Asus motherboard bios version1104 - Computers & Internet
  • 1 more comment
  • Anonymous Dec 06, 2008
    Sir ,
    Yes I have the same problem,Do have any solution please.
  • bungo_singh Dec 10, 2008
    Dera Sir ,
    I have tried but same problem is there Checksum bad please help .
  • Teis Thomsen
    Teis Thomsen May 11, 2010
    what is it you want?
    /Teis
    Scholar:
  • 80 Answers
Whether it shows your cmos checksum error press F1 to continue or f2 to load default.? If this is the problem than kindly switch off the system check for the cmos battery and change the cmos battery and set the date and time properly in the bios and save it by pressing F10.This will resolve your problem.and if not than check the jumper setting on the motherboard is it set to clear cmos and if so kindly remove and set it properly to adjacent jumper ok. Have a nice time.
Posted on Dec 04, 2008
Cerna obrazovka nemam disketu bios
Hi, you can download the bios here:
http://www.asus.com/Motherboards/AMD_Socket_A/A7V600X/#download
Download the asus update utility from here:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
The asus Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows environment.
The Asus Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
Aug 25, 2011 | ASUS A7V600-X (90M7A820G0EAYZ) Motherboard
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
I need installer of asus p5sd2-vm bios for motherboard
I hope you are updating BIOS for a good reason. But ASUS is pretty good about failed BIOS updates. ASUS website works best in IE
Go to the download page for *********** board here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5SD2-VM&p=1&s=22
Enter your Operating System, then click BIOS-Utilities and click the download link
Best wishes
Apr 15, 2011 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Mother board failed and somehow the bios got cleared where do i get the bios dont have the disks
download the Bios Driver From here:
http://drivers.softpedia.com/get/BIOS/Asus/ASUS-P4S800-BIOS-1011001.shtml
Jan 15, 2011 | ASUS P4S800 Motherboard
How can i make bios k8n-vm.rom to motherboard because i cant read from flopy this file , thank you
anaging and updating your BIOS
The following utilities allow you to manage and update the motherboard
Basic Input/Output System (BIOS) setup.
1.
ASUS EZ Flash
(Updates the BIOS using a floppy disk during POST.)
2.
ASUS AFUDOS
(Updates the BIOS in DOS mode using a bootable floppy
disk.)
3.
ASUS CrashFree BIOS 2
(Updates the BIOS using a bootable floppy
disk or the motherboard support CD when the BIOS file fails or gets
corrupted.)
4.
ASUS Update
(Updates the BIOS in Windows
environment.)
Refer to the corresponding sections for details on these utilities.
prepare the motherboard support CD or the floppy disk containing the updated motherboard BIOS before using this utility.
• Make sure that you rename the original or updated BIOS file in the
floppy disk to K8NVM.ROM.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Remove any floppy disk from the floppy disk drive, then turn on the
system.
2. Insert the support CD to the optical drive.
3. The utility displays the following message and automatically checks
the floppy disk for the original or updated BIOS file.
4. Restart the system after the utility completes the updating process.
DO NOT shut down or reset the system while updating the BIOS! Doing
so can cause system boot failure!
more details read http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8N-VM/e2537_k8n-vm.pdf
Aug 22, 2010 | ASUS K8N-VM Motherboard
ASUS P4S333 Bios is maybe corrupted
Asus motherboards are junk, if you buy another in the future, stay clear of Asus products.
With that said, you should check your system for malware and viruses first, before doing anything else
Sep 06, 2009 | ASUS P4S333 Motherboard
I want manual and bios of Asus motherboard model
Here's the link to the driver and bios updates. Hope it helps you.
http://bios-and-system-update.free-driver-download.com/ASUS/12467/ASUS-Mainboard-P4PE-BP-BIOS-1007.html
Mar 29, 2009 | ASUS P4PE-BP Motherboard
Lost driver
U can download the driver from these sites
http://www.driversbay.com/drivers/bios-motherboards/asus/p5vd2-vm-se/microsoft-windows-2000/
http://drivers.softpedia.com/get/BIOS/Asus/ASUS-P5VD2-VM-SE-BIOS-0302.shtml
Feb 04, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Download bios and flash
Try Asus update first, found here: http://dlsvr01.asus.com/pub/ASUS/mb/flash/Asusupdt60301.zip
It should check your current BIOS and download the newest one and install it automatically. If that doesn't work for you then you will need to update the BIOS from a bootable floppy disk using the two files found below:
The BIOS is here: http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5GD1/P5GD114.zip
You also need the BIOS update tool found here: http://dlsvr01.asus.com/pub/ASUS/mb/flash/AFUDOS221.zip
Jun 18, 2008 | ASUS P5GD1 Motherboard
Motherboard driver
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
apolpo-
Apr 25, 2008 | Intel Motherboard
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
