Home | Toshiba | MW20FM1 20 in. Combo | Curved Greenish yel...
Toshiba MW20FM1 20 in. Combo
Problem for Toshiba MW20FM1 20 in. Combo
Curved Greenish yellow band across the bottom of picture.
By greenx6 on Dec 04, 2008
~60 inch ~7 yr old Toshiba Cinema Series TV that now has a greenish yellow curved band across the bottom.  Also, the words on the screen are showing up in double.
Comments:
Dec 04, 2008
- Model# TP61H95
Dec 04, 2008
- If the problem is the amps- do I need to replace both?  What advantage is there to the higher amps?  How difficult is it for me to replace?  How much would a typical service call cost to repair this? What are PH001 & 002?  Thanks Bill for your help.
Best Solution
posted on Dec 04, 2008
Helpful)
premtech
Rank: Guru  Toshiba Expert
Rating: 89%, 1218 votes
Yes, both amps need to be replaced. Typically when an amp fails it greatly stresses the other amp. So it's HIGHLY recommended that both are replaced for greater reliability.
The only advantage of replacing the 110's with 150's or 180's is a higher amperage rating. (Able to withstand a greater current draw with less stress) But the circuit is designed with the 110's to operate efficiently. If the supplier doesn't have the 110's in stock you can go higher with no problems.
Unless you have better than a basic understanding of electronics I wouldn't attempt the repair yourself. These amps are about half the dimension of a pack of cigarettes with multiple pins protruding from the bottom. These pin fit into the slotted holes in the board and are soldered in from the underside. That means you have to remove the board they sit on and de-solder the amps that are in there in order to install the new ones. It can be a bit difficult and bending the pins happens even to the best of techs. It's what you do or don't do to remedy the many problems you could encounter.
How much does a typical service call cost... Well, it would depend on the area and how far the tech needs to go to make the call... But a service -call won't fix this set normally. I know it's a buggar but it will most likely have to go to the shop. Some techs simply remove the board and take it in for repair - then come back to install it. But that leaves the tech with only static testing and if there is anything more wrong it's a back and forth game to the shop for parts, tools etc... Ask the shop what they do for this type of repair. You can explain what you believe is wrong and ask what they typically charge for such a service.. They should easily be able to give you a ballpark... In my area I pick up the DLP and PTV's just because I like to be precise in my repairs. Guess I'm a bit anal that way but I have very few call-backs. Shop install on those amps we charge $425.00 parts, labor, tax, p/u and del.
You could cut your p/u and delivery charge by taking the unit in yourself.
Lastly, PH001 and 002 location numbers where you'll find in this case the connector pins for the digital module. Everything on the board has a location number C338 is a capacitor located in the 300 series of a particular circuit. D955 is a diode in the 900 series and so forth.. PH is a connector and at 001 and 002 you'll see a connector and on the underside the pins of that connector are soldered to the board. In this case look at them carefully, you may need to re-flow some solder on them to eliminate ringcracks.
If you don't do the job pass it along to your tech to have him look at these soldered connectors for reliability issues.
Good Luck!
Bill
Was this helpful?
Yes
No
Solution #2
Helpful)
premtech
The problem sounds like convergence amps have failed but without the model number I can't really tell you what STK number they are... If you want to reply with the model number I'll look up the schematics for it and let you know.
Bill
Comments:
Dec 04, 2008
- That would be my guess and it's a common problem for this unit, convergence failure. This unit uses two STK392-110 Sanyo amps. You can of course use 150's or 180's instead, just higher amp ratings respectively. Just make sure to get original Sanyo and not some Chineese knock-offs... Acme sales in Florida is a good place.
Another thing you might look at while you're in there is Ph001 & 002, specifically the solder connection on the digital module. These also are a common failure. The joints on these connectors are weak and over time can develop ring cracks. It's preventative, but well worth the time and effort to look.
Good Luck!
Bill
Was this helpful?
Yes
No
Popular Solutions for Toshiba MW20FM1 20 in. Combo
Questions and Unsolved Problems for Toshiba MW20FM1 20 in. Combo
Do you recommend Toshiba MW20FM1 20 in. Combo?
Answer
Answer
Hooked up external Toshiba DVD player to Toshiba MW20FP1 TV/DVD/VCR combo. Red,yellow and white... (More)
Answer
The remote censor does not work. Is there a way to access the menu function manually?
Answer
I have a Toshiba MW20FM1 when I turn on the power light comes on but no picture or sound
Answer
I need the programing codes for the remote so I can program the remote that came with my cable box... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba MW20FM1 20 in. Combo:
Top TV Combo Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more TV Combo Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
