Question about ZR4 Radar Detector
When I use car siren, ZR4 is chirping
Whenever I use the car siren(Audi, Mercedes, new models of car) I can hear ZR4 chirping. When I release the siren, ZR4 stops chirping. Pls, let me know how to solve this problem?
Regards
Vladimir Djelic
  • 134 Answers
This is caused by electrical noise within your car's electrical system. Jump over to radardetector.net for suggestions about how to resolve this issue.
Posted on Mar 17, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How to program remote for viper 650xv?
You can find a copy of the manual at the link below or try this:
  1. Open driver's door - leave it open (door trigger must be connected on the alarm).
  2. Turn ignition key on.
  3. Within 5 seconds, press the valet/programming button once and release.
  4. Press valet/programming button again and hold it down.
  5. With valet/programming button held down, you should hear the siren chirp within a few seconds. After the chirp, press the lock button on your new remote.
  6. After pressing the remote's lock button, you should hear a short blast from the siren. Now release the valet/programming button.
Viper 650XV Installation Manual
May 13, 2014 | Basic Remote Vehicle Alarm System
No chirp when arming vehicle
Either your siren is broken, not properly grounded, the system is in valet or, the chirps were deleted. To add chirps, turn the key on then off, immediately press and release the valet switch three times. If the chirps were off you will hear one chirp from the siren.
Feb 14, 2014 | Prestige Remote Start
I'm trying to install a Python 991 Remote Start / Car Alarm in an automatic 2000 Subaru Impreza and I have all the wires set up. I know the Control center is supposed to be switch from manual to automatic...
It is not the "control center" that needs to be switched. The unit itself must be programmed for automatic transmission. The antenna (control center) must be connected to the module for normal operation. Merely connecting the two does not initiate a reaction from the LED. You MUST enter the programming mode (ignition on , ignition off, press and hold programming button until you hear three chirps from the siren). The three chirps are remote starter programming options. After you hear the three chirps, press and release the programming button once then, press and hold the button (you will hear one confirmation chirp), now press and release the lock button on the remote (you should hear two chirps from the system). The unit is now programmed for automatic transmission.
There are several other programming options for your particular vehicle (not mentioned) that may be NECESSARY for the proper operation.
Mar 20, 2011 | 991 Responder LC3 SST Security/Remote...
How to program new remote to alarm
TRANSMITTER PROGRAMMING Note: System can learn up to 3 different codes max. 1. Turn Ignition ON and OFF 3 times quickly, leaving it ON the 3 rd time. (ON/OFF, ON/OFF, ON) You should hear (1) short chirp. 2. Push the Program/Override Button for 5 seconds until the siren chirps (3) times. Release the button. The system is now in programming mode. 3. Press Button #1 on new transmitter - siren will chirp to confirm programming. Repeat Step 3 within 5 sec. for up to 2 additional transmitters. 4. Turn off Ignition. Note 1: If only one transmitter is being programmed, continue pressing button #1 until dash LED flashes goes out and the system chirps to exit programming mode to prevent unauthorized codes and noise from entering the system. Note 2: Programming mode is exited automatically after 5 seconds of last code transmission or once 3 new codes have been programmed. The LED will flash (4) times indicating program mode exit.
Jan 12, 2011 | 1Way Remote Transmitter
Battery dead.when i try to boast the car alarm goes off and i can"t turn it off without removing boaster cables
Try manually disarming the system when you hook up the battery cable. After you hook up the cable ( the siren will be going), turn ignition on, press and release valet switch one time. The siren will stop and you will be able to start the vehicle. Test the remote. If the remote is not working, and the battery is good, try reprogramming the remote. Turn ignition on, press and release valet switch one time. Press and HOLD valet switch, press lock button on remote. You will hear a confirmation chirp when the remote is programmed. Turn ignition off. Test system.
Nov 21, 2010 | Remote Start System
How do program a new 488v led remote for my car?
Open the drivers door, press and release the valet button one time, press and hold the valet button, siren will chirp. While holding the the valet button, press and release the the lock button on the remote. siren should respond with a long chirp. Release valet button, trun off ignition, test remote.
