Question about Dell Dimension 2350 PC Desktop
Can't enable LAN or Wireless Ntwk Connections
We have a NEC Versa P7200 that was happily connecting wirelessly to our Netgear Router, then just stopped working for some reason.
Within the Network Connections window, the LAN connection advises that the network cable is unplugged, and the Wireless connection advises it's not connected.
I've tried; uninstalling/ re-installing both controllers, installing new drivers, re-formatting my hard drive with no luck
I'm at a loss as to why I can't connect and what I can try next.
  • emalicious Dec 07, 2008
    Forgot to mention that other PCs can connect to the Router, so not the Router.
  • 386 Answers
I believe that all you really had to do was just unplug the router for a few seconds then reboot it and try again to connect to it. I've a few routers that for no apparent reason just go off-line wirelessly and that would fix it. You also could just check it's settings to verify it is configured correctly before rebooting it.
Formatting your hard drive was a bit in the wrong direction and a needless process.
Good Luck
Posted on Dec 04, 2008
Dell XPS M1530 laptop can't access Internet with Netgear router DGN 1000.
Have you opened Internet Options, Connections tab, Lan settings, Check Auto Detect. OR release and renew your IP address : http://www.wikihow.com/Refresh-Your-IP-Address-on-a-Windows-Computer Is your wireless adapter enabled? Drivers up-to-date? in working order? Have you run the diagnose in Manage Network Connections. What is your Anti Virus? Try connecting with it disabled?
Dec 26, 2012 | NetGear DGN1000 Wireless Router
Router wont connect from the CD, all connections are correct
Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password
You can now change the admin password and configure the wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 08, 2011 | NetGear WGR614 Wireless Router
My netgear wpn824 router is not connecting to the dsl router address 192.168.1.1 without connecting how can i configure my modem
You can bypass the Smart Wizard Configuration Assistant feature by typing
http://www.routerlogin.com/basicsetting.htm
in the browser address bar. You may be prompted for a user name and password. The user name is admin and the default password is password. This will enable you to manually configure the wireless router even when it is in the factory default state. When manually configuring the router, you must complete the configuration by clicking Apply when finished entering your settings. If you do not do so, a browser on any computer connected to the router will automatically display the router's Configuration Assistant Welcome page rather than the browser's home page. In the Lan setup page, you have to use PPPoE, and type in the username and password from your DSL provider.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 15, 2011 | NetGear RangeMax WPN824 Router
The netgear is set up and the lights are on and i connected it but it says limted or no conectivity on the status and the signal is good so whats the problem
try right click on the computer icon near clock and go to status then to repair tab if this does not work try this;
if XP go to start button go to all programs accessories command prompt when it opens type in ipconfig/release hit ENTER
then type in ipconfig/renew
re-boot computer if this fails
disconnect power from modem, router and computer for at least 2 minutes turn on modem let it flash for about a minute then turn on router let it run for a minute then boot up computer.....
Jul 20, 2010 | NetGear WGR614 Wireless Router
Wireless won't work - can't type in registration boxes on netgear
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 11, 2009 | NetGear WGR614 Wireless Router
Netgear WGR814v2 does not see my ASUS 1005HA-P netbook, but the netbook sees the the Netgear wireless network but cannot connect .
To connect into your own Netgear router, you need to configure the wireless card with your router's wireless configuration settings, eg.the SSID and encryption settings. Check your router manual on how to configure the router or go to the Netgear WEB site to download this info.
To configure the Netgear router for wireless you need to connect a LAN cable from the laptop to the router and run your browser with the configuration IP address. for Netgear type the URL address ;-
http://192.168.0.1
the login = admin PW = password
Then configure the SSID and encryption, record this info so you can configure the wireless card with the same settings.
You can also connect to the Internet by using a LAN cable and plug it into the Netgear router without a wireless connection.
Sep 04, 2009 | NetGear WGR614 Wireless Router
Netgear connection
is that wired connection or wireless? if it is wired, checked the cable and the port, make sure that the LAN connection is enabled.
if it is for wireless, checked the wireless settings of the router, enable the wireless card of the wireless computer and, verify the wireless settings of the netgear adapter and from there connect to it.
Jun 26, 2009 | NetGear DG834G Router
Setting Up the Netgear WGT624 as a bridge
Just disable the DHCP function of the Netgear router. Connect them from LAN port of 2wire to LAN port of Netgear.
Nov 25, 2008 | NetGear WGT624 Wireless Router
Netgear wireless router DG834PN wireless access local only I can get internet on my desktop which is connected to the router via ethernet but I can connect to the router wirelessly on my laptop but only...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To start with plug the LAN cable, type 192.168.0.1
into your browser, a netgear window should come
up name is (admin) PW is (password) default.
goto to wireless settings.
Tick Enable Wireless Access Point
Tick Allow Broadcast of Name (SSID, give it a name
Under security options, Tick none
Hit apply and exit
Setup your laptop up with no security to start with, the laptop
Should now see the Netgear SSID name you made.
After this find out your laptops MAC address, log back onto the
Netgear unit, add the MAC address to the allowed list, hit apply
And exit, now only your laptop will be able to get a wireless connection.
Hope this helps
Have a nice day
Aug 14, 2008 | NetGear WGR614 Wireless Router
NEC Versa s970
when the bluetooth and wlan light are off press the wireless button three times and wait a sec and it will work. thats what nec told me
Apr 16, 2008 | NEC Versa LX Notebook
Dell Dimension 2350 PC Desktop Logo
162 people viewed this question
Alun Cox
