Question about Kenmore 15762 Dishwasher
Kenmore dishwasher 15762
My dishwasher lights up when the "start" button is pushed, but the cycle does not start. I can hear a faint humming sound like it wants to start. It worked perfectly two days ago and I am wondering if it is because of the extremely cold weather we are having. None of my pipes are frozen in my house, so I am not sure if something could be frozen within my dishwasher.
  • Anonymous Mar 28, 2014
    My dishwasher has no power and none of the buttons light up when I push them
    Scholar:
  • 135 Answers
On the inside of the dishwasher (on the bottom), there should be a little "float" device, which tells the dishwasher when it has put enough water into the tub. Sometimes, this float gets stuck in the "up" position, so the dishwasher never puts any water in, but continues to run anyway as if it did. Try pushing down on the float to unstick it, then start the cycle over and see if it puts any water in.
Posted on Feb 06, 2007
Kenmore dishwasher 6651702 wash cycle won't run. .hear a faint humming noise. It will fill and drain.
Sounds like the main pump needs to be replaced. Mine is similar and the pump just went out with the same symptoms. 130 bucks if I remember correctly.
Oct 30, 2015 | Kenmore Dishwashers
Press START and nothing happens
yes the door has a safety switch that will keep the machine from starting, this is most likely the problem.
Aug 12, 2008 | Kenmore 15762 Dishwasher
Why will my dishwasher not start?
this sounds like the user interface {touch-panel} has gone bad
Dec 11, 2017 | Kenmore 15762 Dishwasher
Kenmore dishwasher fills with hot water but will not wash, just a faint hum. goes through cycle, drains fine, like motor doesn't turn on.
The faint "hum" sound is your wash motor trying to turn on. You either have a piece of glass/tooth pick/ ect.. or a worn out bearing. Its time to change your wash motor. If you do a DIY you can save money over having a service man come out and charge about the cost of a new one.
Best of luck! Please rate me a 4 if that was helpful.
Dec 12, 2010 | Kenmore Dishwashers
Lock light stays on
It sounds like the circuit bontrol board is cracked or shorted, which means it must be replaced.
Jul 24, 2009 | Kenmore 15762 Dishwasher
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
Sears Kenmore model# 665-16022401 Serial# FS0304946 - Clean Light Blinking
THE HUMMING NOISE THAT YOU ARE HEARING IS THE ELECTRONIC DRAIN MTR ACTIVATING BUT YOU HAVE NO WATER IN THE SYS. SO IT SOUND LOUDER AND DIFFERENT THE HUMMING IS THE LESS OF YOUR WORRIES THAT IS NORMAL BUT WHAT IS NOT NORMAL IS THE CLEAN LIGHT FLASHING IF IT FLASHES 7 TIMES THEN PAUSES YOU HAVEA BAD PROCESSING BOARD AND ALSO A HEATER ON SOME OF THE KM MODELS THE CONTROL BOARD AND HEATER IS SOLD AS A KIT. TO VERIFY THAT THIS IS THE CASE GO TO WWW.SEARSPARTS.COM . BUT FIRST ALSO CHECK TO SEE IF YOU HAVE A BURNT WIRE AT THE HEATER ASSEMBLY WHICH WOULD REQUIRE PULLING THE DW OUT. GOOD LUCK
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Mar 12, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore dishwasher
needs a new control panel/ touchpad assembly very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 27, 2007 | Dishwashers
Dishwasher "lock on ' control wont turn off
Hold the control lock in for more than four seconds. See if that works.
Jul 25, 2007 | Kenmore 15762 Dishwasher
Kenmore 15762 Dishwasher Logo
325 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
