Question about 2wire HomePortal 1800HG Router (1000400229000)
Router blocks MSN and https: secure sites
Help me please. When I try to login to MSN Messenger, i get an error message saying the firewall is blocking it. Also when I try to access at website which begins with https: (a secure site), the page simply doesn't load. Can anyone tell me how to fix this problem?
I had exactly the same problem. Check your mtu settings on the 2wire. I think the modem is set at 1450 (or there abouts) An article (sorry can't find a link) suggested raising it to 1500 this didnt work for me so I started reducing it instead. Once i set it at 1400 mtu I was able to log on to secure sites again. Hope this helps.
Posted on Dec 15, 2010
Reset the windows security files. Go to start, then run and type in cmd. Click ok. In the command prompt type regsvr32 softpub.dll and press enter. Next type regsvr32 wintrust.dll and press enter.
If that doesn't work you may need to lower the MTU setting in your router. This controls the packet size sent and can cause problems with secure site encyption if too large.
Posted on Mar 25, 2008
  • billveeneman
    billveeneman Jun 07, 2011
    MTU setting on my cisco RV042 was set to AUTO. Changing it to manual and 1500 bytes - bingo... that solved my problem. [I could not go through the router to thinkorswim with https reliably - or at all. Evidence of the router problem was all computers plugged directly to the ISPs (dual WAN) worked fine. Solution was instantaneous.
    President:
  • 2,961 Answers
You must have your internet browser settings too high, depending on the browser you use it will be in the internet options.
Posted on Feb 07, 2007
Error 80072f7d
Since you can't immediately login, remember that you can try logging into the Web Messenger,
at least until you can restore your normal Messenger functionality:
http://webmessenger.msn.com
However, here are some suggestions you should check/try if you haven't already.
1. The date on your computer needs to be set properly -- double click the clock verify that
the time and date are set.
2. If your password information is not saved, verify that you are typing it in with the
correct case (uppercase or lowercase).
3. Change your password @ https://login.passport.com/ChangePW.srf to
something smaller (under 10-12 characters), then try signing in again.
4. If you use a firewall (like ZoneAlarm, Norton Internet Security etc. ), it's possible
that Messenger doesn't have the correct rights to access the Internet, especially since you
upgraded. You may need to re/add Messenger to the allowed list of programs in your firewall
if this is the case.
5. If you disabled your firewall in the past, it still may be blocking Messenger -- try
restarting it and see if that helps the situation. You also might try uninstalling an
installed firewall, to verify that it isn't causing a problem (even if it is disabled).
6. Clear your IE cache and cookies -- open Internet Explorer, click the Tools menu, then
Internet Options, then click the Delete Files button, and when that's complete click the
Delete Cookies button.
7. Check your IE Security settings -- open Internet Explorer, click the Tools menu, then
Internet Options, then Advanced tab, scroll to the Security section, and verify that "Check
for server certificate revocation" is unchecked. Also verify that 'Use SSL 2.0' and Use SSL
3.0' is checked, then click OK.
8. Click Start, then Run, and enter the following:
then click OK
and do the same for the following:
regsvr32 initpki.dll
regsvr32 MSXML3.dll
Nov 21, 2010 | Microsoft MSN Messenger Connect Service
Hello I am getting the problem with sign in to MSN messenger, Error 80048820 I have checked / tried all the steps described on...
then click OK
regsvr32 MSXML3.dll
Nov 04, 2010 | Microsoft Windows Live Messanger
Error code 81000306 cant sign in
http://messenger-support.spaces.live.com/blog/cns!8B3F39C76A8B853F!13932.entry
Please go and read the solution right there.
Hope this helps.
Aug 18, 2010 | Microsoft Windows Live Messanger
I am trying to sign on to msn messenger and i get the error code it is 80048820
Please follow steps to resolved issue
The Solutions to MSN Error Code 8004882080048820_lan.jpg Internet Explorer - Try removing the tick next to Internet Explorer 'Proxy server' settings, instead, go with the 'Automatically detect settings'.
1) Launch Internet Explorer, click Tools and then click Internet Options.
From the Internet Options dialog box, go to the Connections tab.
Click LAN Setting. Un check the Use a proxy server for your LAN (These settings will not apply to dial-up or VPN connections) checkbox. Finally positively tick: 'Automatically detect settings'.
2) Register softpub.dll.
Click Start (Button), and then click Run, type regsvr32 softpub.dll. Restart MSN Messenger. See also Error code 81000314
3) If necessary, logon as a local administrator and set the computer's clock to the correct date and time. (Check on the internet if possible.)
4) Turn off the firewall temporarily. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
NetGear problem, but also with some other routers
a) Enter IP address 192.168.0.1 in your browser's address bar.
b) Log on with ISP user name and password.
c) Enter Admin, password
d) Navigate to advanced menu, WAN set-up
e) Change MTU size to 1400
5) Try a password of no more than 8 characters.
6) If you are using IE 7.0 check the SSL Settings. Internet options advanced (Tab) scroll down to the bottom. Security section. Tick 'Use ssl 2.0'.
7) One of the simplest ways of curing MSN error 80048820 is to unplug, or restart your modem. This is particularly effective for cable modems.
8) We should have tried this solution before; check that the MSN site is 'up' 'available'. However, even if the site is down, you don't usually get error code 80048820.
8a) As a variation, of checking online, you could try phoning your local Microsoft Support office. Local area numbers available from http://support.microsoft.com.
9) Have you just installed any anti-virus software? Did the anti-virus software just make a big update? Try disabling and see if that cures the error.
