Question about Belkin Wireless Cable/DSL Gateway Router
NEW BELKIN WI FI CABLE ROUTER NOT WORKING AFTER 4 DAYS OF USAGE
After buying a refurb PC to be base station for WIFI network I connectedBelkin Cable Router - all worked fine for 4 days until last night. Tried to access internet this a.m. = error message website unavailable. Did the Cable Modem re boot - no good. Have switched router off and back on - no good.Now working on internet as stand alone PC is connected to Cable modem direct without router. ANY SUGGESTIONS - Apart from return Router to retailer?
  • 624 Answers
I would try a hard reset of the router to reinstall the original settings. Then reconfigure and test again. If ther is no change then as you probably suspect the router has failed. Let us know if you have any other questions and please don't forget to rate this posting.
Posted on Feb 06, 2007
How to connect a rca thomson router to wifi
You are trying to connect to a modem, not a router, the router, a wi-fi version, is what you are connecting to your network.
First, power off all equipment, computer and modem, use the network cable you have connected to your computer from this modem and disconnect from the computer, connect it to the differently colored port on one end of the Belkin, the others have numbers, connect a network cable from one of the numbered ports to the computer.
Now power on the RCA modem, wait until lights are steady, then turn on the new Belkin router, wait until lights are active, just a few moments, then power on your computer, you should now have internet access and be able to locate the manual from the Belkin's website to further your setting up a passphrase or setting up some security on your wi-fi.
Jun 14, 2014 | Thomson Rca / Digital Broadband Modem...
Wireless router configuration
If you don't already have a wireless network, you can use an AirPort base station to create one. To configure an AirPort base station, you connect the Ethernet connection to the WAN port on the base station. In turn, the base station creates a Wi-Fi (wireless) connection to the Internet. Consult the documentation for your AirPort base station for more information on how to set up your wireless connection. Once you have a Wi-Fi network available, use these steps to tell your Mac to join it:
  1. Click the Wi-Fi menu icon airport_symbol.png and select your Wi-Fi network from the list of available networks.
  2. If prompted, enter the password for your Wi-Fi network.
  3. Check "Remember this network" to have your Mac automatically join your home network.
Mar 03, 2014 | ASUS Us Rtn53 Dual Band Wireless Router...
Can't connect iPhone 5s and hp 1220c
Sir/Madam
iOS: Troubleshooting Wi-Fi networks and connections Symptoms This Issue is Related To Your apple Mobile And Make Sure You Already Install HP Printer Software In Your Desktop or Laptop. If yes I suggest you perform below Solution for Your Apple 5s and HP Priter Connectivity Issue:
Learn how to troubleshoot WiFi.Issues you may encounter while using your iPhone, iPad, or iPod touch.
Resolution Occasionally while using your iOS device, you may notice unexpected Wi-Fi behavior: Difficulty locating or connecting to a network
Unexpected Wi-Fi signal strength or disconnects
Inability to access the Internet
Not automatically connecting to WiFi when expected
Follow these steps to troubleshoot the above issues:
1.Be sure you're in range of your Wi-Fi router (access point).
2.TapSettings WiFiand turn WiFi off and on. If your Wi-Fi setting is dimmed,follow these steps.
1.Confirm that your Wi-Fi router and cable or DSL modem are connected to power, turned on, and connected to the Internet. If not, refer to your network administrator or Internet service provider (ISP) for assistance.
2.Restart your iOS device.
3.Tap Settings WiFi and locate the WiFi network to which you're connected.
4.Tap and Forget this Network.
5.Try to connect to your desired Wi-Fi network.
Note: You may need to enter your Wi-Fi password again if your network requires one.
6.Turn your Wi-Fi router off and on. If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
7.Update your deviceto the latest version of software.
8.Update your Wi-Fi router to the latest firmware. For AirPort Base Stations,install updates using the AirPort Utility.
If the issue is still unresolved Follow the steps below for the issue you're experiencing.
Collapse All'Expand All
Unable to locate a Wi-Fi network
Unable to connect to a Wi-Fi network
WiFi disconnects or signal strength is less than expected
Unable to access the Internet while connected to Wi-Fi
Unable to automatically connect to Wi-Fi
Additional Information Find information onconnecting to a Wi-Fi network.
Some third-party routers may not be compatible with all iOS devices, even after updating to the latest firmware. If your iOS devices can successfully connect to other Wi-Fi networks, contact your router's manufacturer to ensure that your router is compatible with your iOS device.
See recommended settings forconfiguring your Wi-Fi router for use with iOS devices.
Notes
1.iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models supportWLAN.
2.If needed, please consult with your network administrator (which may be your Internet Service Provider) for assistance with this step.
3.iPhone 5, iPad devices, and iPod touch (5th generation) are the only iOS devices that can connect to 5 GHz networks.
