Question about Vehicle Parts & Accessories
2001 buick lesabre alarm system
Frequently, but not always the car will not start after being turned off and locked. the inside lights, headlights and dash lights come on, but will not start. we have tried unlocking with key and only locking it with keyless remote. we have been unable to connect the dots. the alarm light blinks when opening the door, but does not go out after locking the door. is there a way to disable it
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
short shadey
  • 421 Answers
SOURCE: Car Alarm
sounds like the drivers side key switch has failed remove the interior door panel and there will be a switch attached to the back of the key lock cylinder or around there it should be two or three wires also check the door jamb wire harness where the door closes for any broken or damaged wires, use a vot meter and see if you get power or ground to the opposite side of the switch when you use the key to lock and unlock the door if nothing changes and there is power or ground! at this switch i would replace it, i don't think there is one but if the car has a passenger side key hole try to unlock the car from that side and see if you get the same problem -jeff
Posted on Aug 31, 2008
  • 16 Answers
SOURCE: 2001 Grand Am GT interior
a la mejor tiene malos los fusibles o se descompuso la computadora
lo mas probable es que se haya descompuesto la computadora del auto
Posted on Sep 02, 2008
SOURCE: Alarm haywire, can't override anti-theft system or turn on car
The Alarm on my Mercedes ML320 sounded every night, then it started doing it more often, Showed it to the dealer he says it's the 'Tow Sensor', that needs to be repaced. $700, down the drain. I have already started hating this car, it eats $500-600, every 6 months...
Posted on Jan 27, 2009
emissionwiz
  • 77169 Answers
SOURCE: Drivers power lock will not unlock with remote.
the door lock actuator is defective, they get really hard to move when they go bad, that is why the difficulty with the key.
Posted on Mar 31, 2009
  • 47 Answers
SOURCE: Disable or disconnect the factory installed alarm
should be a fuse for it, just remove it......
Posted on Jul 07, 2009
Car will do nothing. as if the battery wasnt hooked up. has new battery. no lights. NOTHING
2001 Buick Lesabre: Car Will Not Start Does Nothing Took ...
www.2carpros.com/questions/buick-lesabre-2001-buick-lesabre
Apr 22, 2007 - Car will not start does nothing took battery out to get tested because it would not jump start battery found to be good put battery back in ...
how to fix a buick century that wont crank - YouTube
? 2:44
https://www.youtube.com/watch?v=UWfvEouMMtc
Dec 18, 2009 - Uploaded by jay eltatertoto
how to fix a buick century that wont crank. jay eltatertoto ... How to easily fix a Buick that will not crank and security light flashing - Duration: 6:06. ... My Car Wont Turn Over - How To Test The Starter / NSS / Ignition Switch - Duration: 5:21. ... 2001 BuickCentury Custom - Duration: 19:44. uxwbill 19,621 views.
Car Won't Start Because of Anti-Theft System That Uses ...
repairpal.com > Problems > Buick > LeSabre
Feb 05, 2016 | 2001 Buick LeSabre
2001 buick lesabre know inside lights work checked fuses all or good
You may have a bad light switch does the dash lights work win you turn on the switch or is every thing off
Nov 08, 2014 | 2001 Buick LeSabre
Can headlights be turned off during day?
no they can't you can try depressing the parking brake just one click so the brake light comes on this usally will over ride the daytime running lights and will not ingage the brake seeing it is only one click. good luck
Mar 26, 2010 | 2001 Buick LeSabre
2001Buick LeSabre parking light
On top of the headlight housing are two large knurled black plastic knobs.Unscrew them counter-clockwise.Now the whole headlight housing may be removed. Set it on the bumper and you'll have easy access to the marker light.
Nov 12, 2009 | 2001 Buick LeSabre
Trouble Starting 98 Buick LeSabre
Read your comment on 8/18...Kzactly what I thought. always look at the basics...more times than not, you will find problems there, and , by checking, you eliminate false readings when doing other tests.
Aug 16, 2009 | 1998 Buick LeSabre
2001 Buick LeSabre. How to remove headlight assembly... Just need to remove and replace the headlight assembly on my 2001 LeSabre Custom. I think it's just a matter of removing a couple of bolts, but would...
the bolts you are looking to remove are located on the top of the light housing. It only takes 2 of them to remove the housing. One is about 6 to 8 inches long, and the other one is much shorter than that. Just unscrew and remove them, and pull the housing straight out.
Jul 19, 2009 | 2001 Buick LeSabre
Not start condition
turn the key in the door lock a couple of times. this should reset the alarm. try the trunk also
Oct 09, 2008 | 2000 Buick LeSabre
Vehicle Parts & Accessories Logo
232 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
