Question about Garmin GPS
I got a garmin nuvi 660 online on ebay there is a pass word in place dont no how to reset ? the owner said he did not put one in place . i first turned it on useing my computer some other people said that is why the pass word kiked in . is there a way to fix it ?
  • 4 more comments
  • ryan blanar Dec 04, 2008
    it is the 4 digit anti theft password. i called garmin and they said they would not rest the password because i was not the first owner.
    i did that and it dosnt work. and its bottom right. please help
    i pressed on the lower right bottom the screen appeared i hit yes and all factory settings are reset but the password lock is still there.
    i tryed that and the password lock is still there
    that wont work because i tryed to return it and emailed him about 20 times he wont respond to me any more . can i put it in my name and send it in ?
    it acquires the satellites from procedures 1 throw 5 the computer found the garmin on the usb port but the software loader for the up dates cant find the drive letter.
  • 65 Answers
Unfortunately, This is an anti-theft feature which means it is not designed to be easily defeated. The manual suggests that a deliberate action is required in order to set this feature. It is not likely that connecting it to a computer would cause this problem.
Therefore, one must deduce that the device is stolen. I would suggest that you contact ebay and maybe paypal if you used them about a possible refund and to report the individual who sold it to you. Sorry to be the bearer of bad news here. I hope you find this solution helpful.
Posted on Dec 04, 2008
  • 4,889 Answers
Hi, did you try resetting the device from Maintenance mode? This is what garmin dudes do to reset the device. Try it out I'm positive it works.
Here is the video
    Genius:
  • 1,011 Answers
Sir,
The Nuvi also comes with a security feature that allows you to enter a four digit password to lock/unlock the unit prior to using it. In the unlikely event your unit is stolen, not having the pin would render the unit useless. Furthermore, you can also set up a security location if you forget your pin. You can either use your home address or the parking lot of a nearby 7-11 etc. If you forget your pin, just drive to the 7-11, and the unit unlocks itself. Or, if you used your home as your security location, the unit automatically unlocks
good luck
    Sergeant:
    Champion:
  • 334 Answers
In order for this to have saved memory it has to have a power source inside to save the memory. If you could access a schematic you could find this power source and disconnect. This inturn would reset the whole system.
    Scholar:
  • 81 Answers
Try this.... 1.- Power off the GPS
2.- Press and hold the right bottom corner
3.- Power on
4.- System asks if you are sure to delete all custom data and setting.
5.- If you answer "yes" next screen looks like brand new device
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
To my understanding you actually have two concerns; not only would the lock code be needed but the the Garmin Nuvi 660 must actually be in a certain location termed as "security location". The unit will verify against its programming if the said certain location is the same as the one it has been set to as its "security location". It will make use of the received sat signals to compare.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • 837 Answers
1) Call the seller on ebay.
2) Get the password from the seller.
3) Enter the password.
4) DONE
If #2 doesn't happen .. Your Garmin is stolen
1) Contact Ebay - note seller name, etc.
2) Money and time lost
    President:
  • 2,110 Answers
To reset do following ...
Procedure 1:
Try to turn the NUVI off and then ON again. Flip the antenna and see if it acquires satellites after a couple of minutes.
Procedure 2:
If 1 didn't work then try a soft reset. Press the reset button at the back of the NUVI (behind the satellite antena) and see if it acquires satellites after 2 minutes
Procedure 3:
If 2 didn't work, then try another reset. This time:
a- Turn off the NUVI
b- Keep the Power Button pressed for about 2-3 minutes. You will see a message indicating Pre-Boot. Keep the button pressed until you see the word LOADER. Release the power button and let it load the software again. After the software is loaded check to see if it acquires satellites after 2 minutes.
Procedure 4:
If 3 didn't work, then try a hard reset. This time:
b- With one hand keep pressing the lower right hand side of the screen. With the other hand press the power button.
c- When the NUVI screen turns on, release the power button, but keep holding the lower right hand side of the screen.
d- A screen will come up indicating if it should erase all user data. Click YES
e- It will take you to the screens to select the language and time zone. Choose accordingly.
f- After the software is reloaded check and see if it acquires satellites.
Procedure 5:
If procedure 4 doesn't work, try to load the updated software. To do this follow this link:
http://www.garmin.com/support/collection.jsp?product=010-00540-00
    Top Expert:
  • Garmin Master
  • 78,936 Answers
My friend you are flat out of luck.
  • yadayada
    yadayada Dec 04, 2008
    Here is a brain storm ask the seller for the security code! if he doesn't have it file a complaint with ebay or paypal if you used them, it is most likely stolen, happens on ebay all the time.
    Genius:
  • 1,239 Answers
HI I finally found the ones that work. the directions are:
you need to touch the screen right above and below the white box that says "input ID Code" in this order and I guarantee it will work.
Right up, left up, left down, left up, right up, left up
Enjoy
  • ABHISHEK.C
    ABHISHEK.C Dec 04, 2008
    1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
  • ABHISHEK.C
    Main support number1-800-800-1020
  • Garmin Master
  • 6,487 Answers
The only way that you can unlock this is to let the original owner to contact Garmin so they will unlock the unit since they will only unlock it if the original owner will contact them....
    Sergeant:
  • 217 Answers
Page 4 of the 660 User manual shows how to reset the Nuvi. Disconnect any power from the Nuvi. Flip up the antenna. Behind the antenna is a reset button, press it. Connect it to power again. The Nuvi should reboot.
