Question about Lexmark Office Equipment & Supplies
I own a Lexmark 2400. It says align the cartridges has 2 bulls eyes, says print and when I do up comes this option is not available while printer is busy ok help. When I try to cancel out printing it wont do it. Please help me,Alan. Even when I shut everything down and restart the computer, the above is still there.
    President:
  • 1,257 Answers
Soution : Follow the article below and you will be able to delete the print jobs and printer will not show "Printer busy" status
http://helpdeskgeek.com/networking/cannot-delete-print-job/
Posted on Dec 04, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls goto Control Panel, Printers, right click on Lexmark 2400, click on Cancel Print. Do this several times until it no longer shows. Thereafter proceed with the alignment.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
    Guru:
  • 859 Answers
Turn the machine off. Un plug everything, inlcuding the USB cable and open all the access doors you have. Remove power from the supply.
Leave power off for several minutes. Close the covers, reattch power but leave the USB off. Press and Hold Cancel or Reset and then Power On. Keep Cancel or Reset pressed down. See if the printer will go into a diagnostic or maintenance mode.
let us know your results
  • Lexmark Master
  • 6,487 Answers
YOu can try first to unplug the ptinter and remove the cartridges for about 5 minutes and plug it back in, then after that check if you still have the same problem if you still have you can also try to uninstall and reinstall the printer software....
I changed my printer ink cartridges and now it no longer wants to print. It does not give an error message or anything of the sort...please help me out.
  1. Make sure the printer is switched on, the old cartridges are still in the printer, and the cartridge cover is closed.
  2. Click on Start, Programs (XP: All Programs), Lexmark <Printer Name>, Lexmark <Printer Name> Solution Center.
  3. When the Solution Center screen appears, click on the Maintenance button on the left-hand side. (This button is the third from the top and bears a picture of ink drops.)
  4. When you see the Install or obtain a New Cartridge option, click on it once. A pop-up displays a brief description of how to physically remove an old cartridge and install a new one.
  5. Follow these instructions and click Next. The software will prompt you to confirm whether the cartridges are new or old.
  6. For the new cartridge you just inserted, select No, it's new. Important: Make sure the setting for any old cartridge stays on Yes, It is old.
  7. Once your selections have been made, click OK. The program will want to run the alignment for any new cartridges you installed. This applies whether you changed one or both cartridges (in the case of printers that can hold two cartridges). An alignment screen with a red and white bull's eye will appear.
  8. Make sure the cartridge cover is closed and that there is paper in the printer.
  9. Then click the Print button on the alignment screen. A sheet of paper will print from your printer with a series of arrows and numbers on it, with one set of solid bars above them. You should see four groups of lines, unless you have a single cartridge. If you have a single cartridge, you will only have one set of lines.
  10. In each group, locate the arrow that looks the most solid. It may help to circle the number under each arrow you choose as you go along.
  11. On your screen, you will see an area where you can enter the alignment values. When you have identified all the numbers, select those same numbers for each group on your screen, using the up and down arrows next to each value for A, B, C, and D (or A if you have only one cartridge).
  12. When all the numbers have been changed to reflect the chosen numbers on the printed alignment page, click OK. The cartridge installation procedure is complete.
  13. You can now exit from the Solution Center.
Aug 31, 2011 | Lexmark X75 All-In-One InkJet Printer
Paper comes out blank
Please check your ink levels:
1. Click Start > Programs or All Programs > Lexmark 2400 Series 2. Select All-In-One Center 3. Click Maintain/Troubleshoot. 4. Select Device status and ink levels.
If all ink levels are still good, proceed to cleaning the cartridge nozzles.
1. Click Start > Programs or All Programs > Lexmark 2400 Series 2. Select Solution Center. 3. Click Maintenance tab. 4. Select Click to fix horizontal streaks.
Your printer will begin to print, forcing ink through the cartridge nozzles and clean them. Try to print your file again.
Jun 17, 2011 | Lexmark X2470 All-In-One InkJet Printer
Lexmark x2600 alignment page skip
I have this same problem and no solution! (I'm on a Lexmark 2400 and Windows XP.) The problem is how much ink it wastes on one alignment and NO BYPASS option - an ink cartridge is $25, we can't waste it on a USELESS test!!! They're trying to make money but let's not fall for it. We need a way to bypass the ****. Somebody heeelp.
~Sarah K.
May 06, 2010 | Lexmark X2600 InkJet Printer
How do I align ink jets?
Microsoft Windows 95/98/Me:
(Applies to all printers)
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Nov 13, 2009 | Lexmark JetPrinter Z11 InkJet Color...
How do I change the ink cartridge on lexmark x3480
Please use lexmark solution center... here it is:
To install a cartridge using the Solution Center:
Thank you......
Jan 15, 2009 | Lexmark X3480 All-In-One Printer
Printer wont Print after replacing catridges
Source: micksmixxx
-Yahoo Answers
Please tell me if this helped I take no credit as I used the name aboves solution any credit should be give to him
Jan 07, 2009 | Lexmark X125 All-In-One InkJet Printer
How to change lexmark Cartridge
      3. Click OK.
Dec 09, 2008 | Lexmark X1150 All-In-One InkJet Printer
I installed a new Lexmark cartridge for printer 2400, it printed out test page and the cartridge is stuck on the left hand side of printer and will not work. The bulls eye diagram comes up says print...
Try doing "start", "control panel" then "click on printers & fax's", & when you get it open to the "icon" that shows your printer", right click on the printer in use icon, & you get the drop down menu", try clicking on "properties", you should get a "pop up box" with a line saying, "printer is busy", & maybe even written several times, click on & delete all of the lines, if that don't do it right away, turn off & unplug ur power cord until you hear a "noise from ur printer", this is "resetting & releasing it", (probabIy less then a minute, maybe even reboot the PC) printer will not print until you get rid of these "commands", I couldn't be more "precise", on getting the "box", to appear, as it will only "come down & appear", if ur having this problem, hope this helps....Don
Dec 03, 2008 | Lexmark Office Equipment & Supplies
I have replaced both my color and black cartrigages for my x2500 printer, restarted the computer, and it is still giving me an empty cartrigage message
is this a pc or mac?
for windows general make sure you folowed these steps:
      3. Click OK.
Dec 01, 2008 | Lexmark Office Equipment & Supplies
PRINTER
How to Install Cartridges on Printers Using the Lexmark Solution Center ID:ENUS3150 null.gif null.gif null.gif
Oct 22, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
542 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
