If it has the automatic trans you need to pull the rod on the rear of the machine that if for free wheeling the machine
Have had this mower for years and have moved it around by pulling disengaement rod but for some reason now it will not disengage the drive, have tried adjusting the rod but still the same, have backed off the brake still will not move. Have checked the key way on both axels and no problem. Also checked the fluids and they are right where they are suppose to be. Any other suggestions as seem to have checked every thing possable so far.
are you sure the rod is hooked p and didn't fall off
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
SOURCE: Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
Pulled the rod with the same results. Have tried adjusting the linkage and still will not roll free, checked the key way on the axel and no problem there. Have backed off the brake and it still does the same thing. What else can I try?
rod is hooked up and the lever it turns on transmission turns to disengage the drive seems to be working properly
when moving the rod does it change the resistance it takes to push it?
