Question about Kitchen Ranges
Hi I have a Baumatic BAH9003G SS Kitchen Hood which is two years old, the fan and light button assembley has fallen back into the unit meaning I cannot use it. Is there any way to get into it and attempt to put it back in? Thanks Robyn
I have bad news - the spare parts from England are not available and "Think Appliances" who import these items have no idea when shipment will be coming into the country.I will go on a hunt and see if I can get a second hand one.
Posted on Feb 01, 2013
  • 50 Answers
Are there any kind of filters underneath it. if so u should be able to pull the filter out and access it from the inside,
Posted on Dec 04, 2008
Faber model inca hc 72. The fan makes an odd noise. It still works. it is 11 years old.
your hood probably needs a service call to examine the motor, please visit http://faberonline.com/service.html to find your local service #, thank you
Jan 30, 2014 | Faber Inca HC SS Stainless Standard Insert...
Put new bulb in baumatic kichen hood turned it on, instantly made a noise like it tripped out, fan and lights now don't work, can not find fuse?
It was probably a defective bulb that tripped a circuit breaker in your house panel. Check the breakers and replace the bulb.
Feb 24, 2010 | Baumatic F60 Stainless Steel Kitchen Hood
Where can i buy new Baumatic 7.3 GL cooker hood halogen lights at a good price
FIRST TURN OFF THE POWER TO THE HOOD UNIT THEN LOCATE THE BULBS AND REMOVE TAKE THEM TO THE LOCAL DIY STORE TO FIND REPLACEMENTS IF NOT FOUND THERE YOU CAN GO TO AN ELECTRICAL AND PLUMMERS SUPPLY STORE , GOOD HUNTING.
Nov 17, 2009 | Baumatic F60 Stainless Steel Kitchen Hood
Baumatic hood bt82.1 lamps blown..
Hi johnnyi6,
I'm Harvey the Master Plumber.
Your problem is: had a crackling noise then pop..looks like transformer has blown,replaced
but still no lights ..fan o.k...don't appear to be getting any power to transformer via switch?...how do you get push button switch out?...
bypassed light switch and lights o.k with new transformer..any ideas..
Yes, I agree, the switch went bad. It snaps in so you will break it during removal. I recomend you get the replacement switch first so you don't have a wire hanging out while you wait for the new one.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 15, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
The extractor on my Baumatic fan stopped working. Thsi was shortly after the light bulbs blew which I replaced and they work OK. Any suggestions as to how i can resolve this?
Sounds like it was the main fan motor - that caused the lights to blow in the first place.
Isolate from supply, and get the fan motor checked out. If it is burnt out (inside) you will need a replacement.
Hope this helps.
Jun 05, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Push Button Switched
zepher sent replacement sritch.
had to wait a while -parts from italy (heh)
so far ok
design is poor
Feb 29, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
F90 st.steel hood fan problem
kerry, does it make any difference if you hold that button or not? If so, the switch set could be bad. Any odd noise from the motor? The motor might be bad. Power off. Then, remove the filter and try to turn the motor by hand. If it turns hard, it's the motor. Easy, then replace the switch. Check the electrical connections to the unit. There should be a box somewhere inside the housing. It is possible that wires have come loose. Again, do this part with the power off.
Nov 25, 2007 | Baumatic F60 Stainless Steel Kitchen Hood
Light blown then fan doesn't work!
take out switch assemby and check if the track of the pcb is blown - caused by the bulb goiung. you can often repair by soldering in wire links. bet you have 12a fuse in system - should be 3a. track has blown instead of the fuse
Mar 02, 2007 | Baumatic F60 Stainless Steel Kitchen Hood
Kitchen Ranges Logo
78 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
