Question about 2wire HomePortal 100W (1000-400026-000) Wireless Router
I want all cmmands of router dx 1821
I want to change my ip address in roter interfase e0
and remove ip address from serial port
and how to give secondary ip address in eternet port
Please send all commands for configur & view of dax
Posted on Sep 18, 2009
C:\Users\Nelson>ipconfig /all Windows IP Configuration Host Name . . . . . . . . . . . . : Dragonlorde Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP...
It does not show as connected. Connect the ISP modem to main uplink port. Then connect pc to any other port. Done! Test it with network cable to pc before trying a wireless device.
Default IP is 192.168.1.1 Use web browser to access. User: Admin Password: password.
There is reset option in the back. Hold it in till it cycles. This will clear all custom settings.
http://www.netgear.com/images/WNR3500Lv2_DS_07Jun1118-5898.pdf
Nov 08, 2012 | NetGear WNR3500L100NAS Rangemax WirelessN...
Cisco router 1841 connected to serial interface
Make sure you set up correctly the subnet mask.
Jul 29, 2008 | Cisco (1841) Router (cisco1841)
I forgot the password for DAX dx 1821 router, how to reset the password for DAX dx 1821 router
With the two wire home portals, you will have to contact your service provider for dsl/fiber to give you the password, you generally will need to provide them with a few different forms of ID, such as your account number, last four of your social security etc...
May 06, 2011 | 2wire HomePortal 100W (1000-400026-000)...
How do i change a password
If you don't have the current password, you will have to press the reset button located next to the power connector port. This will reset it back to factory default settings. The you can access it with your browser:
To access the Web-based management utility:
1 Open your Web browser and enter the IP address of the router into the
Location (for Netscape) or Address (for Internet Explorer) field, then press
Enter. The default IP address of the router is 192.168.0.1
For example, type 192.168.0.1
After the connection is established, the logon screen opens.
2 To log in as an administrator, enter the user name of admin and leave the
password field blank (default), then click OK. The Web management Home
screen opens.
You can download the user manual at:
http://www.retrevo.com/support/Dynex-DX-E401-Routers-manual/id/8352ag821/t/2/
Jan 15, 2011 | Dynex DX-E401 Router
Is there any case that the port from belkin router
This may happen due to double NAT issue.... the DSL modem might give an IP address in the range of belkin route....that is 192.168.2.X check for the ip address when the computer is directly connected to the DSL modem... now check for the IP adress when the Belkin alone is connected to the computer.... if they both give an IP adress like this 192.168.2.X......(X can be any value) then you will face the above issue..... in that case you can login to router and change the IP address of belkin router from 192.168.2.X to 192.168.15.X this will resolve the issue
Apr 15, 2010 | Belkin (F5D7230-4) Router (587009)
How do I assign an IP address with the DYNEX DX-EHB4?
The IP address for your router is normally assigned and manqged by your Internet Provider. They are normally the only ones that have any control over that. This is true for any router, as the Provider has ultimate say and control over IP addresses.
Apr 09, 2010 | Dynex 4-Port Ethernet Broadband Router...
Router port settings guidance
Is there any computer connected to the router ?
If not then connect the computer to the router.
check the IP address and the default gateway of the router.
open the set up page of the router.
there you will find the place to place to open the ports on the router.
Click here for more information about roters and network
Jan 11, 2010 | Computers & Internet
Can not get my xbox to connect to my netgear 614v7 router am using a lan connection but it cant get a IP address from the router any ideas ??
In this regard, I would recommend you to forward certain port no’s on
the Router.
Port numbers: UDP- 88, TCP/UDP- 3074
It is in this context, I would suggest you to please try with the
following troubleshooting steps:
A) Assign static IP and DNS address to the XBOX.
1. Assign IP address as: 192.168.1.50; Subnet mask as: 255.255.255.0
and Default Gateway as: 192.168.1.1
2. Assign Primary DNS Address as: 192.168.1.1 and Secondary DNS
Address as: 4.2.2.2
# Please Contact X-Box Technical Support to assign the Static IP
Address on Your X-Box.
C) Open the ports on the Router using the following steps:
1. Click on Port Forwarding under Advanced.
2. Click on ‘Port Forwarding’ on the left hand column on the screen.
3. On the bottom of the screen, click on ‘Add Custom Service’.
4. Give a name to the service (for example, XBOX1).
5. Select Service Type as UDP and key in the starting port and ending
port as 88.
6. In the Server IP Address specify 192.168.1.50
7. Hit ‘Apply’.
8. Click on 'Wan Setup' Under 'Advanced'.
9. Check the box 'DMZ Server'. Type in the IP Address 192.168.1.50.
Click On 'Apply'.
10. Log Out of the Router Page.
Please repeat Steps 3 – 7 to configure the ports “UDP/TCP 3074”.
Jan 03, 2010 | NetGear WGR614 Wireless Router
Connecting NETGEAR Wireless RouterWPN824 v2 to PC HP2009m tru Comcast Airrs Modem for use by Xbox360 in another room
the Router.
Address as: 4.2.2.2
port as 88.
7. Hit ‘Apply’.
Click On 'Apply'.
Dec 30, 2009 | NetGear RangeMax WPN824 Wireless Router...
Insufficent mtu, but a connection all the way through xbox live
you can go to your routers2_bing.gif website and enter it manually. Type 192.168.1.1 this might be it or try 192.168.2.1 or 192.168.1.100
when it shows your routers info write it down and then put it in your xbox's network by entering it manually. btw the secondary DNS is just 0.0.0.0 if it doesn't give you two. the gateway is just your routers ip address.
what else you can do is do port forwarding.
But the xbox is not a static ip address so it'll change. what you can do is when it says to put your ip address in your xbox put all the numbers the same as the routers ip address BUT DON'T USE THE SAME LAST NUMBER! so like if your routers ip address is 192.168.1.1 you can use 192.168.1.23 i use 192.168.2.15 but you may not have the 2 in yours.
http://portforward.com/english/applications/port_forwarding/XboxLive360/XboxLive360index.htm
a website that'll help
http://support.microsoft.com/kb/908874
list of ports you have to open
any other ?'s email me at mbish1993@yahoo.com
Nov 23, 2009 | Microsoft Xbox 360 Console
2wire HomePortal 100W (1000-400026-000) Wireless Router Logo
301 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
