Question about Sharp AR-5316 Advanced Digital Imager Copier
Error H4 Sharp photo copier machine model AR 5316 , shows error H4.
  • 1 more comment
  • mathew_gomes Dec 07, 2008
    Thank you the solution was accurate, problem solved
  • 18MISSION Dec 17, 2008
    SHARP AR-5316 error H-4 reset "14" suggestion not working.
  • abcdefhg Mar 01, 2009
    showing h4 in the screen
  • 4,889 Answers
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out andthe LED Display should go blank. If the lights do not go out, thenrepeat step 3 until they do. It may be necessary to increase ordecrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Originally posted by tryit
Posted on Dec 04, 2008
  • eagle338
    eagle338 Dec 07, 2008
    You are welcome. Thanks to try it for the fault reset procedure. Also since the issue is resolved please consider rating it as fixya.
    Thanks,
    Eagle.
Error h4 sharp ar-5316 can you help me ?
H4 indicates "low temperature", possibly caused by a failure of the heater lamp or fuser. Sometimes this error is shown without an actual damage when the power cord is pulled without shutting down the copier first.
To cancel the error code, press [CLEAR], [AUTO], [CLEAR], [AUTO] in rapid succession. The display should go blank. Next, select 14 (clear low temperature code), press [START]. Finally, switch off and on the machine.
If there was no actual damage (i.e. power cord pulled), the machine should be OK again. If the error persists, immediately or after short time of operation, you will need to contact Sharp technical service for repair.
Jan 08, 2011 | Sharp AR-5316 Advanced Digital Imager...
H4 error on sharp ar-5316
H4-00 Heat roller low temperature detection
Nov 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
I have a sharp photocopier AR-5316 flashing error code is h4 how to reset this code and solve the problem
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
Jul 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5316 errors
heat roller low temperature direction
Jun 24, 2010 | Sharp AR-5316 Advanced Digital Imager...
MY PHOTO COPY MACHINE SHARP 2618 SHOWING A CODE H4. HOW I CAN SOLVE IT
You may check the thermostat if its open and if not, then you have a busted heater lamp.
Apr 22, 2010 | Sharp AR-5316 Advanced Digital Imager...
H4 error for ar-5316
Reset the error by pressing [#] [interupt] [ C] [interupt] [1] [4] [start]
If the problem persists check the heater lamp and the thermostat by ohm meter
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR 5316 error H4
The problem is in the fusing unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
If these steps doesn't work you must call an authorized serviceman to check your machine, maybe something is busted on the fusing unit like thermostat or fusing lamp.
Mar 01, 2009 | Sharp AR-5316 Advanced Digital Imager...
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-5316
I am getting a problem code H4 for sharp copier when i start the machine. what is the problem. is ther any solution for the problem of the said model.
Aug 28, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
202 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
