Question about Philips HD-5702
NO HACE CAFE LA CAFETERA NODELO HD 5702 PHILIPS
EL PROBLEME ES QUE NO ME DI CUENTA QUE ESTABA VACIO EL DEPOSITO DEL AGUA Y AHORA AL LLENARLO NO ME SALE EL CAFE -QUE TENGO QUE HACER?
4 Suggested Answers
ThaMp3Doctor
  • 8596 Answers
SOURCE: I have a terrific problem / Tengo un terrible problema
Run a repair in Philips Device Manager
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
reverendrave
  • 24 Answers
SOURCE: en la pantalla desplega el mensaje "maquina en descalcificacion"
Hola Ostras,
Que estoy traduciendo esto a través de Google así que pido disculpas si no es correcto
Hay una serie de razones por las que la máquina no está funcionando. Podría ser un disco selector de detrás de la perilla de control o de una pizarra electrónica malo. La mejor sugerencia que tengo es ponerse en contacto con Miele servicios técnicos y que pueden solucionar con usted por teléfono
Posted on Sep 16, 2009
  • 13 Answers
SOURCE: tengo una saeco vienna superautomatica,
hola :)
Try changing the seal under the water tank: NM05.006
(Intente cambiar el sello en el tanque de agua)
Posted on Apr 22, 2011
Cafetera Krups XP7230 bota agua por debajo
The problem lies with one of the hoses taking water to and from the heating element - hoses either have a crack in it or one of the two connections is no longer water tight.
Feb 12, 2016 | Cars & Trucks
Mi suzuki aereo tira agua de la manguera superior por la union de la abrasadera y el radiador,es como si no pasara el agua y se incha mucho la manguera, ya le cambie la bomba de agua q estaba desconpuesta...
Si la manguera sufrio dilatacion por efectos de temperatura, es mejor cambiarla; efectue un purgado del sistema, para eliminar aire en el interior del sistema de enfriamiento. Verifique los niveles de refrigerante.
Apr 23, 2012 | 2003 Suzuki Aerio
Tengo una camioneta jeep grand cherokee, 97 que en la computadora me manda un mensage, coolant sensor bad y no lo e podido corregir y sale mas cuando hace mucho calor
Ese es un mensaje comun en este tipo de camionetas; tengo una '93 GC Limited 5.2L V8 y presento el mismo problema por algun tiempo.
Solamente hay dos cosas por hacer:
1. Desconecta el harness del sensor y dale una lavada con solvente dielectrico para contactos electricos. Previamente desconecta los bornes de la bateria.
2. En caso de que el procedimiento anterior no funcione, podriamos pensar que el sensor de refrigerante es el que esta da?ado, enviando una falsa se?al al VIC (Vehicle Information Center) que es el que te envia el fallo.
OJO que cuando desconectas los bornes de la bateria el ECU se resetea, con lo cual podriamos tambien probar que era un error antiguo almacenado.
Aqui hay un tema en una web Jeepera de Espa?a: http://www.jeepy4x4.com/foro/viewtopic.php?p=311758
Espero que esto te sea de ayuda; recuerda calificar esta respuesta. Suerte.
Oct 05, 2010 | 1996 Jeep Grand Cherokee
La direccion de la consola esta deshabilitado mac xbox360
Conectar xbox 360 a internet; si tienes xbox 360 y quieres jugar en internet, ve este tutorial.
Como conectarse al Live.
Bueno tienes tu nueva 360 smile.gif y ahora quieres entrar a la experiencia Xbox Live y no sabes cómo. Acá una guía que te enseñara como hacer desde las conexiones de redes (VTR por ahora) hasta la creación de tu cuenta Xbox Live/gamertag.
Las Conexiones:
Hay 4 opciones para conectar tu consola:
A: Directamente desde el MODEM de VTR.
Conecta el cable de red que sale del MODEM a la 360.
MODEM ------------ 360
1. Llama a VTR (600 600 9000 opcion 3, 3), pideles que te cambien el numero de MAC al que tiene la 360.
2. Para saber como obtener tu numero de MAC debes buscarlo en las opciones del menu de 360
3. Una vez hecho esto estás listo para entrar a Xbox Live.
B: Desde el MODEM de VTR 2 conexiones (USB y RED).
