Polaroid DRA-01601A Hard Drive Model/Format
I bought a Polaroid DRA-01601A "cheap".
It was missing the DVD burner and HDD cables and the HDD.
While the cables are easy to replace (I think), I have no idea what HDD it uses nor what the format would be.
Does anyone have any parts or suggestions?
The HDD is 160 gigs.
The menu allows one to "format" the drive.
I have not tried this however.
Posted on Dec 14, 2008
Where can you buy capacitors? I have a Polaroid DRA-01601A and at least one of the capacitors is blown. Specifically CE10 from what I see on the mother board.
You can buy capacitors from many places. Radio Shack as a local store. Digi-key as an example.
Jim
Preston Computer Service
www.prestoncomputerservice.com
May 21, 2011 | Computers & Internet
Password problem
The password is for the parental control feature.
For the Poaroid dra-01601a the password is 3-3-0-8 type this in using the number pad then press ok. If you press setup on the remote then press down till you get to ATV/DTV then press right arrow button to highlight DTV Parental control, press enter then a dialogue box will appear this is where you can input the password code. Select V Chip and press ok, you will then have the option to select which content controls to use in the menu you will see Block enable, use the down arrow to highlight this then press the right and left buttons to turn either on or off. to exit this setup press 6.
Hope this helps,
James
Apr 21, 2010 | Polaroid DRM-2001G DVD Recorder/HDD...
I have the polaroid dra-01601a dvd/hdd audio
First of all with all do respect I do not have the polaroid drm 2001G. I have as I exprest in my letter to you the polaroid dra 01601A. The problem i had was an audio problem and i simply rechecked all my connections and found that I needed and extra set for HDMI plugs on my TV.
Jan 03, 2010 | Polaroid DRM-2001G DVD Recorder/HDD...
Polaroid dra-01601a hdd to dvd recording
You will have to split the title and record on more than one DVD. The default speed is SP, that is 2 hours of recording. If you want to record longer programs, go into setup and change the default record speed to one of the other settings, for example: SP+ which is 2 1/2 hours or one of the other longer record settings. This DVD burner will only record at the same speed as you recorded to the hard drive. You can also edit out the commercials by using segment. Go to the title you want, press the right arrow, scroll down and select segment. When you want to start your edit, press enter. when you want to stop the edit, press enter again. You can use your right arrow to skip forward 30 seconds and your left arrow to skip back 10 seconds if you went too far when editing. You will see where your edits are on the screen by the darker color. Do this through the whole program. When you record to DVD, the commercials will not be recorded. Hope this helps you.
May 01, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
Time shift to hdd
The only way I was able to do it is to capture "while playing back" to another recorder "VCR" DVD"
Dec 10, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Transferring from timeshift buffer to hdd
When in timeshift, press record on the remote (every time you push "record" 30 minutes are added) and make sure the program you are recording is not macro protected. If your program has already finished rewind to the beginning of the program and push record the correct number of times to cover your program and then press stop on the remote. It should then be at the bottom of your hard drive list.
I have a Polaroid DRA-01601A DVD Recorder (w/160gb hd). I am getting a video output on my tv as a black and white split screen. Can you help?
The picture output may be set for other than 480i. Try to connect the composite output, and you may get enough picture to change the setup to 480i.
Oct 13, 2008 | Polaroid Televison & Video
Polaroid DRA-01601A will not power up
99.9 % of the times its the capacitor which is blown. I had spent few weeks to investigate on this and ultimately found this solution. Till date I have replace two capacitors. To determine which capacitor is gone, Check on the flat silver surface of capacitor. If its not 100% flat it means its gone and you need replacement. Pl. check my attached file to understand on details of inside configuration.
Hopefully it works for you.
I am not able to upload pdf which I have created. Pl. contact me via email to get pdf file
viki_3578@yahoo.com
Regards,
viki_3578
Feb 16, 2008 | Televison & Video
Polaroid Will NOT edit out Commercials!
You need to post edit the recording;
First unprotect then do a split before the commercial
than split after, then recombine the parts without the ad.
Cumbersome, but it works
Feb 12, 2008 | Polaroid DRM-2001G DVD Recorder/HDD...
Televison & Video Logo
240 people viewed this question
Top Televison & Video Experts
Electro Med Services...
