Cannot adjust resolution from HP laptop. 1920x1200 can be panned through the 1024x768 window, but the e540 will not reset to higher resolution. Computer fine with nearly identical HP 1120 monitor. Sony cpd-e540 works ok on other computers. What the heck is going on? Can i use a driver to overide the plug/play? how to driver get for ATI x1300 & the e540?
SOURCE: Installing this PDA on Windows Vista Home Premium laptop
you shouldnt need a device driver for your pda to work along side with Vista, as Vista has it's own Windows mobile device centre which should run as soon as you connect your pda to a usb port. If it doesnt run, then open up windows mobile device centre in programmes and check the mobile device settings as to whether usb is set to connect to the centre.
SOURCE: Sony Vaio PCG-TR3A, Blue Screen states cannot find operating syst
There should be a factory image on the HD when you try restarting it. Hold down the F8 key or F10 key while its rebooting this should start the recovery process you shouldnt need a windows disk.
SOURCE: Sony Vaio PCG-K23 LCD Monitor will work with
hook the laptop back up to the external monitor, once it boots and has settled, I would like you to hold down the Fn key which should be at the lower left of the keyboard and tap the F7 key. This will toggle the video output from external to internal or both at the same time. I have never heard of an issue where Ubuntu will allow a video signal, but now windows. I hope this works for you.
SOURCE: Bose Companion 2 Speakers won't work with Sony Vio Laptop
i have bose computer speakers that i thought wouldnt work on my laptop at first but after playing around with it i can only get the left speaker which doesnt have any red or white plugs to mess with just the direct line that goes into the headphone input on my laptop. i have a ibook g4. is there any way to get the other one to work also because that speaker has all the controls and this isnt half as lound as it was when it was connected to my regular comp.
