Question about Mitsubishi WD-62525 62" Rear Projection HDTV
62 in Mitsubishi Tv Repair Or Trash?
I was given this tv the person whom had it before me said that they had it placed over heater vent and it got to hot and know when turned on its power light comes on and the projection lights in the rear come on and blink rapidly there is sound but know picture. can anybody advise me as to whether it can be fixed and will it cost me arm and leg to do so or am i waisting my time?
    President:
  • 1,284 Answers
This is a DLP projection TV from the model you posted I guess. Is there any kind of light on the screen at all such as on screen displays? This is the first step in trying to isolate the problem.
Posted on Feb 07, 2007
I have a mitsubishi wd-62827 tv. How do I access the bulb to replace it? Do I take the back of the tv off or the front?
on the back bottom right corner there are 2 Phillips screws holding a vent cover remove that, should have a small tunnel the lamp screws you can turn by hand pull handle to remove your lamp
Jul 03, 2011 | Mitsubishi WD-62827 62" Television
Television will not respond to panel power switch or remote
This unfortunately has become a widespread problem with this series of Mits televisions. You can read a forem about it here: Flashing green light of death But there is hope, Mitsubishi has instituted a rebuilding program for the chassis inside of your television. Any authorized Mitsubishi repair center should know about how to get you set repaired. It's not cheap (expect $500-$600) and it takes a few weeks, but it will save your TV.
Apr 07, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Where is the Lamp located in the Mitsubishi 2004 model the number is WD-62327
Turn unit around facing you, either on right rear side or left rear side, generally looks as though it is a vent cover with one to three screws holding cover in place. UNPLUG TV BEFORE YOU WORK ON IT AS ELECTRICITY CAN KILL YOU.
Oct 09, 2009 | Mitsubishi WD-62327 62" Rear Projection...
My 62 inch mitsubishi tv was hit by lighting
Try to find a local repair centre & ask if they can give you an estimate on the cost to repair. A lightning strike can cause either minor damage such as just an internal fuse blown or can cause severe damage which will wipe out entire circuit boards which can be a costly repair. In this case it's usually not worth repairing.
Oct 07, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Blinking green light will not reset. TV will not turn on.
something is not quite right here. usually mits has a good rep, but this doesn't sound quite right. i suggest you contact mits customer service about your experience.
Sep 11, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Rolling horizontal lines on 62" Mitsubishi
That problem is caused by failed Capacitors on the signal and FMT power boards. which is a very common problem for mitsubishi TVs. There are repair kits available for the V26 dlp which contain the capacitors and instructions on how to do the repair. Heres a link check under the repair kits category.
http://servicemanuals.vstore.ca/
Mar 29, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Lamp
you need to make sure your fans, and vents are kept clean, if they cant cool the lamp properly, it will make the lamp go out faster, also change your setting in the menue to power save, or low power, saves on lamp time
Jan 08, 2009 | Mitsubishi WD-62825 62" Rear Projection...
Mitsubishi 62in tv
You can get the owners manual on-line at mitsubishi-tv.com.
That should give you all that is needed.
Good Luck,
-Bill
Nov 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Thank you for your response.
plz post what is the tv is doing so i can help
Apr 13, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
