Question about Kitchen Ranges
I am having a hard time trying to find new oven racks for a Jenn-Air gas electric grill range model #: svd48600. Have any ideas where I can find them?
  • 50 Answers
Http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=svd48600
click this link, then choose your model, then on the left side under select diagram scroll down to # 7 oven, and presto.
Posted on Dec 04, 2008
Jenn-Air model svd48600. Gas stove top, electric oven. Why would the exhaust fan turn itself on whe either of the left burners is lit.
The switch for the optional grill attachment is activating...pull the tray/pan on the left side that holds the two burner grates toward the front...it should shut off. To correct the problem permanently, you'll need to adjust the position of the switch. The switch gets lose over time and slides on its mount until it gets out of range. The purpose of the switch is to activate the blower continuously when using the optional grill accessory. When you remove the left-side grates and the tray/pan the grates set in...you'll notice a protruding piece of metal on the front of tray/pan that fits into a hole in the cavity where the tray sits. Inside that hole is the switch that is out of position. Getting at the switch to adjust its position is not difficult, but you need to remove the upper front panel...KLS
Dec 13, 2009 | Jenn-Air Kitchen Ranges
Cleaning surface grates on 10 year old Jenn-air Gas-electric
Spray them w/ oven cleaner, put them in a plastic trash bag, and let them sit overnight. They should clean up w/ minimal scrubbig.
Sep 18, 2009 | Jenn-Air Kitchen Ranges
Jenn-Air S136 Grill-Range--auto clean not working
Selector to Clean
Temperature to Clean
Move lock lever to the right
Press the enter button Twice
Mar 19, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air Gas-Electric Grill Ranfe with Convection Oven M# SVD48600
if possible, squat down in front of the range and put your ear as close to the bottom of the control panel/top of the door when you close it. there is a small motor that pulls the door in when you use the self-cleaning function. perhaps that motor is running all the time? its quite, more of a humm. this could explain why its locking itself. other than that, my convection oven JennAir has a small fan in the back that runs when the oven is on, regular or convections mode. you can see this fan squirel cage in the back wall of the oven. if you were to pull the range out, you will notice (atleast on mine) that there is another much smaller fan on the backside of the range behind the removable metal panel. what the smaller fan is for, i have no idea. so there are two fans, plus if you have the down draft feature, thats 3 total. hope this helps somehow.
Jun 21, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jenn-air gas electric grill range
any power to unit at all?? clear, start, clean ,button?? what happens when you push them??? clock on?what happens when you try to set to clean again??? it should activate hte door lock latch at which point cancel and it should reset itself. with any luck! what happened thankgiving how was it fixed
Mar 14, 2008 | Kitchen Ranges
Kitchen Ranges Logo
262 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
