Question about Intel D845GVSR Motherboard
Hi ,i have intel motherboard d845gvsr with p4 processor,4 years old problem is that it suddenly got switched off . when power on then there is no display ,no sound nothing and auto switch of in 10 secs,when i restart it it give high/low siren sound . can u help me what is the problem.
  • 4,889 Answers
I had a similar problem with my pc sometime ago. The main cause for this is oxidized DIMM contacts. just take out your RAM wipe its edge(The end which you insert into the slot) using an eraser and that should fix the issue. Also make sure the sound is not coming from your hard disk. If it is then just push in the power connector of the hard drive in(it has 4 pins).
Rate positively if it fixed the issue or you need more help..
Posted on Dec 04, 2008
I have intel motherboard D845GVS1 with p4 processor. can sata hard disk be connected in my computer?
Yes... You just need to buy a Sata Controller Card for one of your PCI slots and hook your sata drive into it.
May 18, 2012 | Intel D845GVSR Motherboard
FAN OK BUT NO DISPLAY
I like that. Kinda' rhymes. "Fan OK but no Display"
Problem is your Processor isn't turned on.
You have a bad Power Supply.
> Weak voltage power rail.
You probably have a 200 to 300 Watt power supply. (SMPS)
1) ALL of the LED lights together use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor can use 51 to 125 watts. Depends on what Processor it is.
The Intel D845GVSR motherboard uses a Socket 478 processor socket.
Supports Intel Celeron, Intel Pentium 4, and Intel Celeron D, that utilize a Socket 478 processor socket, and have a maximum FSB of 533MHz.
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
Utilizes the Intel 845GV motherboard chipset.
[ Intel 82845GV Northbridge chip, and Intel ICH4 Southbridge chip ]
89 Watts is the maximum wattage, that can be used by a Processor for the Intel D845GVSR motherboard.
Power Supply has enough power to light LED lights, and spins fans, but not enough to turn the Processor on.
No Processor operating, No computer.
No computer, No video signal to the monitor.
(No Signal)
Do you have access to a KNOWN to be good, compatible Power Supply, for a test unit?
Motherboard Manual in PDF file form:
http://www.intel.com/p/en_US/support/highlights/dsktpboards/d845gvsr
Under the heading > Documents and Guides, left-click on > Product Guides for D845GVSR.
Then left-click on the first file listed.
Product Guide - PDF File Name: D845GVSR_ProductGuide_English.pdf
Nov 03, 2010 | Intel D845GVSR Motherboard
Drivers for intel 845 gvsr with p4 2.4 gHz for windows 7
please visit the website below and search for your board 845 then select your operating system in the right hand box and the drivers that are available will be show below hope this has helped http://downloadcenter.intel.com/Default.aspx
May 22, 2010 | Intel D845GVSR Motherboard
Intel D845GVSR & Windows Seven !!! Sir I am having an Intel D845GVSR motherboard,Pentium 4 processor,2GB DDR333 RAM and 320 GB Hard Disk. When I attempted to install Windows Seven...in the menu for...
hello: not all old driver are compatible with windows 7 searts or google for it on the net .
maby next year if windows 7 are on the marked the hardware suplyers wil figure out more driver for windows 7
Nov 01, 2009 | Intel D845GVSR Motherboard
I have intel 845gvsr motherboard so iwant to buy a new intel processor which is compatible
it support intel 478 pin processor 1.8 ghz 400 bus up to 2.4 ghz 533 BUS
May 29, 2009 | Intel D845GVSR Motherboard
Best Graphics card for my Pc
Hi Dr,
Best video card for you're Intel D845GVSR would be XFX GeForce 6200 Video Card - 512MB DDR2, PCI, DVI, VGA, TV Out. XFX carries a Lifetime Warranty.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3735736&CatId=319
Enjoy!
Mike
May 09, 2008 | Intel Motherboard
Upgrading
To upgrade from pentium 3 to P4 you have to change alot of the hardware.
You need a NEW P4 Socket mPGA 475 Motherboard.
New DDR RAM
New 478 PIN Processor.
You can use the old CD rom and Hard drive and any other PCI card but You Need the Mentioned Hardware to Upgarde.
Jan 08, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Intel D845GVSR Motherboard Logo
90 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
