Question about Canon ImageRUNNER 1670F Copier
We cant figure out how to get our Konica 7065 to copy and staple with the page positioned and scaled correctly.
Put the at lest 2 original documents on the (adf) then put the quantite then go to output on the screen chosee the position set what you wont to use . and then press ok .
Posted on Feb 15, 2010
Konica 362 not stapling left side of copies
staples been replace. does it corner staple?
Nov 10, 2016 | Konica Office Equipment & Supplies
Charge corona unit
carriage to printer is jam do you know of a service center that waork on kodak 7250 since staples wont take it back tok mit bto a dealer said he cant fix
Dec 12, 2013 | Konica Minolta magicolor 2430 DL Laser...
Yes you did good but you didnt get it in all the way... push harder till it clicks in,,,, unless there is no staples in the cart.... tell me how it went
Sep 04, 2011 | Konica Minolta Bizhub c203 Copier
Why do multiple copies sometimes staple together as one set instead of multiple sets?
I don't know how/why, but if you set the Print settings (main print screen) to non-collate and the Printer Properties (clicking in to get to the staple option) to collate, it works correctly, stapling each set individually.
Oct 28, 2010 | Konica Minolta bizhub C450P Laser Printer
I am trying to print a booklet with eight pages front and back from publisher 2007 on a Konica Minolta Bizhub C550 and when I print one copy it folds and staples fine. When I print two or more copies the...
first change driver, second print to hdd in printer, and then call this job from hdd and change copy amount. if this is not helping, then maybe the firmware is faulty, fw update is good idea
Oct 15, 2009 | Konica Minolta bizhub C250 All-In-One...
Folding and Stapling a Booklet on Bizhub C250
1)The print driver has two collate buttons and you only need to uncheck the first one (which is the windows driver not the Konica Driver) or
2) Install a new driver
Oct 02, 2009 | Konica Minolta bizhub C250 All-In-One...
you copy registration, w/out RADF? Or RADF registration adjustment?
Jul 02, 2009 | Sharp AR C250A Color Copier
Registation problem
Exists adjustment VWVstand up front edge. If you have servise documentation try to correct the registration begin copyings. I it is necessary to see the picture, as beside you cut, blanching band or begins the scene not first картнки but later. Send the picture scaning. Thank you
KONICA MINOLTA C450 VXL Printer - When stapling multiple copies it staples all the copies together rather than each one separately as required. I use vista operating system.
There is an issue with the Konica Print Driver and the MS Print Driver. If Collate is turned on in both the drivers, you will get this problem.
The solution is to turn off Collate on one of the Drivers. Usually you will have an initial Print Dialog window that pops up when you can select your printer, how many copies and if to collate or not. De-select Collate. Then you should also see Preferences Tab. If you select that tab, select Collate and Staple, your print jobs should now Collate and Staple correctly.
Jul 23, 2008 | Office Equipment & Supplies
Konica 4155 print shift
You need to enter a service mode. Holding down the "3" and "6" turn on .Enter "92" press copy button then press "P" when the copy quantity indicator flashes a number enter using the number keys a smaller or larger number.turn off then on.
Mar 17, 2008 | Office Equipment & Supplies
Canon ImageRUNNER 1670F Copier Logo
79 people viewed this question
old marine
old marine
