Question about Viking VGIC485-6G Gas Kitchen Range
I have a Viking 4 burner range. When I turn on the front right burner it will ignite but the left rear ignitor continues to spark. It continues to spark even after 1 minute. I have stopped using the right front. What do you think is going on?
  • 42 Answers
You have a faulty spark module submit your model and i will post your part #
Posted on Dec 21, 2008
Viking model VGR48 stovetop burners will not ignite?
First shut off the gas supply & disconnect electrical power to the range.
  • Remove all the burner control knobs, grates, burner caps & trim rings.
  • Remove the 2 screws securing the manifold panel, one from each corner. The panel will drop down.
  • Remove the screws from each manifold pipe mounting bracket. Remove 1/4 inch hex head bolt from the center of the manifold pipe. Push supply tube back to release from manifold pipe. Lift the cooktop assembly at the front to clear the 1/2 inch locator pins attached to the top of the bodyside.
  • Place cardboard between each side of cooktop & bodyside to prevent damage.
  • Move the cooktop to one side, being careful not to put stress on the wiring harness on left side.
  • Remove the wire from the electrode.
  • Remove the screw from the electrode mounting bracket to release the electrode.
You can replace the electrode & reassemble following instructions in reverse order.
Aug 20, 2008 | Viking VGSC306-4B Gas Kitchen Range
I have just replaced all the ignitors and the spark control module on the cook top burners. Prior to this the back burners would cause ignition spark continually when lit. the front 2 burners could be...
first check to make sure all the burner tops are setting correctly on the burner base, if not it will make the flame uneven. the way the igniter works is once they feel the flames on them they will stop sparking. make sure the flames are not too low and they are touching the igniter. check them one at a time. if you have any questions message me back thanks
Apr 08, 2011 | Viking Kitchen Ranges
My Viking Range top has 4 burners and the automatic ignition on the left two burners do not wok. Can hear clicks and gas but no ignition. Can manually lite them. Any ideas?
Sorry to read about your problem, I hope this helps you out.
your lite tube may be clogged, or take a needle and clean the hole's next to the lite tube on the range grills..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 19, 2010 | Viking Cooktops
Left front burner not igniting...no spark but has gas,
automatic re ignition control (spark module), that's a common issue on all viking stove.
appliancesrepairla.com
May 12, 2010 | Viking VGIC485-6G Gas Kitchen Range
Viking gas stove top ignitors sparking incorrectly
all ignitors spark at the same time no matter which burner is turned on. If you are having trouble with one burner not lighting try cleaning around the ignitor with a small screw driver so the spark has a good path to ground.
Mar 19, 2010 | Viking Kitchen Ranges
Burners sometimes will not light
You can check the ignitors/wiring by switching
the output wires at the spark module. If the
front ones work & back ones stop working, change
out the module. If no change take a look at the
ignitor(remove screw on bottom to remove
ignitor), ignitor wire & ground wire by removing
the burners.
Possible Causes Of Continuous Sparking:
Defective spark wires.
Continuous high heat can cause spark wires to
degrade. Use volt/ohm meter to determine
continuity
of spark wires. Look for obvious cuts/ abrasions
or pinch points. A defective wire can allow
spark voltage to transfer through insulation to
ground prior to reaching spark electrode. Under
normal circumstances all igniters fi re together
and if the burner in question has found an
easier
ground path the spark will go there. It will
not, however, in most cases have found a
CONTINUOUS
ground path such as what the fl ame would
provide under normal circumstances. This will
cause
the spark module to re-ignite.
Sep 01, 2009 | Viking VGIC485-6G Gas Kitchen Range
Viking Gas Burner issue?
is this a sealed burner unit? if so the burner base (the heavy brass part under the burner cap) has to be sitting just right. you will notice that it has holes around the the sides make sure that where your ignitor sparks to it that it aligns with the lowest hole on the burner base. if you have a great flame all around the burner after checking what i mentioned i would replace the spark module. if it continues to drive you crazy with the noise - just unplug it. the burners will continue working fine without power.
Dec 23, 2008 | Viking 42 in. Professional Series...
Burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Dec 14, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
Viking VGIC485-6G Gas Kitchen Range Logo
501 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
