I can't connect to internet via wireless router. My computer doesn't show my wireless network adapter in device manager, even though I have used this computer, router, and DSL modem for over 3 years. I recently upgraded my RAM (had issues with that); the internet worked great for one day, then went kaput. Any chance they're related?
  • 404 Answers
Hello! I very much doubt that Memory will cause the problem you have. Are you using a secure network? if so you may have to pair it again with the p.c. try this! hover over the internet icon on the taskbar (2 computor monitors) it should show wireless networks available, if not right click on it then click set up network or search for available networks, if this fails uninstall the wireless router in the device manager and reload after re booting.
Hope this helps!
Paul 'W'
Onyer~EDson(:0)~[><
Posted on Dec 04, 2008
Adapter inactive
It is not the problem with the router. It is the problem with the wireless adapter on your computer. Open Network connections and look for Wireless network connection. If it is not there then open the Device Manager and look for Wireless network adapter under Network adapters. It seems that wireless adapter on your computer is not working or it is not detected by your computer. If you have external wireless adapter then unplug it and replug it.
Nov 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I cannot connect to my home wireless network provided by my new ISP, after I ended my subscription to my old ISP. Connection via old ISP was via Dial Up; connection via new ISP is via broadband. I have a...
First of all you may try to check the adapter settings on your computer.
Start>control panel>network and sharing center>adapter settings>check status of broadband(should be connected)
If not right click on broadband connetio and click on connect if still showing as disconnected
You may also check internet option settings.
open IE>tools]nternet options?>connection tab>tick on never dial a connection.
Click on LAN settings tick on automatically detect settings>ok
You may also check for the if the driver for your wireless broadand is working by checking it on device manager.
Try to check if broadband is working on the other computer.
Apr 15, 2011 | Dell Inspiron 630M Notebook
HP built-in wireless internet light cannot be
try this...
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Oct 03, 2009 | HP Pavilion dv9000z Notebook
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
In my home office I am using an airlink 101 802.11g wireless usb 2.0 adapter to connect with my airlink 101 super g wireless router on my main computer. Everything has worked well, but today my office...
Hi.
This method will hard reset the wireless drivers back to default settings.
What i want you to do is right click "computer" select "manage" and then "device manager", a list will populate, then click on the + sign next to "network adapters" and right click on the wireless adapter and "un-install" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again.
Good luck
Jun 17, 2009 | Computers & Internet
Unable to connect to the Internet
Check to see if your wireless card is displayed under “Network Adaptors” in “Device Manager”. You can access the "Device Manager" by going to the 'Control Panel", "Administrative Tools", "Computer Management" and select "Device Manager" located in the left side column. If it is detected and there are no alerts or errors, try uninstalling the wi-fi card, reboot the laptop and reinstall the drivers.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 04, 2008 | Dell Inspiron 5100 Wireless Mini-pci...
Toshiba Satellite limitations on network adapters all wireless, need other
you need to log into the router setting by typing something like 192.168.*.* etc,check the right one for your router and enable some type of encryption like 128bits wep..Then your network is secured with a password which will stop anyone access.Now also change your router password if possible to prevent access from others...Hope this helps.
Sep 06, 2008 | Toshiba Satellite M40-S417TD Notebook
Can't connect to internet
It sounds like the driver for the USB network device is not loaded correctly. So, you'll need to reinstall it from scratch. Unplug everything, install the software, then reattach the usb cable to the PC.
The other thing is, did you DISABLE the network adapter that was already in your PC when you added the USB network adapter? If not, you need to do that. If they are both active but only one is connected, the system could still be trying to use the other network adapter and tying up the resources in the process.
Jun 23, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
