When I run msconfig.exe the program starts but the graphical display for the program never comes up. I can start task manager and see the program has started in the Image Name list. I'm running WinXP Pro w/SP3 and all updatess. Any ideas? gib
  • gibster99 Dec 04, 2008
    I've tried all the solutions you've offered and they still don't help. I have also found that the Windows Home Server console will not open backups for restoring of individual files.
    All items work on my 3 other Windows XP machines here at home. So I know it's something specific to this one. I'll probably end up having to reinstall Windows, but hate the after work of having to reinstall all the applications.
    Thanks for the try.
    gib
    No worries. I'll give the Repair a go and see what happens. I've got all my data on a 2nd harddrive in the system now. So it's just a matter of backing up book marks, e-mail, and copying the program files directory over so I can have access to configuration settings after the reinstall of certain programs.
    I've even tried doing a full restore from Windows Home Server (which worked like a charm) but it didn't solve the problem. I have to assume it's one of the many programs/utilities I've tried over the last year that have caused the problem.
    If the repair funtion doesn't work, I might even give Vista a try.
    Thanks again
    gib
    Guru:
  • 859 Answers
Have you tried using Alt+Tab to cycle through windows as an attempt?
Then, right click the task bar, select cascade windows in case the window is opening off screen.
The only other thing you do is us the system file checker. This requires the XP CD.
from the run command window type:
sfc /scannow
This can take awhile while Windows checks your system files for checksum values.
Regards,
Worldvet
Posted on Dec 04, 2008
  • 2 more comments
  • Glenn Rogers
    Glenn Rogers Dec 04, 2008
    What I would suggest as a next step in the recovery of your machine is this:
    a.) I can assume you've taken all scanning measures for viruses and the like. I take it yoiu have done this and ruled that out. You seem quite capable.
    b.) Instead of a re-installation of Windows, use the Installer to run a Repair process. This is different than the repair console option at boot up with the installer CD..
    To allow Windows to heal itself, way beyond the capacity of the system file checker. Run the installation CD or winnt.exe from its root folder should it be on another partition.
    Allow the installer to run as per usual, including the appearance of a fresh installation. You will get a stop screen. This stop screen Alerts you to the fact that you already have Windows installed. Here you are offered two options. One is Repair the current installation and Two perform a fresh installation. Select the option to Repair the current installation. This choice is one I fall back on quite often as it is remarkably effective. For some reason its abilities beyond what SFC should be able to perform is in the order of 10 fold.
    In fact, it is somewhat disappointing that the System File Checker cannot accomplish what this other option can.
    19 times out of 20 this works wihout fail to recover an installation. Naturally, it is appropriate to run Windows Update manually and see what if anything needs to be downloaded and reinstalled. But this process is quite painless and quick. However, just to be clear, there is always a concern that a failure in hardware could be involved. I just wanted to get that ugly caveat out of the way.
    Lastly, and this is in the face of an utter failure of the Repair Funcion of the Installer, I do resort to a fresh installation, instruct the installer to use the current Windows directory and not format the hard drive (Unless You have reason to suspect a zero sector virus). Even with this final option all user files wil remain intact. However, many techs choose to use a new directory for Windows, recover all user files to a separate hard drive, format and install new. .
    If you have any question or need for reiteration or clarification please ask. I'll be glad to offer myself as a aid in your recovery process. When you respond to these comments we receive an email alert and I will respond as soon as I am able.
    Sorry we couldn't apply a quick fix to your problem.
    Regards,
    Worldvet
  • Glenn Rogers
    Glenn Rogers Dec 05, 2008
    I've seen this repair method solve the most stubborn of all issues. I don't rely on it exclusively. I've had to resort to it on tuff nuts like your problem though.
    It should work perfectly.
    Regards,
    Worldvet
  • Glenn Rogers
    Glenn Rogers Dec 13, 2008
    Microsoft has just released the Beta Preview for Vista SP2. This is one service pack above what is available today.