10) A drastic solution is to try uninstalling MSN Messenger version 8.0 or 7.5 and install Microsoft MSN version 7.0.
Hope it can resolved issue
Thanks for using Fixya
Apr 02, 2010 | Microsoft MSN Messenger Connect Service
Acer Aspire 5630 will not fuction with MSN messenger Yahoo messenger or Skype
I don't know what exactly is happening when you say it is not functioning. I'm assuming that the software would load but it wouldn't send and receive messages.
  • Check your firewall - it maybe that your firewall or even antivirus (sometimes it's bundled with a firewall) is blocking certain ports that those programs require to send and receive messages.
  • To diagnose this, go to control panel then security centre and click "windows firewall" on the left, change settings and turn off the firewall. Leave that control panel open and attempt to use MSN etc.
Jan 19, 2010 | Acer Aspire 5100 Notebook
Error code 80072745
From the Microsoft web site at: http://messenger-support.spaces.live.com/blog/cns!8B3F39C76A8B853F!13931.entry?sa=240159924
December 11 Error: 80072745 If you are encountering the error code 80072745 when you sign into Messenger try the following: 1. If you are connected to the Internet through a router, remove the connection to the router. Then, directly attach the network or modem cable to the computer. This will help determine whether the issue is related to a firewall setting on the router. Try to sign in to Messenger after you connect to the Internet. If you can connect to Messenger after bypassing your router, the issue may be related to router settings. Try resetting your router (Note: This may revert your settings back to factory default settings and may delete all your custom settings.). Please contact your router manufacturer's Help documentation or customer support channels to determine how to reset your router or enable port 1863 through the router firewall. 2. If you are signing in from a corporate environment, contact the network administrator to determine whether port 1863 is being blocked inside the network.
3. If you have Zone Alarm with IM Security installed on the computer, turn off IM Security for Messenger: 3.a. Right-click the Zone Alarm icon in the notification area, and then open the Control Center.
3.b. Click IM Security or click Security to open the IM Security settings window.
3.c. Click the Main tab or the Status tab.
3.d. Slide the Protection Level slider to Off to turn off IM Security.
Note: This procedure will change the IM Security settings for any instant messaging programs that are installed on the computer.
3.e. Sign in to Messenger again to determine whether the issue is resolved.
4. If you are connecting to the Internet using a Wireless Data card through a mobile phone network, please contact your mobile internet provider to verify if you need to additional data plans that enable you to connect to the Messenger service.
Aug 15, 2009 | Microsoft Office Outlook 2003 for PC
People cannot see me on cam
every application when it connects to the internet, it uses "ports" , now if the port that the messenger is trying to use for the "cam" is blocked , you basically experience that kinda problem. first disable your firewall (try windows first, then any other firewall (like norton, mcafee or other), also check with your Router or Modem (if DSL) but usually these ports are open by default, but you never know sometimes untill you check it. but your best bet is the firewall that is blocking your port for the cam.
disabling the firewall is the easy solutions, opening the ports is the longer one. of help on opening ports on you DSL modem OR router (or both), check this site
good luck
Jun 18, 2009 | GE MiniCam Pro HO98756 Webcam
Error code 80048820
MSN Message error 80048820, unable to signin
Problems:
- While you try to Sign in MSN Messenger you getting an error message with the no. 80048820
- Unable to Sing in
Probably reasons-
- Your system time/date incorrect
- Internet Proxy setting incorrect
- softpub.dll disable/missing
- Firewall does not allow to access, etc.
Solution-
Step#1
- Remove Internet Explorer proxy server settings and check the 'Automatically detect settings'.
- Launch Internet Explorer, click "Tools" and then click Internet Options. From the Internet Options dialog box, go to the Connections tab. Click LAN Setting. Uncheck the Use a proxy server for your LAN checkbox. Finally tick/check: 'Automatically detect settings'.
Step#2
- Correct the computer system's Time/Day as current (if required).
Step#3
- Click Start (Button), and then click Run, type regsvr32 softpub.dll click ok.
Step#4
- Turn off the firewall. Check firewall settings such as Norton: "Block access to secure sites". If this cures the problem, make sure that Microsoft's MSN Messenger is allowed full access through your firewall.
Reference from:
http://www.trulybangladesh.com/itnews.php
Aug 12, 2008 | Computers & Internet
Key ports
I had the same problem and I tried everything I found in all kind of forums but nothing every seems to work.
What it worked for me was:
First:
Clear your proxy settings in Internet Explorer:
  1. Start Internet Explorer.
  2. On the Tools menu, click Internet Options.
  3. On the Connections tab, click LAN Settings.
  4. Clear the Automatically detect settings check box.
  5. Click OK, and then click OK again.
Then:
Check Internet Explorer security settings:
  3. On the Advanced tab, in the Security section, make sure that the Check for server certificate revocation check box is cleared. Also, make sure that the Use SSL 2.0 and the Use SSL 3.0 check boxes are selected.
  4. Click OK.
Apply Changes.
Close Internet Explorer
Run Windows Live Messenger and You Are Ready To Chat Again!!
Aug 08, 2008 | U.S. Robotics (USR8200USR8800KIT)
Windows live messenger
4. If you are connecting to the Internet using a Wireless Data card through a mobile phone network, please contact your mobile internet provider to verify if you need to additional data plans that enable you to connect to the Messenger service. Hope that helps!
Apr 23, 2008 | Microsoft Office Outlook 2003 for PC
Computers & Internet Logo
1,727 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
