Question about Kenwood KDC-V7017 CD Player
Need a Kenwood Part #...
I've got a Kenwood KDC-V7017 and i need a replacement part. The part is what the faceplate clicks onto and rotates it around when you eject a cd and/or turn it off. It looks like a thin rectangular piece of metal with a swiveling arm that connects to each end longways. The plastic plate that is glued to the back is all you see when the unit is switched off. The arm on mine is snapped in two but i think this might be one part number for both pieces. I don't really need the plastic plate; i can glue on the one i have. If I can just find the part # I can order it online.
    Novelist:
    Champion:
  • 218 Answers
Partstore.com will have the part but you will need to go to manualsparadise.com first and get a pdf of the COMPLETE service manual with the parts breakdown in it. If you are lucky enough to get the actual part number from someone then you can of course skip the part about getting the service manual. Good luck.
Posted on Feb 07, 2007
I need the instruction manual for my kdcv7017 kenwood cd player
Kenwood has the manuals for many of their products available on their support web site: http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/ . The direct link to the KDC-V7017 CD Receiver user manual is http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDCV7017.pdf . See the Kenwood site for the other available documentation.
I hope this helps.
Dec 01, 2011 | Kenwood KDC-V7017 CD Player
Need to get the security code for Kenwood KDC-608OR
ok I just found this info online and they say it came from the service manual for that stereo so I hope it helps:
You will need a Kenwood RC-410 remote control. This remote works on KDC-519, KDC-X859, KDC-319, KDC-4019, KDC-MP919, KDC-X759, KDC-419, KDC-X459, KDC-MPV619, KDC-MPV7019, KDC-2022, KDC-2022V, KRC-435, KRC-535 and KDC-X959
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Above information source = http://techbybucky.blogspot.com/2008/01/how-to-reset-security-code-on-kenwood.html
Jun 19, 2011 | Kenwood Car Audio & Video
Faceplate opens to remove the faceplate but there is no display?
you probably have a bad flexible cable (goes from the face to the main motherboard). unless you are good at desoldering and soldering, you may want to have it done by a professional.
Sep 08, 2010 | Kenwood KDC-V7017 CD Player
What is the security code for kdc-891
1) Turn on the car.
3) Press >>| and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>| key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>| key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>| key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>| key on the faceplate.
Jun 01, 2010 | Kenwood KDC-X891 CD Player
Ejecting my faceplate
you probably have a bad ribbon cable.
Aug 06, 2009 | Kenwood KDC-V7017 CD Player
Kenwood KDC-MPV 7019 code
Kenwood Code reset for KDC-MPV7019: (remote required)
1) Turn on the car.
MANUAL for the same radio
Jan 15, 2009 | Kenwood KDC-MPV7019 CD Player
Kenwood kdc-v7017 wont turn on, fuse is good
I tested the cable from the face plate to the pcm with a ohm meter and fond that there were a few broken wires in the ribbon cable so i found a downloadable service manual got the part numbers for the ribbon cable and the recptical that the faceplate contacts and ordered them from the kenwood parts web site
Jan 02, 2009 | Kenwood KDC-V7017 CD Player
Manually opening a Kenwood motorized face
hi if you pop off the top cover you should see a motor on the right hand side, with a flexi cable connected to it, if you unplug the Flrxi from the pcb, you can then use a pp3 (9v) type battery to power up the motor. this will be much esier than manually moving the gears.
be sure to remove the flexi first otherwise you WILL damage the motor driver.
Regards
Mark
Jul 23, 2008 | Kenwood KDC-715S
Kenwood KDC-MP2035 security code
yo tengo un reproductor kenwood kdc-mp2035cr pero este no me reproduce nada solo me sale un mensaje que dice protect y no me deja hacer nada ni colocarle nada por el auxiliar
Jun 05, 2008 | Kenwood KDC-MP2035 CD Player
Kenwood KDC-V7017 CD Player Logo
137 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