    I've looked the preview over and it is pretty solid as you'd expect from a point 2 upgrade.
    Wish I could have waved my hand over the keyboard and solved your problem. If you could would you change you vote to Helpful for me? I'd appreciate it and it means a lot when I give it my best effort on a tough problem. I leave most of the easy stuff alone. Its these really unusual problems that interests me. And, as such, when you do discover the fix, which I do believe the Install Repair tool will do, please let me know so I can file that solution away for someone else to benefit from later.
    Best of Holidays,
    Worldvet
  • Glenn Rogers
    Thanks for the rating upgrade. Let me know how it goes. I really do get involved with these problems as if I had your machine here in my shop. I just wish I did have it here. I'd have it back in your hands again and working.
    Worldvet
Win xp laptop won't run programs fro Start menu
Either your system is really corrupted, or you've got a virus. The only think that comes to mind is to go to task manager, find explorer.exe and click End Process, then click File > New Task (Run...) and type explorer.exe. This will reload explorer and possibly fix the issue.
Apr 05, 2014 | Dell Inspiron Computers & Internet
Schedule record application starts automatically in background when system restats
Try this:
Disabling Startup Programs in Windows For some programs, it's smart to have them start with Windows, such as anti-virus and firewall software. However, for most programs, starting them at boot-up just wastes resources and extends startup time. There is a tool installed with Windows, called MSConfig, that allows you to quickly and easily see what's running at startup and disable the programs you prefer to run on our own after startup as needed. This tool is available and can be used to disable startup programs in Windows 7, Vista, and XP.
NOTE: MSConfig can be used to configure several things other than just startup programs, so be careful what you do with it. If you're not sure about using it, just follow the steps in this article and you should be fine.
To run MSConfig, open the Start menu and type "msconfig.exe" (without the quotes) in the Search box. As you type, results display. When you see "msconfig.exe," click on it or press Enter, if it is highlighted.
NOTE: If you are using Windows XP, open the Run dialog box from the Start menu, type "msconfig.exe" in the Open edit box, and click OK.
Click the Startup tab on the System Configuration main window. A list of all the startup programs displays with a check box next to each one. To prevent a program from starting up with Windows, select the check box next to the desired program so there is NO check mark in the box. Click OK once you have made your choices.
A dialog box displays telling you that you may need to restart your computer for the changes to take affect. Click Restart to restart your computer immediately. If are not ready to restart your computer, click Exit without restart.
Aug 26, 2012 | IBM Lenovo ThinkPad L412 Notebook
Cannot find dwtrig20.exe
#1 Press "Ctrl," "Alt" and "Delete" together to open the Task Manager. Click the "Processes" tab to show currently running processes on your computer.
#2 Scroll through the processes window and click "dwtrig20.exe." Click "End Process." If dwtrig20.exe is not a currently running process, move to the next step.
#3 Click the Windows "Start" button and click "Run." Type "msconfig" (without quotes) and press "Enter" to open the System Configuration Utility window.
#4 Click the "Startup" tab. Scroll through and click "dwtrig20.exe" and click "OK." Restart your computer. The program will be removed from startup and will no longer run.
Nov 18, 2010 | Computers & Internet
Ie problem
I know exactly what you are talking about, my sons laptop was doing this last summer and mine began doing it a couple of months ago (I have since reinstalled XP). O was never able to get rid of the problem but I was able to work around it by running task manager and going to Processes find explorer.exe and end task, then go back to Applications click New Tasks and type explorer.exe.
The problem seems to be within the use screen because I had my own user account on my sons pc and my desktop did bot do that.
Hope this helped you.
Jan 14, 2010 | Microsoft Windows XP Professional With...
On my pc not any icon or start menu can be shown only wallpaper can be here
To solve this issue..
1) Click CTRL+ ALT + DEL at a time..
2) You will find Task manager option..
