank you and I hope this helps!
Sep 03, 2008 | HP iPAQ H2210 Pocket PC
Passing allign screen test
I am not an expert on this. But I just had a problem similar to this as the unit kept reporting a FAIL on the screen calibration test. So this is what I did and after I did this, the screen calibration passed.
I went back to the screen alignment tool and performed a screen alignment with the stylus and this solved my issue. I then checked the self test aand it passed. This may not workfor you, but you can try it. Also you might want to check to see if you have any third party programs that are affecting this. The only way, you'll know is to remove those third party programs, one by one and repeat the self test to see if this corrects the problem. Good Luck
Aug 04, 2008 | HP iPAQ RX3715 Pocket PC
Helo i have a problem
The dreaded "allign screen problem" strikes again. This is a known bug of these rx ipaqs. You should simply try to see if the ipaq passes this stage if you try to allign the screen a few times. If not, try a firmware update/rom update (from the hp site) If this woun't work then the problem is located on the motherboard,where a small chip called the touchscreen I/O controller has failed. This isn't fixable by replacing the screen, only the whole motherboard. Unfortunately most of the first generation rx 3715 units (first revisions) carried this problem just waiting to happen.
Please ask more details if you need to better understand any of these methods above.
Jul 11, 2008 | HP iPAQ RX3715 Pocket PC
Bogdan, could you give me a solution to contact you about this PDA? Give me your email adress or your cell phone number (mine are tiby_olimp@yahoo.fr and 0746761410)
Jun 09, 2007 | HP iPAQ RX3715 Pocket PC
Ipaq RX 3115 Stops at align Screen
solia, I'm sorry, I didn't mean to close the chat session on you.
Is your unit still under warranty? If so, check with the manufacturer.
They can help.
Mike
Sep 27, 2006 | HP iPAQ RX3115 Pocket PC
IPaq rx3715 locked up
try leaving battery out overnight.
Sep 07, 2005 | HP iPAQ RX3715 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
134 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
