I have problem of disply .after removing ram processor fan moving properly but when seting ram on board it not move properly and unable to give display after installing new ram it remains constant..
    Problem Solver:
  • 8 Answers
Ther is problem in your ram socket on the mother board
Posted on Dec 04, 2008
Computer turns on, fans move, and lights light up, but no beeps are heard and no bios shows on the screen. Not sure what is causing the problem. From research, I've heard it could be RAM, motherboard,...
Its ram problem in most cases.First check it by removing rams of your system,second check hdd.
when system display screen its firs load in ram for processing then processor send it to vga and if ram have problem then processor unable to process msg for you and you unable to see screen.
Jun 02, 2011 | Computers & Internet
Processor is OK, CPU fan is also working but no display in board, and also processor is no become heat when supply is ON
If there is no display then first of all we start form the power connector of your monitor check it if its lose if yes then fix it properly and also check your another cable which is connected to your CPU.
After power connector unplug all the power cables and remove the cabinet of your system
now look for the RAM on the mother board .
Take it out by un clipping the side locks.Clean the golden pins with a normal Eraser and clean it with cotton cloth.
Fix it in the same slot properly you have to be very careful, Keep the RAM properly and push it properly inside, the side lock should lock automatically if not then try again.
Then carefully plug only the power cord and the monitor cord and start the system, if you are not getting display then try the RAM in other slots.
If you are not getting the display the try changing the RAM.If this solves your problem then don't move to the next step.Then you are done if it resolves the problem then move to the below step.
Now lets move to video card, similarly take the video card and clean it and fix it .If you are not getting display then you have to replace the video card.
Now you are done.Hope the information provided will be helpful to you.
Thanks for using Fixya.
Nov 23, 2010 | Intel D845GVSR Motherboard
Fan mooving but no beep no display msi k9vgm-v board amd processer
if only processor fan is moving & there is no any other processing like ram beep etc then check your processor & motherboard.
if you have any other board with same conf. then interchange the processor & check.
Aug 02, 2010 | Asrock P4I45GV R5 Motherboard
GIGABYTE GA-M61SME-S2 AM2 NVIDIA GeForce 6100 Micro ATX AMD Motherboard Will not post, tried clearing CMOS, moved memory chips around. Still does not post.
Is this a new board? Check the processor to make sure that it is seated properly. You will have to remove the fan and heatsink, but if you put the processor in yourself, it is possible that it didn't seat properly.
Mar 19, 2010 | Gigabyte GA-M61VME-S2 Motherboard
I dont't get display in my moniter my board is intel dg43nb ram 4 gb, core 2 quad processor fan move green led light but n display
check the ram to know if it is actually working or sitting properly.......check the VGA port...........try another monitor on your board........lastly try the monitor on another board and if it works you board is bad
Jan 31, 2010 | Intel DG43NB Motherboard
PC will not power on - fan turns briefly then stops
The easiest way to troubleshoot these syetms is disconnect parts one at a time and try booting each time. This issue may be power related, but may not be the power supply but rather a component pulling too much power and causing a shutdown. First disconnect the ram, one stick at a time, then move on to the cd or dvd player, move through the components to see if any of them are the culprit. Test the PSU to see if it is putting out the proper voltage. Check the processor heatsink for air blockage and remove the processor and replace the thermal paste on the processor and heatsink. An initial high temp will cause the systym to shut down. I am thinking it is your power supply, because when you turn the system on, even if the system doesnt boot, the fan and the components should continue to run. Lets try disconnecting components first, then move on to checking the PSU voltage.
Nov 08, 2009 | Acer Aspire RC500 PC Desktop
Disply problem
CHEK POINTS
1. Does your fan spins
YES:- Go to 2. No:- replace S.M.P.S.
2. Do you get any beep noise
Yes :- remove and fit Ram No:- go to 3
3. Does your processor fan spins & stops after while
Yes :- Your Processor might damage No:- go to 4
4. Do you got spindle voice of your hard disk & fan spins & stops after while
Yes:- Please take out motherboard from chassis & chek
No:- remove C-mos battery for 1 hour & fix again & check
Mar 14, 2009 | AOpen Computers & Internet
Gigabyte mother board ga-6bx7+
You might have damaged the CPU/ motherboard during the process of overclocking.
Check your CPU on other compatible mobo.
Check your mobo documentation properly & set the jumpers rightly. If that doesn't help, you will have to replace the mobo.
Jul 01, 2008 | Gigabyte GA-6BX7 Motherboard
The power on my pc keeps recycling
remove all hardware except RAM n CPU and then try it if the system gives you a disply then add all hardware 1 by 1 and keep checkin this way you can find the problem with the harware compatibility if the system wont disply then check the mobo for RAMs and CPU respectively if the problem presists then you have the BAD BOARD.-
Jan 16, 2008 | Intel D845GLLY Motherboard
Intel 845 GVSR
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Nov 11, 2007 | Intel Motherboard
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
