Question about Lite On LTN 323 (LTN-323) Internal 32x CD-ROM Drive
CD-ROM will not read any disc
I have a Lite-On CD-ROM that was included with a Dell Dimension Desktop system. Yesterday, I had a DSL connection installed to the computer. The CD-ROM worked fine before, during, and even for a few hours after the installation. All of a sudden, while I was playing a game that requires a disc to run, the CD-ROM stopped reading the disc. I removed the disc and reloaded it; the LED light came on for a few seconds and then went did not sound like it was trying to read the disc. The CD-ROM is shown to be working properly in device manager, and uninstalling/reinstalling/updating the drivers did not change anything. The drive is shown in explorer, but it says that there is no disc. I tried different discs with no change. I don't know what my next step should be, short of replacing the drive. Any help would be greatly appreciated.
  • 168 Answers
Re: CD-ROM will not read any disc
Well try to clean the lens with a clean and dry cotton swab. ir you have a compressed air duster for electronics, use it also. remove the drive and open the cover. look for small like circle glass(lens) clean it. use also the compress air duster by hitting the below parts of the lens assembly to remove accumulated dust and test. if the problem persist, its about time to replace your drive. good luck!
Posted on Feb 07, 2007
0 characters
3 Points
The Samsung CD-Rom SC148A on my Dell Dimension 2400 won't recognize any discs that I insert. Device Manager says there's nothing wrong with it, the driver is up-to-date, troubleshooting provided nothing,...
It might be dirt on the pickup lens, and you can try cleaning it. The best way to do that is to take the drive out, remove the cover and use a cotton swab moistened with lens cleaning solution. The cleaning discs you can buy aren't usually effective. But if you're going to go through all that effort, you may as well just replace the drive. If dirt isn't the problem, the most likely cause is that the laser power has dropped too low for the discs to be read, or the pickup has failed. In that case, you'll need to replace the drive anyway. A new CD-RW/DVD-RW drive is only around $20 (or something equally inexpensive in your local currency), and it's easy to change the drive, so it's really not worth worrying about trying to repair this one.
Feb 01, 2011 | Samsung SC-148 CD-ROM Drive
Hello i want buy solution cd-rom driver..... my
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties you will have options under general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Jan 16, 2011 | Dell (074JH) Internal 48x CD-ROM Drive
Can lite-on-ltn4865 48x play dvd movies
If your Drive is a CD-Rome drive, surely it cant, for the drive cant read dvd disc. Replace the drive of yours with DVD-Rom or DVD-RW in order to play dvd disc, DVD-RW simply has the added capablity to burn on DVD discs
Jan 12, 2011 | Lite On (LTN486S) Internal 48x CD-ROM...
Cd-rom wants to "format" any disc i put in. system is a dell latitude ls.
make sure the cd you have are not CDRW that is a rewrite disc .... buy CD-R check your disc
Dec 24, 2009 | Dell (6T980-A01) CD-ROM Drive
My cd/dvd rom no longer reads or burns
The laser that reads (or "burns") has failed.
Spend $30 to buy a new CD/DVD reader/writer.
Nov 16, 2008 | Compaq Refurbished 7 EVO N410C DVD/CD-RW...
Is cd-rom and dvd-rom different?
CDROM drives can only read CDs while
DVDROM drives can read both CDs and DVDs
If you need further clarification please do contact me.
Sep 24, 2008 | Dell Compact Disc Reader CDR-1900 CD-ROM...
Memory disc in wrong printer slot
When I asked about:
"...took the digital chip out of the camera...put...the disk into a wrong hole and it won't come out."
Don't need to pay for technical assistance like this...Dear rocknroth,
We wanted to find out if you still need a solution for the Dell Latitude CP System Board ( Motherboard 166MHZ ) - 66892 CD-ROM Drive Problem you posted on FixYa yesterday.
In case you do, we'd like to offer you our Premium Assistance Plan
Not even close...
Aug 08, 2008 | Dell Latitude CP System Board (...
Windows could not start
you can use any xp install fresh copy not sure you know someone who could lend you a copy for couple of hours
Feb 20, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Replacing a cd rom drive
put a little jumper lieka blue or green or white cap on soem pins on rear on CS and slide it in. bolt down. put ide cable red or blue edge closest to power socket. carefull with pins pushing it in should look even if looked at from lower angle against cdrom
heres the dell steps manual
Oct 17, 2007 | CD Drives
Lite On LTN 323 (LTN-323) Internal 32x CD-ROM Drive Logo
160 people viewed this question
Top Lite On CD Drives Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a Lite On CD Drive Expert? Answer questions, earn points and help others
