Question about Kenmore 60659 Microwave Oven
Microwave Dead after burning up potato
I've had this built-in over-the-range microwave for more than 3 years. It has always been reliable. Recently, I tried baking/cooking one small to average size potato. I realize now that I probably set the timer for too many minutes. I had set it for 10 minutes on full power, because earlier the same day I cooked about 4 or 5 potatoes in a different microwave at work and the smaller ones turned out just fine. Anyway, smoke poured out of the microwave, there is some smoke soot inside the microwave, and the potatoe sort of looked like a large piece of charcoal. Ever since then, the microwave is totally dead. Nothing on it works. I checked the fuse on my electric box and it seems to be ok. Is there something I might be able to do to fix the microwave, or do you think it is repairable at all? I hope it can be fixed as the cost and installation of a new one will be more than $400.
I had the same problem, technician said it was the thermostat, once replaced it worked fine.
Posted on Sep 11, 2007
  • Kenmore Master
  • 9,156 Answers
Chances are the magnetron overheated and blew the thermostat / thermal cutout that monitors it. The magnetron itself may be bad, too. If Sears Service might consider this still under magnetron warranty, then they may replace the mag with no part costs (or just the thermal cutout part cost), but likely would charge labor. You can contact customer service or repair via http://www.sears.com Otherwise, if you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://www3.sears.com or likely cheaper here: http://tinyurl.com/gv383
Posted on Feb 07, 2007
SOURCE:
I bought a Gallery microwave built-in about a year ago. Soon after we tried to use the potato fuction and the sensor malfunctioned. It filled my house with smoke.tt
I'm no expert with microwaves but I always go online to
"Repair clinic" Be sure to have the manufacturer, the model number & serial number. I have found this site to to be most useful when fixing most household appliances.
Aug 30, 2017 | Microwave Ovens
Microwave starts by itself
Likely a microprocessor/control panel issue. Microwave ovens that sit over ranges often have electronic failures due to heat, humidity, and grease, from the range below, which come into contact with their main circuit boards.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 16, 2014 | Samsung 1.8 Cu. Ft. Over-the-Range...
MAYTAG MICROWAVE OVEN ARCING FOOD ON PLATE, HEATS EXTREMLY FAST. PUT BABY FOOD (SWEET POTATOES ON A PLATE AND WITHIN 5 SECS THE FOODS BEGINGS TO ARC AND BURN
The magnetron is getting to hot and will eventually fail, especially when it is arcing, "a safety issue convern" the cause is the part mentioned above, or there is exposed metal on the inside cavity.
May 07, 2012 | Maytag 1.6 Cu. Ft. Over-the-Range...
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
Jan 28, 2011 | Amana MVH210W Microwave Oven
Get rid of burned smell in Microwave
I decided to buy a new microwave. I am resistant to paying a monthly fee to FixYa as I have so few "breakdowns" in my house each year.
Dec 29, 2009 | Microwave Ovens
Baked potatoes went up in flames now microwave has no power no lights. power outlet has 110v ac
Were the potatoes wrapped in foil? If so, the megatron tube was burned out. Replace unit.
Nov 06, 2009 | Kenmore 62622 Microwave Oven
Kenmore 60659 Microwave Oven Logo
221 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
