Question about Canon Office Equipment & Supplies
Hi, I'm trying to set up MP620 printer for wireless operation.Stuck at the access part."access point not detected" also how do I find out what the network key is?
I have the same problem on my new Canon printer - what is the solution?
Posted on Oct 23, 2010
Canon MP620 cannot detect a memory card or USB flash drive for saving
Canon MP620 problem, not showing up at all - Windows 7 Help Forums
www.sevenforums.com > ... > Hardware & Devices
Apr 29, 2012 - He's got a Canon PIXMA MP620 and we're trying to get it to connect to his Windows 7 laptop. ... Basically, I started off with no trace of Canon in the laptop.Then, using the setup disc, I followed all the instructions up to actually connecting the printer to the laptop. Problem with wireless Canon MP620 printer connection Solved ...
Jan 26, 2013
Problems installing Canon MG6220 Wireless Printer in Win 7 x64 ...
Aug 28, 2012
Cannon PIXMA MX870
Feb 14, 2011
cannon mp620 printer
Mar 28, 2010
More results from www.sevenforums.com
Nov 04, 2015 | Canon PIXMA MP620 All-In-One InkJet...
Can't turn on wireless
Have you checked whether your wireless access point/router is working. For example does your smartphone detect your wifi signal. If not turn off off your access point/router, wait 30 seconds and then switch back on.
Also in the bottom right of your toolbar you will be able to bring up an option to connect to the wi fi - did you set this to automatic?
Dec 29, 2012 | Computers & Internet
Got a new router and now can't use my canon mp620 wirelessly.
IT sounds like to need to reset up your printer for the new router:
Gather the following information from your router: • Access Point Name/Network Name: Also referred to as SSID. A name to identify the specific access point. • Network Key: Also referred to as encryption key, WEP key or WPA/WPA2 passphrase, Pre-Shared key if you used one
use the buttons of the front of the printer near your display to select Settings, then press the OK button
Select Device settings, then press the OK button
Select LAN settings, then press the OK button. Select Wireless LAN settings and update with the new information you collected earlier.
Hope this helps
Apr 20, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Printer is not responding. Canon Mp 620. wireless. no problem with laptops or wireless network
This might happen if you recently reset/changed your internet access (e.g. resetting your modem and changing your access settings such as renaming an SSID access point, changing your access password, etc.). Reinstall the software and configure your network access settings (like you did when you first set up the printer - with USB cable. Refer to your manual).
Jul 30, 2010 | Canon PIXMA MP620 All-In-One InkJet...
When I try to install canon mp620 on new computer
You may find some help at this link. It contains some very good guidance on setting up the MP620 on a wireless network.
May 21, 2010 | Canon PIXMA MP620 All-In-One InkJet...
I have a cannon MP620, when i go to print it says printer not responding. switched from wireless to wired. still same problem
If this is a new install, make sure the printer driver is configured to the correct port.
Control Panel > Printers > Right click "Properties"
Click Port Tab
If you have used this printer before successfully on your wireless network, try resetting your router or access point.
Jan 09, 2010 | Canon MP610 Photo All-In-One Printer
Printer not detected with Wrt54g2
Fixed it. I saw another post by someone, who had detailed step-by-step the setup proceedure with regrds to wireless. First, make sure printer is connected via USB to PC and everything works.
Next on printer, select settings, then device settings and Reset all network settings.
Next, run the CD-rom, select region, and then select Easy install when main menu appears.
Nest select only the most essential drivers, MP drivers and the Canon IJ Network tool. Select & reinstall the MP driver (main driver) and Canon IJ network solution tool.
Once they are installed. Run the Network IJ tool program, follow the setup to activate wireless.
This is how my MP620 finally worked.
Hope this makes sense.
Jan 04, 2010 | Canon PIXMA MP620 All-In-One InkJet...
I'm trying to connect to my Canon MP620, wirelessly. All my other computers have been hooked up, catch is I had the disc. Windows automatically installed everything when I hooked it up with the USB cord...
If I understand you correctly, you have lost the software?
I'd recommend getting the software for MP620 from Canon. Select the operating system in the drop down box to the right of the text "Please select your operating system to view available drivers and software" on the page to reveal the software downloads relevant for your operating system.
Then run the network install using the downloaded and installed software on one of the computers. You have to connect the printer using the USB cable once to setup network access to the printer. After that, all computers should be able to see the printer through the network. The software should be installed on all computers that should use the printer.
I have set up wireless connection to the very similar Canon MP600R before, with success.
Aug 13, 2009 | Canon PIXMA MP620 All-In-One InkJet...
81 people viewed this question
old marine
old marine
