Question about Samsung SC-D33 Mini DV Digital Camcorder
Samsung mini DV sc-D366 always displays eject
Every time I try to rewind, fast forward or record on my camcorder the screen displays eject and I have to remove the tape and re-insert it. It will run for a couple of seconds and then say eject again. I cannot record or play back anything.
  • Anonymous Jan 14, 2009
    I have that problem too...only record on Sd memory, when I try to use the tape a "D" next to the eject symbol appears blinking on screen...I read quang's solution and I wonder...
    Do this repair really worth the money instead of buying another camera?..., if there's no warranty, I mean...how much money would I spend on something like this???...below 30% real camera price,  I would  think about it...more than that..no way.
    Scholar:
  • 107 Answers
I believe your problem is in the drum motor assembly part No is AD97-10579A. Samsung they know that problem it require a Technician to replace this part because you must adjust electronic and sometime mechnism as well. Depend which country you are it might cover under warranty even your CAM is out of warranty just check with Samsung in your area
Posted on Dec 04, 2008
Samgung SC-D353 camcorder 'EJECT' problem
sc-d353 got wet slightly the camera part is working but good tapes display eject sign and in the middle of the screen displays the eject symbol and ...r please help
Jun 02, 2009 | Samsung SC-D353 Mini DV Digital Camcorder
Distorted sound on playback, samsung mini dv camcorder.
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Dec 18, 2008 | Samsung SC-D67 Mini DV Digital Camcorder
Samsung SC-D363 Mini DV digital camcorder
sir if your camcorder is new then it has a warranty. we should send it first for their service because they have a spare parts for replacement and info. if your going to fix it by yourself then the warranty of that will be void. by the way the place for the service center for camcorder samsung in the philippines is in makati i think. i got a problem with my samsung just like your model and they told me that it is located at makati. hope that helps!
CHARCOIS
Oct 03, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
Eject light comes on after I start playing the tape
ksmitheram,
I had the same problem with my camcorder just awhile ago. This can reflect a low battery. Try plugging in the camcorder for a couple of hours without using it. Then try recording or playing back the tape with it plugged in. Unplug it and check again. If this does not work you may have to replace the tape head.
Dec 25, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
D-eject problem
try cleaning tape? maybe tape path is outta balance. try new tape?
Dec 14, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Cassettes not rewinding
The heads could also just need a good cleaning, either professionally or using a head cleaner dv tape. It's important to remember to always use the same manufacturer dv tape all the time. Evidently, Sony and Panasonic do not mix well, and the lubricants from those two tapes combined will gum up the works. If you use Sony dv's, always use a Sony head cleaner and vice versa. Cold can also cause those lubricants to gum up. Sometimes simply fast forwarding will loosen things up.
Nov 25, 2007 | Video Cameras
Entire camera is locked up
THIS IS A PROBLEM WITH SAMSUNG SCD 353 LET ME NO IF U NEED MORE REPAIRS
Oct 21, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Even after using head cleaner, no playback
SOUNDS LIKE YOUR MAIN BOARD IS GOING OUT. NEED TO SEND IN FOR REPAIR
Feb 01, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Samsung SC-D33 Mini DV Digital Camcorder Logo
286 people viewed this question
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
