Question about Kenmore 17252 Free-standing Dishwasher
Vent cover removal from Kenmore 17252 dishwasher door, for cleaning
Our particular dishwasher model has a circular vent on the inside of the dishwasher door. It was suggested I remove it in order to clean it out, as our dishwasher fails to dry our dishes. Do you know how it is to be removed, as it appears it wants to break when I try POPPING it out. Please advise. Kayzy
  • 2 more comments
  • Kay Stinson Feb 07, 2007
    I am sorry. We removed the kick panel now, and found an empty packet cover. Evidently the installers must have removed the instructions and they are no longer available.
    The particular vent in the door is ciruclar. We tried to remove it but it appears that it will break. We don't know if it is to rotate to be removed, or if it is to POP out.
    Please advise.
    Kayzy
    kayzy12@hotmail.com
  • Todd Hunter Sep 13, 2013
    It rotates and then lifts out. Not easy, but that's how mine comes out.
  • Anonymous Mar 18, 2014
    I've gotten to the shredder housing cannot remove don't want to force removed 2 screws
    Cannot remove shredder cover from dish wash 17533 removed 2 screws don't want to force
    Scholar:
  • 76 Answers
Kayzy If you remove the bottom kick panel you'll find the pouch with technical data on the inside part of it. You will find a complete instruction how to remove the vent. Gendos...post back
Posted on Feb 07, 2007
Vent cover removal kuds301 vbl3
Do I need to remove the inside door to my KUNDS301-VBL, to change out the automatic soap dispenser? Its cover latch does not work. I need to reinstall a new latch cover.
Jan 13, 2013 | Kenmore 17252 Free-standing Dishwasher
When we are running the dishwasher it leaks water onto the floor. What is likely the cause or problem?
could be door seals or you need to take covers off and inspect inside whilst running ... ( DONT TOUCH ANYTHING IF YOU DO THIS)
Feb 26, 2011 | Kenmore 17252 Free-standing Dishwasher
Water standing in tub,already removed cleaned screens,also drain hose is not plugged,can feel spindle spinning on pump out motor.Would impeller be shot??....thanks
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 07, 2010 | Kenmore 17252 Free-standing Dishwasher
Dishwasher will not drain already checked screen and hoses
if you have checked the drain in the bottom of the dishwasher and it is clean, then you have a plumbing problem. maybe try pouring some draino down in the dishwasher to clean out the hoses
Jun 28, 2009 | Kenmore 17252 Free-standing Dishwasher
Kenmore portable dishwasher not working
THERE IS A PLASTIC COVER GRATE IN THE BOTTOM OF THE DISHWASHER TAKES A 1/4 INCH NUT DRIVER TO REMOVE IT, TAKE IT OFF CLEAN OT THE DEBRIS AND FLUSH WITH A BUCKET OF WATER, THIS IS SUPPOSED TO BE THE FILTER, IF ANYTHING IS IN THERE YOU WOULD BE ABLE TO SEE IT, I HAVE FOUND STRAWS AND KNIVES IN SOME DISHWASHERS, HOW THEY GET IN THER IS A MISTORY BUT THEY DO
May 29, 2009 | Kenmore 17252 Free-standing Dishwasher
Water leaks out front
I had exactly the same problem with my Kenmore Ultrawash. I thought the leaking might be coming from the seals around the door, but found that it was leaking from the top as described. I removed the air vent cover on the inside of the door and found that it and the vent area had a great deal of what appeared to be dissolved paper. At first I thought perhaps this was somehow remenents of some kind of air filter, but after reading the post here, came to conclude this was foreign matter. I believe what happended is we at some time washed jars or something with lables on it and this stuff accummulated inside the air vent area. I think in a normal case, when the washer is running, water is mostly stopped from going into the air vent area by the hatched cover, but inevitably some water would get thru. This would be ok normally, because the water would just hit the vent area and probably just fall back into the washer. With all the debris stuck in the vent area and on the cover, I suspect the water was not able to exit the vent area or was hitting the debris and causing the water to jet out the opening to the front - hence the water coming out the vent and pouring down the front. Once I cleaned out the vent area and the cover from the debris, I replaced the cover and ran the washer with no water leaking anymore.
I'm so glad you posted your finding - it gave something to look into, and turned out to be the same source of the problem. You saved me a service call.
May 22, 2009 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore dishwasher not cleaning properly
Look in the inside for any screen that would be easily removed, some dishwashers have a self cleaning filter so you may not find it. I have a lot of other tips for you if your dishwasher is not cleaning so check it out.
http://tclaundryrepair.com/dishwasher
Feb 17, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Soap door won't open
The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. In case it will not solve your problem, the unit should be replaced. Good luck!
Sep 13, 2007 | Kenmore 17252 Free-standing Dishwasher
Kenmore Ultra Wash Quiet Guard
That looks more like the serial number. Check again to confirm the model number.
Sep 09, 2007 | Kenmore 17252 Free-standing Dishwasher
The rinse aid compartment on my Kenmore Portable dishwasher ( Model 17829) leaks and doesn't hold the solution. It seems to have done this for longer then I can remember. What can be the problem?
Sep 21, 2006 | Kenmore 17252 Free-standing Dishwasher
Kenmore 17252 Free-standing Dishwasher Logo
1,453 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