Sep 15, 2010 | 488V LED 2Way Remote
Need to pair the remote with the alarm on a DEI Python 990 car alarm
If you know where your Valet switch is, turn the ignition on, push and release the valet switch once, then push and hold it, you should hear the siren chirp once, then while still holding the valet switch, push the #1 button on the remote, you should hear the siren chirp again. it is now programed. If you have the package that came with the remote, it should have a table on the back that tells you how many pushes of the valet for which feature you want to program. Most remotes are one push for all features, some are 7 or 8 pushes. So if it say auto learn is 7, turn the key on, push it 7 times, the push it again and hold it, the push #1 button, and it's programed. Hope this helps. If all else fails, take it to your nearest best buy, if they charge you to program it, it won't be much.
Aug 20, 2009 | Vehicle Parts & Accessories
Programming the APS02BT2 remote
TO PROGRAM ADDITIONAL TRANSMITTERS:
1. Enter the vehicle, and turn the ignition key to the "on" position.
2. Press and release the valet push-button switch three times.
3. The dash LED will flash once, and the siren will "chirp" once, indicating the system is ready to accept programming for channel 1 or the arm/disarm and panic functions.
4. You can assign any of the three transmitter button functions listed below to channel 1.
a. Pressing button #1 on the keychain transmitter.
b. Pressing button #2 on the keychain transmitter.
c. Pressing both buttons simultaneously on the keychain transmitter.
5. Press and hold the selected choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 1 was successful.
6. Press and release the valet push-button switch one time.
7. The dash mounted LED will flash 2 times, and the siren will "chirp" indicating that the system is ready to accept programming for the unlock/panic channel.(If you desire one button to control lock & unlock, move on to step 9)
8. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of unlock channel was successful.
9. Press and release the valet push-button switch one time.
10. The dash mounted LED will flash 3 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel2, or the pulsed ground output for remote trunk release, remote car starter, etc.
11. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 2 was successful.
12. Press and release the valet push-button switch one time.
13. The dash mounted LED will flash 4 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel 3, or the additional pulsed ground output if available on your model. NOTE: If the program switch is operated again, the circuit will recycle through the program mode. In other words, press 1 time to access the lock function, 2 times to access the unlock function, 3 times to access the start function. When programming is complete, simply turn off the ignition switch to exit the program mode.
ERASING TRANSMITTERS IF THEY HAVE BEEN LOST OR STOLEN: NOTE: Before you begin to erase the lost or stolen transmitter(s), have all transmitters available that you wish to remain programmed. These will be used during the program process to identify transmitters that will continue to be used.
Enter the transmitter program mode:
1. Turn the ignition switch to the “ON” position.
2. Within 10 seconds, press and release the valet/program switch three times. (Siren emits 1 short chirp indicating channel 1 has been entered)
3. Within 10 Seconds, press and hold the ARM or ARM/DISARM but-ton of the first transmitter you wish to remain stored into the control unit until a single chirp is heard from the siren.(Repeat this for each transmitter you wish to remain stored in the control unit).The receiver stores up to four transmitters. To be certain all transmitter slots in the receiver are occupied with transmitters you wish to continue to use, and all others are erased, you will have to fill all four receiver slots. If in step 3 you identified one transmitter, you will have to fill the additional 3 slots. If in step 3 you identified two transmitters, you will have to fill the additional two slots, etc...
4. Press and hold any unused button or combination of buttons until a long chirp is heard from the siren. Release and press the button or button combination again and again until all remaining slots are full. NOTE: The button or combination of buttons entered will also control the armor arm/disarm function until additional transmitters are added. All unwanted transmitters are now deleted.
Feb 28, 2009 | Car APS02BT2 Transmitter for...
Audi a4 turbo chirps when car is started
Could be the belt(s).
If not that, could be a loose hose coming from the turbo. If it build boost and the hose is loose, it'll chirp. At least, it would on my turbo bike. Sounded like a balloon releasing air when the neck is pinched.
Dec 24, 2008 | 2002 Audi A4
ZR4 Radar Detector Logo
100 people viewed this question
Top Escort Vehicle Parts & Accessories Experts
John Nolan
Jason
Steve
Are you an Escort Vehicle Part and Accessory Expert? Answer questions, earn points and help others
