SOURCE: U-line 15" wine cooler not cooling, but light is on.
If the light is on and no fan or compressor is running then its your thermostat that is bad. Thats the only thing that turns on those parts.
SOURCE: Wine cooler not running. When thermostat was
You have either a week connection or a bad thermostat. Check your connections. Part # 2767-s
SOURCE: Wine cooler #ULN-75BWC-00 motor seems to have shut
the motor could be defective or it could be low o refrigerant causing the pressure switch to not kick on the fan. Could even be wires have come loose from the fan. If the fan does not work it won't cool. however it mould most likely cosy you more to fix if you take it to a shop to have it repaired if you have the tools to test it with I can help you so let me know if you have a test meter volt ohm meter and I can tell you how to test the system.
SOURCE: I need to replace the
To replace thermostat inside of the cooler back panel needs to be removed.That gives you more room, to remove the thermostat. You have 2 screws on the bottom of the evaporator that holds the thermostat sensor in place. Then the thermostat sensor runs thru the bottom toward the back.As you remove the old one jus put the new one in the same way.The thermostat should be clamped onto the bottom of evaporator plate. --------- this will help.thanks.Helpmech.
After installing the new thermostat I opened up the back again and noticed the fan was not working, which likely caused the unit to shut off after a while. I removed the fan, took it apart and cleaned it, reinstalled it and the wine cooler is now working perfectly.