  • llincon Dec 04, 2008
    Maintenance Mode:
    Step 1. Turn your Nuvi unit off, remove any SD cards from the SD card slot and make sure that the unit is not plugged into any computer.
    Step 2. Place a fingertip on the upper left hand corner of the touch screen and keep it there while turning the unit on, a prompt should read " Do you really want to start in maintenance mode?"
    Step 3. Select the yes button.
    Step 4. Enter your PIN if enabled.
    Step 5. Main Maintenance Mode screen should have 4 selections:
                            System information
                            View Diagnostics
                           Clear User data
                            Clear Waypoints
    Step 6. After some selections the unit should reboot and you check to verify unit after rebooting.
    click this link for all the trouble shooting information
    http://gpsinformation.info/nuvi/660/660....
  • 4,806 Answers
Hold your finger on the lower right corner of the nuvi screen while you turn on your nuvi, keep your finger pressed until a pop-up screen appears
Touch "yes" and all factory settings will be restored
kind regards
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Dec 04, 2008
    disconnect the nuvi from external power, flip up the GPS antenna (the flap in the middle) and hit the reset button.
    Connect it back to a power source and it should operate properly
    regards
  • Lee Hodgson
    if you still can't reset the garmin, contact Paypal and claim your money back or you can try register it in your name and send it to garmin for them to sort.
    There might be a price for that though
    regards
  • Lee Hodgson
    I'm sorry to have to tell you this ryan, but according to the user manual you have no choice but to send it into garmin for the 4 digit code to be wiped, if i were you i would contact paypal and get your money back because the item is not as described, it could well be stolen!!!!
    regards
  • 395 Answers
If it's similar to other nuvis, just press on the upper right side of screen and then power on the unit while continuing to press on the upper right of the screen. It will prompt you to clear all user data...click on 'Yes'
    Scholar:
  • 149 Answers
Assuming that its the 4 digit anti theft password the manual says that you have to send it back to the manufacturers to get it reset
heres the manual
http://www8.garmin.com/manuals/nuvi660_ownersmanual.pdf
    Genius:
  • 3,422 Answers
HI,
Yes you can reset thus by holding the power button for 1 min.
I will also let you know the procedure for hard reset
  • Priya darshan Dec 04, 2008
    Please click on the below link to view the manual for your model and refer the page no.4.You will see all the steps to reset your nuvi with the picture.
    http://www8.garmin.com/manuals/nuvi660_o...
    Here are the steps.You can also view the manual for these steps and for the picture.
    1)Disconnect your nuvi from external power
    2)Flip up the GPS antenna
    3)Press the reset button
    4)Connect the nuvi to power source.The nuvi should turn on automatically.
My garmin nuvi 660 is frozen . how can I do?
Reset the nuvi 660:
1 Disconnect from external power.
2 Flip antenna up.
3 Locate and press small button labeled "RESET" in the antenna recess on rear of nuvi 660.
4 Connect to external power source.
The nuvi will reset, power up and operate normally. If this was helpful, please rate it 4 thumbs up - thanks & good luck!
Sep 20, 2011 | Garmin Nuvi 660 GPS Receiver
How to reset pin#
Resetting Your nuvi
Depending on your nüvi model, you can reset your nüvi by pushing the reSet button on the bottom of the unit.
CaUtion: Do not reset your nüvi with a ballpoint pen or other sharp object, which can damage the unit or the battery.
If your nuvi does not have a reSet button, slide the Power key to the on/off position and hold it for 8 seconds.
Apr 08, 2011 | Garmin nuvi 205W GPS Receiver
Where can I find an internal speaker for a Garmin Nuvi 660
Hi
Depends which country you are in but i would try
radio shack, maplin, farnell or even have a look on ebay.
Please dont forget to vote if you liked my answer
many thanks
Feb 13, 2011 | Garmin Nuvi 660 GPS Receiver
How do i get a new ribbon that runs from the main board to the viewing screen of the garmin nuvi 660
Typically this would need to come from Garmin or one of their manufacturing partners but sometimes one can find parts on Ebay.com.
Mar 25, 2010 | Garmin Nuvi 660 GPS Receiver
I need to update my garmen nuvi 660- How do I do that?
Go o Garmin.com and upload new maps. They run between $60-$99. Ive tried finding drivers to by-pass and get new maps but garmin scrambles the codes. Hope this helps
Nov 06, 2009 | Garmin Nuvi 660 GPS Receiver
Forgot pin number to my nuvi 660
Please see this article on the subject
http://www.fixya.com/support/r1121296-lost_pin_garmin_lock_nuvi_series
Feb 02, 2009 | Garmin Nuvi 660 GPS Receiver
No unlock code for Garmin Nuvi 660
Sorry but that is a security feature. There is a chance you've purchased a stolen unit from ebay. Unfortunately, only Garmin can unlock it and they will require a receipt from a Garmin dealer.
Jan 10, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660
Owners can select a pin code to use which locks the unit preventing use by theives. Sat Nav theft is a big market. The unit needs to be sent to Garmin who will verify you are the registered owner and unlock it for you. If you bought at a market is there a good chance it may have been stolen?
Sep 18, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 650 unlocking
If you are the legitimate owner, you can send your unit back to Garmin to be unlocked. Be prepared to provide rock-solid proof of ownership because Garmin has a program that prevents stolen units from ever working again. It's one of the reasons that I purchased it. As word gets out that you cannot unlock a stolen unit, thieves will be deterred from stealing them in the first place. And if you try to open the unit to see if there is any easy jumper or something, you will permanently destroy it.
Jun 23, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
29 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