3) From that select process tab..
4) Then select explorer.exe...  And select end process..
5) Then select application tab...
6) And click o new task..
7) In the bar type explorer.exe..
8) Then select ok..
Now the icons will be reloaded.
Jan 02, 2010 | Microsoft Windows XP Professional
Compaq n600c hang problem plz slove my problem
Please give more information Like --
After how much time it hangs?
what OS u r using?
in general answer --
open task manager (pressing CTRL,ALT, DEL keys) this will bring up Windows Task Manger, click on Application, highlight any task that is Not Responding and click on End Task.
Also, to make your CPU boot up faster, I would
click on Start
click on Run
type msconfig.exe (this will open System Configuration Utility box)
click on the Start Up Tab
(you will see several boxes checked under Startup Item). And look for programs that you don't want to launch every single time you log on. (such as Realpayer, yahooMessegner, realsched, etc).
Uncheck the boxes and this will require a reboot. Your computer will bootup a lot faster. These programs you can always open when you want. You can always tell if you have a lot of programs that startup when you turn on your cpu and in the righthand corner, where the time time is at, you see a lot of icons.
Also if you can always open up task manager again, click on Processes, find explorer.exe and kill that process, this closes everything on your screen. dont worry...
then in task manager
click on FIle
New Task Run
and type explorer.exe and click OK
and you will see all your icons pop back up on the screen.
Post reply....
Thanks
Mar 22, 2009 | Compaq EVO N600C (Refurbished) 14.1" LCD...
Desktop view problem
go to new task and make sure you enable Windows Explorer.
Mar 05, 2009 | HP Computers & Internet
Blank screen, can only start programms by task manager
Try to boot Vista into Safe Mode. Tap the F8 Key right after you turn on the computer until you get the Advanced Boot Up Menu
and use the keyboard arrow keys to select Safe Mode. The next screen may ask you to select your operating systm. Select Vista, not the Recovery Console.
Does your task bar and icons appear in safe mode? If so, it might be one of your start up programs that is failing and causing explorer.exe to fail during normal boot-up into Windows and not allowing your taskbar and icons to appear. Click Start and type in msconfig and hit enter then click the Start Up tab and look at all the programs that start up when Vista is starting up. Do Not uncheck anything in the list that you do not recognize as you may uncheck drivers or Vista starting programs that you computer needs to start up Vista properly. Google anything you don't recognize and uncheck any Start Up programs you do not need to start when Vista boots up, like Quicktime player or Adobe Reader for example. (This would also help your boot up time into Vista)
Sounds like explorer.exe crashed. Try opening up the Task Manager again, and Click File > New Task and type in explorer.exe. See if the task bar and your desktop icons appear.
If they appear for a brief moment then disappear again, the Windows explorer.exe is corrupted. Explorer.exe will try to start and then fail again. You may need to use System Restore to bring your computer back to a date and time when the computer was working properly, before the Vista update.
Jan 31, 2009 | Computers & Internet
Display problem
start pc wait a little press and hold ctrl+alt and hit del(delete botton)-at the task manager click file and pick new task ..type control panel ! this is just to load your icons (programes)...try to double click on an icon and see if it responds ..and take it from there to do what you need like uninstalling conflict programes and to check if you have spyware addware viruses !!if you get this message:intenal state of programes are corrupted !!...i do suggest that you try to start pc in safe mode first and see waht happens !!you could try msconfig at first by using task manager or doing it by clicking on run at the start menue and typing msconfig to trouble shoot this problem !!click on start up and stop programes from loading when you start your pc!!this might take sometime if you don't get lucky !!peace
Oct 29, 2008 | Computers & Internet
Explorer.exe won't come up after downloading and installing new software
In my openion, Virus doesn't want to be killed by anti-virus :D You need to download DM2000 (disk manager 2000 of SeaGate) and run it in DOS mode to format Hard-Disk.
Jul 31, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
