Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Hey guys I have a pretty interesting one for you. I researched all the convergence issues a few months ago, and new I needed to buy new IC's. I bought the C5AA00000203's from Partstore.com, which were expensive but from what I read, more reliable. I finally got around to replacing the convergence IC's today. I have a friend who is an engineer and I wanted to be sure the soldering was done right. We took the back off the tv, got the old IC's out, and replaced them with the C5AA00000203 Ic's from Part Store.com, I didn't want to skimp on the cheap versions of the chips. We got the old chips out, new chips in, my friend said he did a great job on the soldering, and put everything back. We turned on the set, and it stayed on.... Great sign. I went into the convergence menu and it was all out of whack, as expected, but when it said "red" adjustment,it was adjusting the green cross instead of red. When it said "green" adjustment, it was still adjusting green. So I replaced all the IC's and for whatever reason I cannot adjust red! It's like signals got crossed somewhere. I am totally dumbfounded as to why I can't get to the red adjustment. Any ideas would be HUGELY appreciated, I hope I didn't waste 4 hours and $100. Thanks so much and please let me know ANY ideas of what I can do
  • 1 more comment
  • falltron Dec 04, 2008
    Before I fixed the IC's, I had complete control over the green and blue convergence adjustments, vertically and horizontally. The only convergence I could not control was the red convergence, horizontally. I could move the red convergence vertically, but it was about 1 inch too far to the left. However, the menus were correct for the adjustments, when it said green, it would adjust green, etc. I'm not sure why the menus are all screwy now, I can't even tell if I fixed the red convergence because I can't get into the menu for it.
  • falltron Dec 08, 2008
    Found out what the issue was! Just had the yokes for the red and green switched, tv works perfectly and I couldn't be more pumped that I saved that money!
  • jason May 11, 2010
    did you have the red not moving problem before the new ic replacement ? or after ?
  • Panasonic Master
  • 3,459 Answers
Bad IC is my guess...
On anotehr note convergence is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Posted on Aug 31, 2009
AR5731 Undetected
Dear
The refill guy may done somthing which by pass the CRUM chip. At your end you may check the module attached to the toner cart.and test with alter that chip.
This may solve.
Before doing this pl.check the errorcode display .there might be other related problem with the machine.
Thanks.
Feb 04, 2015 | Office Equipment & Supplies
Mitsu WS-55859---turned off & only powers up for 2 secs
2,2 is short protection.
98% chance the fuse or fuses (there are two 5 amp pico fuses) that protect the convergence circuit are blown. If you find F9AO4 OR F9AO5 on that board check them--if either is open the STK-393-110 DID IT.
Fairly short life for this chip if it was installed correctly and had heat sink compound applied to it--once in a while you get a bad one.
If this has helped you, rate this solution as I do this here for FREE.
sd tech
Nov 19, 2009 | Mitsubishi WS-55859 55" Rear Projection...
I got these problems too...
My kodak easyshare c653 camera is 2.5 years old when suddenly did this a few times then completely refused to turn on at all. Research showed me that this is a firmware issue in Kodak cameras. Kodak will look at it and try to fix it for $70 which is not worth it in my case as I paid $130 for the camera brand new 2.5 years ago. Buying a new camera but not a kodak brand.
Sep 01, 2009 | Kodak EASYSHARE Z1285 Digital Camera
Convergence problem with PT-53TW53... green and blue lines.
I would not do it, I had this issue before and the fix only lasted a few months then it happened again, sorry
Jul 16, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Picture flickers in and out rapidly,gets blurry for about 5sec then looks like new for about 5sec then back again
Did you replaced 2 IC convergence as well or just 2 resitors 3.9 ohms ? if you did replaced 2 IC then you might have probelm in convergence drive it is1 of the PCB mount vertical on the left side from the rear view under part BP95-00415C you need to readjust the convergence by using your remote control just follow in the servive manual
Nov 22, 2008 | Samsung HC-P4752W 47" Rear Projection...
JVC AV_48WP30 Screen loses color, everything is in like negative color
Sounds like shading, caused by convergence IC or bad solder connections in convergence circuit. Check the CONVERGENCE GALLERY for shading.
JVC design is generally reliable. It is extremely unlikely that you would have 2 unrelated failures.
If you are in Canada, email me.
easyab
Oct 27, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence IC`S
Let me know do you have related service manual of Sony KP-57WS500 to guide you further?
Without service manual it would be difficult for you to understand our directions like what to check and where to go in TV etc.
Sep 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Samsung Rear Projection HD tv IC convergence green only messed up now. Help please
To check the pico fuses you're merely testing for continuity. If you get an infinate reading you're in good shape - if it doesn't budge the meter the fuse is open... That's a really easy set to work on for convergence problems - the convergence board is easily removed..
Another cause for mis-alignment like that are the youke return resistors... There are several out front of the convergence amps that may have changed in value. They are 3.9 ohm - 2w resistors and will look identical to Rz123 and Rz124 (same banding). For those simply select a low ohm setting on the meter and check to see if any of them have some way low or way high reading...
Need anything else just ask...
Bill
Dec 09, 2007 | Samsung HCM4216W 42" Rear Projection...
Is this a calibration, convergence, or lens focusing issue?
Did you Change out the Ground Resistors,220 Ohm,3.3Ohm Even if they look Good Change Them
Jul 20, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
