I just changed the battery in my remote. Now I cannot set the alarm on the car?
SOURCE: remote not working how to manually disarm alarm
did you get a different key for your alarm box if not thy the ignition key. joe
SOURCE: program my remote
Program your factory keyless entry functions
For 2001+ Tacomas equipped with a factory alarm or keyless entry, here are some programming options that allow you to adjust the way your locks work.
The first programming option allows you to set the entry unlock to: (A) unlock the driver door with one push, and the remaining doors with a second push OR (B) unlock all of the doors with a single push.
(IN - OUT - IN - OUT)
(SHUT - OPEN - SHUT - OPEN)
(IN - OUT)
(LOCK - ON - LOCK - ON - LOCK - ON - LOCK - ON - LOCK)
SOME OF THE REMOTES REQUIRE THAT THE KEY BE IN THE IGNITION, IN THE ON POSITION. TAKE THE BATTERY OUT AND WAIT 10 MINUTES. THEN PUT THE KEY IN THE IGNITION AND INSTALL THE BATTERY WHILE THE KEY IS TURNED TO THE ON POSITION. HOPE THIS HELPS YOU. PLEASE KEEP ME POSTED. THANKS FOR AN HONEST RATING AND FOR USING FIX-YA. GOOD LUCK
SOURCE: Hi. I lost my remote
You defintely need to get a remote for the alarm to disable it or uninstall the alarm altogether.
SOURCE: After disconnecting the battery and then
If after unlocking the driver door with the key and still no luck, put the key in the ignition and turn forward to start (if it won't start turn forward anyway) then push you're red reset button on the dash. That should do it.
