Question about Canon PIXMA MP150 All-In-One InkJet Printer
HP LaserJet P2015 cartridge refill
How to bypass chip on cartridge when cartridge is refill with toner.
The toner light stays on and there is a "Order black cartridge alert" "Approximate pages remainaining 0"
  • 4,889 Answers
The simplest way to get around this check is to have atleast 2 cartridges. The printer checks the chip to check if the same cartridge is installed again. By refilling a different older cartridge and installing it you can fool the printer and get around this check.
Posted on Dec 04, 2008
The attention light comes on when i want to print
some times this printer problem on toner chip.some times problem processing print defective on LSU
Aug 10, 2016 | HP LaserJet P2015 Printer
Which one refill kit I need on this page?
HP Easy Refill Kit for (HP) Color Inkjet Cartridges Printer
Jul 10, 2012 | HP Easy Refill Kit for (HP) Color Inkjet...
How to reset supplies on HP 2840 laserjet?
"Would like report of supplies from 2840 laserjet. How to get it to show report"
Select 'Menu" button, then select "Reports", then select "Supplies Report".
This will print the status of the four toner cartridges and the drum.
It doesn't make sense to reset toner cartridges UNLESS you refill them
first. On the HP 2840 each cartridge/drum contains a chip that measures
the life of the unit.
You can purchase toner/chip combinations online cheaper than new
cartridges. I also purchase drum chips to extend the use of my drum
until print quality actually starts to deteriorate.
I use both of these methods to save money on supplies - buy toner and
toner chips, buy drum chip to get full use of drum unit.
Hope this helps.
Mar 19, 2012 | HP LaserJet 2840 Printer
Replaced the magenta cartridge and it still says "order magenta cartridge". How do I correct this problem?
Did you replace with an orginal HP cartridge or a reman. Either way, it sounds like the chip that tracks toner usage is bad on the cartridge. If original HP, contact HP and get them to repalce it. If remanufactured cartridge, contact the people that refilled the cartridge.
Jun 04, 2011 | HP 645A Magenta Toner Cartridge (C9733A)...
How to reset hP 2600 colour printer chip
When you refill an HP color laser cartridge you need to replace the SmartChip, as I do not believe that there is any way to reset the chip. Any reputable seller of toner would include the chip with the toner order. The are for sale on Ebay
Apr 11, 2011 | HP Color LaserJet 2600n Printer
I change my toner, and i have msg. "ORDER
Must be an aftermarket or refilled toner cartridge. These toner cartridges have a chip on them that must be changed when refilling or remanufacturing the cartridge. It looks like you got a cartridge where the chip has not been changed. I would return it for another cartridge.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 13, 2011 | HP LaserJet P3005 Printer
This machine ran out of toner today, but didn't give a local notification that it was low. I have tried to find the setting to enable this notification via the printer's web page, but am unable to find it....
Thank you for contacting FixYa with your printer inquiry.
HP toner cartridges for this printer have an embedded chip built into the cartridge that prompts "Low Toner" message locally and will broadcast through its WEB server. Non HP Toner Cartridges or Refilled HP Toner Cartridges will no longer have the chip enabled to generate this message. You can continue to print but the toner level status will not be generated.
Solutions; Purchase new HP Toner cartridge's from reliable source.
Try a third party replacement chip"
http://cgi.ebay.co.uk/HP-LaserJet-P4015-P4015n-dn-Toner-Reset-Chip-CC364X-64X-/310239780829
http://www.octopus-office.de/en/shop/details/c/toner-powder-hp-p-4014-4015-4515/p/reset-chip-hp-p-4014-4015-4515-black-toner-chip/
Hope this helps. Please keep us updated and remember to rate this answer.
May 19, 2010 | HP LaserJet P4015N Printer
We hve a hp laserjet P2015 printer. The tirangle w/the ! in the center keeps coming on. Is this a chip issue or something else. I have tried 4 different cartriges in it now. All doing the same thing Thans,...
I dont have solution,but I have similiar problem. My toner light comes on after 10-25 copies and i need to open and take out cartridge every time it does it.I have tried diferent cartridges (oem and compatible ) all with same problem
thanks Andy
Jan 08, 2010 | HP LaserJet P2015 Printer
The paper jam light is constantly on
if you are using cheep re-mfg toner cartridges the amber light will be on all the time but you can still print. to fix this buy toner cartridges with new chips installed.
Jan 05, 2010 | HP LaserJet P2015 Printer
Laser cartridges with chips
you need to replace the chips so it will read the amount of pages printed by the toner cartridge.This chip is only for measuring how many pages printed.
Mar 30, 2007 | HP Q2613A OEM Genuine Black Laser Toner...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
476 people viewed this question
old marine
old marine
