How to change 2 channels speakers to program to 5 channel program
    President:
  • 1,073 Answers
Press the star button, select controll panel, inside ther you will see an icon saying "Sound", press on that icon, inside there you can change the 2 channels to 5 or whatever your soundcard suports
Good luck
Posted on Dec 04, 2008
I want to set the receiver to surround sound. The indicator only shows two speakers I want it to show five
What is the source of your sound? By default, receiver will use only those channels that are used in the input signal - if you play CD in stereto, it will use only 2 front speakers. If you play DVD with 5.1 audio, it will use all 5 speakers (+ subwoofer if you have one).
However you can use one of the bulitin "sound field program" modes to mix the 2 channel stereo music to all speakers. On front panel, press "PROGRAM < >" buttons to select the one you like. Or on remote control, repeately press MOVIE, MUSIC or STEREO buttons. You can check your manual for description of each sound field program.
Oct 11, 2014 | Yamaha RX-V661 Receiver
Hi, my problem is only the front 2 speakers work i have tried all the speakers in the front 2 connections of the unit & all speakers are working but none when in the rear, center, & sub woofer unit...
Without knowing which receiver etc you have... make sure your "mode" is set to 5 channel, Dolby Pro or similar. And even then, make sure your source is 5 channel. What are you using for an input cable? It needs to be able to provide 5 channel. Standard RCA stereo type cords do not. You need either optical, "coax" or hdmi. Lastly do you actually have a 5 channel program? Many older movies, and standard cable boxes only output stereo, not 5 channel.
May 31, 2011 | Audio Players & Recorders
Don't know how to save and assign radio channels
ok change the channel to what u want to listen to then hold the number 1 button for like 3 sec or 5 secs then that channel is programed to channel 1 repeat steps for button 2 3 4 5 ect... with ur other fav stations u like to listen to.. then u can press the fm button to go to fm 2 which again u can program 1 through how ever many channel numbers ur radio shows now program different stations other then the ones u just programed on fm 1 choose 5 or 6 other station the fm2 just offers u more stations to program other wise just program the normal 5 or 6 stations to ur radio
May 16, 2011 | Car Audio & Video
Unit is a 2 channel system. If connected to a 5 channel receiver can it function over the 5 speakers?
Most 5 channel receivers can simulate some kind of surround effect from a 2 channel signal, so the answer is most likely yes.
Jun 21, 2010 | Technics SL-PD887 5-Disc CD Changer
How to change channel
Spirit GT: Programming a Frequency to a
Selected Channel:
1. Press and hold down the Push-To-Talk
button while turning the radio on, wait for
approximately 5 seconds then release the
Push-To-Talk button.
2. Use Scroll button to select one of the 8
frequencies.
3. On a Spirit GT+, press the Monitor button.
4. The current channel will flash, press scroll
button to change channel.
5. After the second channel is selected, press Monitor button again, current
frequency for second channel will flash. Figure 16.
6. Use Scroll button to select new frequency.
Exit Programming Mode - 3 Ways
1. Press Push-To-Talk to exit completely.
2. Allow the Menu time to expire (10 seconds).
3. Press Menu button to go to code programming.
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
Jul 17, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
How do i change the channel?
Selected Channel:
frequencies. Figure 16.
Jun 25, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
I need speakers for my Onkyo A-911M integrated amp
A+B speakers = 4 channels 2 right 2 left
100 watts/4 = 25 watts per channel
RMS watts / channel = 25 x .707 = 18 watts/channel which is your average consumer stereo system
I would use 8 or 16 ohm speakers (not 4 ohm) -- almost any set of stereo speakers will "work" -- these will be 8 ohm and about 5 watt minimum / 40 watt max thereabouts
May 07, 2009 | Onkyo Audio Players & Recorders
Wiring speakers to amp for both 5.1 channel and 4 speaker listeni
I am assuming that you want to have a normal stereo ( 2 channel ) from, CDs, Radio Etc.. To be able to play from all of your speakers for a more surrounding sound experience, for parties or just more sound. I am also assuming you currently have your speakers wired like standard 5.1 in the bottom diagram on page 19 of your receiver manual. To change the way the sound is coming from your speakers you will need to refer to the “Sound Field Programs” part of your manual starting on page 52. You will want to be in the input source you would like to change “ie: radio” Let assume you want to change radio, once the radio is on; Rotate the “N” Program selector, (or press “5” and then “12” Prog < /> repeatedly ). You will want to change to program, “7ch Stereo” this should take your 2ch signal and send it to all connected speakers. If this does not work, please let me know.
Feb 23, 2009 | Cerwin Vega E-78 Main / Stereo Speaker
Problem w/ 5 ch mode
Hi, maybe you are not feeding a 5 channel program.
Use built-in test tone to check if all speakers are wired and working correctly.
Nov 20, 2008 | Yamaha HTR-5930 Receiver
CHANGING FROM FREQUENCY TO CHANNEL MIDLAND 75-822
Some models of the 75-822 do not offer this as a feature. Instructions for it are not included in the manual. I recently encountered a refurbished model packed with a manual such as this. Pressing and holding the "F" button toggles between Channel number and Frequency number display.
Jun 17, 2007 | Midland 75-822 40-Channels Handheld CB...
Open Questions:
Computers & Internet Logo
David Payne
David Payne