MODEM red ------------- 360
usb ------------- PC
1. Conecta el otro dispositivo que tengas (Ej. PC) y conectalo via USB.
2. Conecta la 360 por el Cable de Red.
3. Llama a VTR (600 600 9000 opcion 3,3), pide que te registren 2 MACs, la del PC y la 360. Así ambos quedarán con Internet.
4. Una vez hecho esto estás listo para entrar a Xbox Live.
C: Router
Modem ------- Router ------ 360
1. Conecta la 360 al router con un cable de red.
2. Ahora hay que configurar el Router. (Ruteo de puertos)
1. Tienes que entrar al menú de administración del router. Generalmente la dirección es 192.168.0.1, después te pedirá nombre y contraseña. Generalmente es User: admin, sin password. Si no funciona, vas a tener que conseguirtelos.
2. Una vez dentro del menú.
3. En la página eliges Forwarding.
4. Elige la marca de tu router.
5. Elige Xbox Live 360
6. Sigue las instrucciones de cómo “rutear” los puertos para la 360 (88 y 3074)
7. Una vez ruteados los puertos, estás listo. Empieza la creación de tu Gamertag.
D: Router via Wifi
Router )))))))) 360
1. Necesitas el Adaptador Wifi para la 360
2. Necesitas un router con soporte Wifi b/g
3. Prendes la 360 vas a la parte de Sistema – Config de Red – Windows Connect Now.
4. Eliges el Spot Wifi
5. Desde un PC, Ahora hay que configurar el Router (Ruteo de puertos).
5. Elige Xbox Live 360, Sigue las instrucciones
6. Una vez hecho lo anterior, estas listo para crear tu Gamertag.
XBOX LIVE
Entendiendo Xbox Live:
Primero hay 2 tipos de cuentas para Xbox Live. Gold y Silver.
SILVER
• Permite a otros jugadores saber quién eres y cómo juegas gracias al perfil de jugador único.
• Entra en el Bazar Xbox Live para conseguir fantásticas descargas (incluidos los juegos clásicos de consola de Xbox Live Arcade), demostraciones y tráilers de los juegos que van a salir próximamente.
• Prueba la acción multijugador con acceso a partidas multijugador masivas. Lo único que tienes que hacer es crearte un gamertag.
• Disfruta de la acción multijugador sin límites con las oportunidades suscripción de prueba al nivel Gold.
• Crea y mantén una lista de amigos para conectarte y comunicarte instantáneamente con familiares y amigos mediante mensajes de texto y voz.
En otras Palabras... Puedes Bajar Trailers, demos, etc. Pero NO puedes jugar Online
May 20, 2010 | Microsoft Video Game Consoles & Games
The playback voice is giving eco effect?
Tu problema es el conector de audifonos de tu mp3 sony nwz b142f , lo que tienes que hacer es abrirlo y apretar un poco las placas doradas del conector yo lo hice y ahora me funciona perfecto...
Este mp3 tiene tres tornillos, dos a la vista al sacar la tapa protectora y el otro bajo el plástico de la pantalla donde dice sony con letras grandes tienes que despegarlo con cuidado para no quebrarlo , despues de sacar los tornillos habre cuidadosamente la carcasa para no romper la trabas plásticas.
Una vez abierto evita moverlo mucho para que los cables que van a la bateria no se desconecten.
Para localizar la falla, teniendo abierto el mp3, conecta los audifonos y enciendelo, luego con alguna varilla plastica o de madera delgada(brocheta) presiona las placas doradas del conector hasta suene correctamente, sabiendo la que esta suelta, desconecta los audifonos y presionala suavemente solo un poco, ahora conecta los audifonos, y comprueba que entre sin problema al conector y que se escuchen correctamente.
Para armarlo debes sacar los botones BACK y ZAP y ponerlos cuando tengas todo listo
IMPORTANTE: antes de manipularlo debes descargar la electricidad estática que tengas en tu cuerpo tocando algun metal desnudo que tenga contacto directo con la tierra por ejemplo alguna cañeria de cobre para el agua , para evitar dañar algún componente del mp3.
Por ningun motivo manipules tu mp3 abierto sobre alguna mesa metalica o con herramientas metalicas al tenerlo encendido, si lo haces puedes producir algún cortocircuito y dejar inutilizable el mp3.
suerte.