If You Still Haveing Problem then Visit official Below Apple Website URL Link:
http://support.apple.com/kb/ts1398
Or
In case you still having HP Printer Issue Then Follow Us On:
HP Printer Support
Feb 12, 2014 | HP DeskJet 1220c InkJet Printer
Enter client device pin
The client device PIN is a WPS method to connect to the network
I would suggest you disable the WPS feature and go with standard WPA or WEP
To get the PIN :
Turn off / Disable wifi in the laptop
  1. - Hardwire the computer and router
  1. - Open the router setup page ( http://192.168.2.1 )
  1. - Click wi fi Protected setup on the left side
  1. - Scroll down a little and you can find the router PIN
  1. - This is the number that you need to enter in the device
To Enable WPA Security in the wireless network
  1. - Leave the password blank and click submit
  1. - Disable Wi Fi Protected setup at the top and click Apply Changes
  1. - Click Security under wireless on the left side
  1. - Change the security mode to WPA
  1. - Type a password
  1. - Save the changes.
Dec 17, 2013 | Belkin F5D8631-4 Router (F5D8631au4A)
I am trying to change the ssid to something more sensible (i.e., "myname network") as there are numerous wifi networks locally. But when I "apply changes" the update appears to be working for the duration...
You are changing the ssid so if you are using wireless you will lose the wi fi connection and would need to disconnect wi fi and then search wi fi networks for the new ssid and then connect to it.
you could connect by ethernet cable till you get it right .
Nov 07, 2017 | Belkin N600 DB Wireless Dual Band N Router
My iphone does not work on w.i.f.i. or 3g, my friend has a camera set up and can only view the pictures on my iphone when my router is switched on
You can manipulate iPhone's settings to refresh flaky network connections, or reinstate lost ones, while physically moving closer to a Wi-Fi base station when needed. You can also improve your Wi-Fi base station or wifi router performance to overcome typical Wi-Fi issues.
Jun 16, 2012 | Computers & Internet
How to connect to the wifi with 3g iphone
Hello Jane,
When using a Wi-Fi network with your iPhone, you may occasionally encounter the following issues,Unable to locate or join a nearby Wi-Fi network,Weak or low Wi-Fi signal strength,Connected to Wi-Fi network, but unable to access the Internet.
Tap Settings > Wi-Fi and turn Wi-Fi off and then on again. Verify that you are in range of your Wi-Fi router or base station. Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on. Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet. Update your Wi-Fi router to the latest firmware.
Jun 03, 2011 | Lands Phones
The router is blinking a yellow light
Here are some of the more common reasons that the status light may blink amber:
  • The Wi-Fi base station has not yet been configured because it is new.
  • The Wi-Fi base station has been reset.
  • A new firmware update is available for the Wi-Fi base station.
  • No IP address is available for the Wi-Fi base station.
  • A Wi-Fi base station in Extended Mode is out-of-network Wi-Fi range of a primary Wi-Fi base station.
  • The WAN Ethernet cable is unplugged from the Wi-Fi base station.
  • The Wi-Fi base station lacks a path to the Internet (or local router).
  • Internet access may be temporarily unavailable from your Internet Service Provider (ISP).
  • Your AirPort Time Capsule has detected that the internal hard drive has reported a SMART error, and is failing (This requires firmware 7.5.2, and AirPort Utility 5.5.2).
Feb 10, 2011 | Apple AirPort Extreme Router
Setup belkin wireless network
1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
Thanks for using Fixya
Proton
Oct 04, 2010 | Computers & Internet
WLAN orange light blinking
Wi-Fi base station: Understanding and resolving a blinking amber status light Your Wi-Fi base station status light blinks amber.
A persistent, blinking, amber status light indicates that your Wi-Fi base station may require your attention.
How to resolve a blinking amber status light alert
Launch AirPort Utility to determine why your Wi-Fi base station status light is blinking amber.
Apple recommends that you use AirPort Utility 5.5.2 for Mac, AirPort Utility 5.5.2 for Windows, or a newer version of AirPort Utility if one is available.
  1. AirPort Utility 5.2 or later opens automatically if your Wi-Fi base station requires your attention. You may also choose to launch AirPort Utility at any time.
    Do not use any version of AirPort Utility earlier than 5.0.
    In Mac OS X, AirPort Utility is located in the Applications > Utilities folder.
    In Microsoft Windows, AirPort Utility can be located by clicking Start > All Programs > AirPort.
    Note: You may also locate and download the latest Wi-Fi base station firmware and software by clicking here.
  2. In the AirPort Utility window, locate your Wi-Fi base station and double-click on it to open the Summary window. Note: If you have more than one Wi-Fi base station, double-click on the icon for the Wi-Fi base station that has the amber circle next to it.
  3. When the Summary window appears, double-click the amber circle to the right of Wi-Fi base station Status to open the Status window.
  4. The Status window lists any conditions that require your attention. Respond to each item until there are no more items listed.
    Important
    : You must reset the Wi-Fi base station using the reset switch to re-enable checking for the conditions you ignored.
  5. Eliminating the blinking, amber status light may require making changes to a specific setting, or putting a checkmark in the "Ignore" checkbox beside any option you don't wish to change. A checkmark simply tells the AirPort that you are aware of the issue and you have chosen to ignore it. For example, you may wish to leave your AirPort open without a password so that anyone can join your wireless network.
  6. Click Update to apply your changes (the Wi-Fi base station will restart).
  7. After the Wi-Fi base station has restarted, the status light should be green and not blinking. If the status light stays amber in color and blinks after the Wi-Fi base station restarts, you may repeat the steps above.
Oct 03, 2017 | D-Link (DI-784) Wireless Router
Belkin Wireless Cable/DSL Gateway Router Logo
90 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
