Question about SuperMicro H8DCE-O R Motherboard
SuperMicro H8DCE-O R Motherboard no video
Here is my problem, I have installed this supermicro h8dce motherboard and there is no output from the video card. I think that I have everything set up properly, everything is running and all of the lights along with the fans are on. The processor is fine, the processor works on another pc. Even though you can not see the POST there seems to be no beeping. The hard drive is running the memory is installed properly, and so is the cpu. I can not see the bios, I know that the screen is good. The video card that I have is e-geforce 9600 gso. As I mentioned before everything seems to be running when I turn the computer on, there just seems to be no video displaying that
    Genius:
  • 1,066 Answers
Did you plug up toe power to the video card, the problem seems to be that the video card is getting no power, if the power is hooked up properly to the video card, the your power supply is probably not powerful enough.
Posted on Dec 04, 2008
2 Suggested Answers
  • 341 Answers
SOURCE: SuperMicro H8DCE-Motherboard no video
Are you hooking up The 24 pin ATX J1B1 connector and the 8 pin processor power connector JBW1 ? Alot of guys don't realize that new AMD's get power from a special connector on the motherboard..If you don't have this connector on your power supply you will need to get one that does. Hope it is this easy.
H8dce no audio
Usual cause.
Under the Chip Set Menu in the BIOS
Under South Bridge Configuration
The setting Audio CODEC Interface has been set to disable.
Feb 03, 2013 | SuperMicro Computers & Internet
Supermicro x8sax memory bank issues
The X8SAX motherboard has 6 memory slots. Try booting with one memory stick in each slot to identify which memory bank (dimm slot) is giving you issues. If you are able to boot off of a good slot, check the BIOS version to make sure you have the latest installed (R 2.0b). It can be downloaded here: Super Micro Computer Inc Products Motherboards Xeon Boards X8SAX
If you are unable to get into the BIOS at all, check the warranty status and submit an RMA request to Supermicro:
http://www.supermicro.com/support/rma/
Mar 01, 2012 | SuperMicro Desktop Board - X8SAX...
How i solve supermicro x8dt3-f display problem
Make sure JPG1 is jumpered between pins one and two.
Pin 1 is on the left.
JPG1 is on the very bottom of the motherboard, near the end of the PCI slot.
Next go to Advanced Setup Configuration if you can get any video, and check Boot Graphics Adapter Priority.
Make sure it is set to Onboard VGA.
If no video, reset the BIOS.
Onboard VGA is the default.
Jun 01, 2011 | SUPERMICRO COMPUTER Supermicro X8DT3...
I have a western scientific server i purchased used. It has a X5DL8-GG motherboard with xeon processors. When I power it on it just has 1 long continuous beep. The CD rom has no power and there is no...
Check the cabling. You may have a 16pin cable plugged into the motherboard backwards. I would try reversing the 16P connector to see if that solves the issue. Next, I would try booting off of 1 stick of RAM (trying each dimm slot). If that fails I would check the CPU slot for bent pins. If any of them are bent you will need to RMA the board. Lastly, if there are no bent pins, it may be the video adapter and will need to be RMA'd. You can check the warranty status here:
Feb 15, 2011 | SuperMicro (X5DL8-GG-B) Motherboard
Hello, I have buy a Supermicro X8DAH+. I have mount 2 x Intel X5670 on the motherboard. When I push the button to start the system, the power is on, the fans run, I ear one beep but the power led...
I dont have specific info on this board, but most of the time you may need to set up a jumper to support 2 cpu's or with the 1 installed go into bios and see if there is a setting there that you can set. Another possibility may be the other chip is bad...swap the 2 out to see if it works...then you can rule that out...go to www.supermicro.com/manuals/motherboard/5500/MNL-1060.pdf...this is the manual for it...
Dec 20, 2010 | SuperMicro X8DAH+ Server Board X8DAH+O...
I installed a Radeon HD 4350 video card and the computer stick on the Supermicro logo on bootup
unplug the new card and retry,,
if it works without the card then take the card back to the store
Mar 12, 2010 | SuperMicro X7DAE Motherboard
Dec 04, 2008 | SuperMicro H8DCE-O R Motherboard
My supermicro mother board can not pick this type of SDRAM PC133U-333-542, meanwhile the memory slot is SDRAM
You are using the wrong memory.
A SuperMicro 370DLE only supports registered memory.
The U in the code shows that the memory you have installed is unregistered.
It will not work.
Exchange the memory for registered memory ,and the system should work fine.
Nov 19, 2008 | SuperMicro (370DLEO) Motherboard
SuperMicro H8DCE-O R Motherboard Logo
244 people viewed this question
Top SuperMicro Computers & Internet Experts
Tony
David
David
Victorman
Victorman
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
