My epson c90 cant print
Hi!my problem is my epson printer cant print....i changed all the cartridge but the orange button still blinking..wat do u think the problem?
    Problem Solver:
  • 18 Answers
Make sure all of the drivers are installed. also make sure that the print memory is empty because it was probly printing when you ran out of ink,and could still be waiting to finish.
Posted on Dec 31, 2008
I changed the cartridges in my epson cx5500 but its still not working
Problem with the Epson Stylus CX5000 InkJet Photo Printer
i changed the cartridges in my epson cx5500 but its still not working
Hi Good day!! is there any error message? or Blinking orange/red in your printer? if no errors try to restart your printer spooler.
Follow this method:
1. Turn off your printer and then trun it back on see your printer status if it is online and ready.
2. Click "Start"
3. Click "Setting"
4. Click "Control Panel"
5. Choose "Performance and Maintenance"
6. Click "Administrative tools"
7. Click "Services" now you should be on Services box
8. in Services box find "Print Spooler" Click it and then click "stop" at the upper left of the box and then start it again.. hope it works now..
Oct 19, 2010 | Epson Stylus CX5000 InkJet Photo Printer
Brand New Edible ink cartridge not working on brand new Epson C90
Hmmm 4 this problem you can take the cartridge out and reinstall the software and then put the cartridge back
Jan 24, 2010 | Canon PIXMA IP3500 Photo Inkjet Printer
My epson stylus C90 will not print, red light and green light bling on/off continuously
YOU NEED TO DISABLE THE INK LEVEL MONITORS AFTER RE-FILLING THE CARTRIDGES. GO TO PROPERTIES, MAINTENANCE, VIEW PRINTER STATUS, OPTION AND CLICK ENABLE STATUS MONITOR ONCE.
Jan 16, 2010 | Epson Stylus C86 InkJet Printer
My printer has a new ink cartridge but does not recognize the ink
What model printer do you have and can you list the print cartridge?
Also have you selected on the onboard printer menu that you have inserted a new cartridge?
Jul 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
EPSON STYLUS C90 CISS INCOMPATIBLE CARTRIDGE!!
The cartridge may be defective, as I seen this numerous times, try buying another cartridge from a diffrent retailer and make sure the tape is removed before installing the cartridge.
If this works, you can contact Epson if it is there OEM cartridge that is defective for a refund or replacement.
Good Luck.
Feb 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson c90
HAVE YOU CHANGED THE CARTRIDGE
Feb 14, 2009 | Epson CX8400 All-In-One InkJet Printer
I cant print
is its a canon the ink collector is full get it serviced
better yet buy a new printer.
Dec 03, 2008 | Computers & Internet
I dont know how...
Unraqr the c90.rar file and copy the extraction to any folder on your hard disk (for future frequent use).
The following only works after refilling the cartridges or using a continuous ink system.
Note: This is for the Epson C90; there are a lot more printer specific resetters. Mine is Indonesian.
Note: This does NOT work if the system date is NOT set at July 15, 2007 !!
1. Set the system date to July 15, 2007.
2. Go to MY COMPUTER, open local disk C: then delete the ADJUSTMENT PROGRAM FOLDER (if present)
3. Close local disk
4. Click START, RUN, type REGEDIT
4. Open HKEY LOCAL MACHINE
5. Open Software folder
6. Open Epson folder
7. Delete PTSG folder (right click, remove=yes)
8. Open Epson C90 Resetter folder and start adjprog
9. Click ACCEPT button
10. Click SELECT button to go to port menu. Selected designated port number (USB ...)
11. Click the "Particular Adjustment Mode" button
12. Double click the "Waste Ink pad Counter"
13. Click the "Check" button
14. Click the "Initialization" button.
15. Turn of the printer and press "OK"
16. Turn on the printer and wait until the maintenance procedure has finished
17. Close the panels of the Adjustment program
18. Reset the date to the current date.
Note: Print these steps for future use.
Note: With a continuous ink system, make sure that the ink filling cable is not to tight; the print head with the attached ink
cabling must be able to freely move all the way to the left inside the printer. Also make sure that none of the ink tubes is squeezed tight by the black plastic clamps that are used to attach the system to the outside (front) of your C90. Place them so that the transparent cover stays slightly open.
Note: With a continuous ink system, be sure to use the "lock roller" on the ink system to close the ink supply when the printer is not in use; otherwise your ink evaporates.
Note: The continuous ink system is quite erratic in its signalling: when one of the colors is about 1/3 full on the Epson monitor, the printer might stop suddenly and display the cartridge X signal. Sometimes, with 2 colors X-ed, you have to do the procedure twice!
I don't know where you got the C90.rar download. You must have the following files:
AdjProg.exe
Apdadrv.dll
EditText.dat
StrGene.dll
If you don't have them all or miss some, pls e-mail me (hanshufkens@yahoo.com) and I'll sent them to you (attachment is about 2 MB)
Last: The C90 is a **** printer. After 4 months of use the paper adjustment goes to hell, so with printing you never know if printing will start before the paper is properly loaded. Might as well buy a new printer (NOT Epson!).
Jul 23, 2008 | Epson AcuLaser C900 Printer
PRINTER LIGHTS BLINKING RED THEN GREEN
Either you have ran out of an ink, because some epsons wont run until you replace cartridge, you have a document pending a print, or you need to disconnect printer, uninstall drivers from Add/emove programmes. Re-install driver then re connect printer when prompted
Nov 10, 2006 | Epson Stylus Color 760 InkJet Printer
Computers & Internet Logo
87 people viewed this question
David Payne
David Payne