Atte Daniel Améstica
damesticaz@gmail.com
Apr 15, 2010 | Sony Walkman NWZ-B142 MP3 Player
En la pantalla desplega el mensaje "maquina en descalcificacion"
Hola Ostras,
Sep 09, 2009 | Miele CVA615 Espresso Machine
Mi internet esta disponible a cualquiera como puedo bloquearlo necesito ponerle un candado llame a soporte tecnico y me cobran por su asistencia es ridiculo si estoy usando sus productos
No porque te compres un coche los del concesionario tienen que enseñarte a conducir...
Supongo que tienes un router WIFI, y que no hay encriptación en él. Obviamente necesitaríamos saber que modelo de router tienes y que tipo de direccionamiento IP estas usando para tu red local.
A grandes rasgos, tienes que conectarte con tu router (a menudo vas a poder entrar poniendo http://192.168.1.1 en un navegador). Quizas te pida un nombre de usuario y password para conectar. Si es asi, tendras que saber cual es. De fabrica una combinaciones validas serian:
usuario: admin password: admin (o dejar el password vacio)
usuario: root password: admin (o dejar el password vacio)
usuario: root password: root
usuario: 1234 password: 1234
usuario: 12345 password: 12345
Una vez dentro del router, tendras que buscar donde se define la encryptacion del enlace WIFI, escoger un tipo de encryptacion (por ejemplo WEP), y poner una clave.
Si has conseguido llegar hasta aqui y te estabas conectando por WIFI, en este momento se te desconectará la conexion. Ahora tienes que decirle a tu PC que utilice encriptacion para conectarse.
Tambien seria aconsejable cambiar la clave del usuario de administracion (el que has usado para entrar en el router).
Suerte.
Jun 23, 2009 | Linksys (WRT54GC) Router
NO SYSTEM ON HDD
I FIXED! LO ARREGLé!!!!... Mi objetivo era ponerlo a funcionar de cualquier forma y LO HICE!!, igual que todos, lo formateé y me comenzó a dar el error del sistema en el HDD, prácticamente tenía un DD portátil. Ahora lo tengo funcionando con el software libre “ROCKBOX” el cual tiene solamente ventajas en comparación al limitado firmware del GIGABEAT y es abrumadoramente más completo y, por ejemplo, no se necesita nada ni similar al “GIGABEAT ROOM” para cargarle música al reproductor pues es tan simple ahora como copiar y pegar (inclusive desde el WINDOWS VISTA) . Los pasos exactos no los podría decir pues fue puro ensayo y error pero es simple, deben buscar el “ROCKBOX” para GIGABEAT serie F en la misma página de ellos (totalmente gratuito) y también buscar la carpeta “GBSYSTEM” pero en Internet, desgraciadamente no puedo dar la dirección exacta pues no la guardé pero no tardé mucho y OJO, no sirve la carpeta “GBSYSTEM” que viene con el cd del reproductor, esa está vacía o con unos archivos ocultos, la que se baja de la red trae al menos dos archivos del tipo “FWIMG” (es más, estoy casi seguro que en la página de “ROCKBOX” explican como conseguirlo de forma simple), la pegan en el reproductor conectándolo como USB. Teniendo todo ello listo, van instalándolo según las indicaciones del PDF que está en la página de “ROCKBOX”… Mucha suerte!!!! Y apreciaría que me contaran si tuvieron el mismo éxito que yo a josedanielcr@gmail.com.
Oct 04, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
Problemas con el sistema de enfriamiento
Hola, mi recomendacion es antes que nada reemplazar el termostato para iniciar bajo control. el thermostat de mas Baja temp para zonas calidas. Despues de esto asegurar el termostato funciona y abre al llegar a los 90 grados o mitas de ahuja debe de verse circulacion en deposito de agua. En estos vehiculos es importante purgar el sistema por medio de un valvula /tubo loicalizada frente a motor. se afloja y sale aire. cerrar cuando ya no salga aire/vapor. Despues de esto se podran tomar mejores conclusions. Recomendacion nunca quitar termostato permanentemente ya que es necesario en tiempo de invierno/frio para calendar vehuiculo adecuadamente. FIN
Sep 26, 2017 | 1989 Pontiac Sunbird
Philips HD-5702 Logo
123 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
