Question about Sony STR-DB1070 Receiver
Volume change, followed by slight static playback.
My STR-DB1070 will be working fine then all of a sudden will slightly increase in volume and at that same time the audio quality gets worse. The playback almost sounds like static.
Could this be a feedback issue?
If I power down the unit, then power it back up it will be back to normal; then a couple minutes later go back to the static sound.
Please help!
  • sshepherd03 Dec 05, 2008
    I will try to find a service center close to me. I really appreciate your comment. I will let you know if I find somewhere to help me with this.
    I looked around for something similar to this under the "hood" but this receiver is fairly complex and all components are jammed in there.
    Being an intermittent problem it will probably be hard to find, although it seems to "most noticeably" effect my center channel.
    Thx Again!
    Scholar:
  • 107 Answers
I believe you have dry joints in output drive it require a qualifier Technician the do this you need special soldering station with anti static you are dealing with surface mount components if you shorted some thing in output drive it could damage to the output they are expensive to replace, now is not too bad you should bring in to Sony or servicce center Sony to repair it
Cheers
Posted on Dec 04, 2008
What causes audio to suddenly increase to maximum?
Volume in modern systems are controlled by a single IC. If that goes, it makes the volume functions go wonky. The IC can be found by tracing the wires from the volume control, or following the circuit if it is mounted on a PC board.
Jan 29, 2016 | Audio Players & Recorders
After switching off and on last night the volume and mute on stopped responding on Humax remote. IT is PVR9150T and remote RT531B. TV Remote works fine with volume. Humax remote works fine on all exce
Note that this type of device is designed to be left on at all times, so should not be switched off each night. I suspect that it has some slight corruption in the user-settings, so a factory reset may be required.
Apr 03, 2014 | Humax Televison & Video
Turned up full volume u can only just hear sound if ear right to it was working fine then the volume just ******** out
It could be the mic plug. uniden is known for the issue where the wires inside the mix plug break at the solder joints.
When the RX wire breaks, you will loose receive because the radio will not go into receive mode. But you can usually hear it ever so slightly if you crank the volume.
Other issue that may cause this. No radio activity, (unless you hear radio activity low and not static)
poor feed line or antenna.
I would try a different mic that is known to work.
Aug 11, 2012 | Radio Communications
Beringer PMH 660M has very low power output to speakers and when the volume in increased the output pops in the speakers and goes completely dead, everything else works ok and the lights stay on
could possibly be the volume switch, try changing the switch with one that you hardly use to eliminate the problem. any further probs just let me know. hope this helps
Feb 16, 2012 | Behringer Music
Hi i have rexently noticed that my phone no longer sends sound to the ear phone jack with the exception of voice calls i have switched the phone off and on but no change. What should i try next thanks
There is different sound setting for voice call and media playback.
If you press volume up key on home screen, it increase the phone call volume but not he music player volume.
You can try to increase sound of media playback. First, open music player or video player and increase the volume through volume up key. You will see media volume written on the Volume increase pop up notification.
If you still have problem, reply.
Jun 15, 2011 | Samsung Galaxy S GTI9000 Smartphone
Volume button
you can remove screws, pull apart and clean contacts with cotton swab and rubbing alcohol. this should cure the problem. If this by slight chance didn't work, than it may be an electronical or programming error
Apr 15, 2009 | SanDisk Sansa e270 MP3 Player
I have an old onkyo a-8067 reciever and only the left side speakers work. A while back the right side was fading and now it doesn't work at all. I also have a sony STR D1015 home theater receiver that has...
Fixed the Onkyo. Took apart the balance adjuster and rebent the feather-like things inside so they made contact. Clamped it back together and it works fine.
Nov 26, 2008 | Audio Players & Recorders
Sony handycam volume
I have a sony trv14e it was working fine yesterday on playback with sound my children pressed something and suddenly theres no sound on playback. Please help if you know how to restore the sound. Thankyou
Jun 05, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony ericsson Z520
I had the same problem with that phone... while manipulating the mobile part (cover) you can slightly improve the volume.
Another point to check is the button on the side of the phone which allows to increase or lower the volume: it could happen that you turn the volume low without noticing it...
My solution was to replace the phone.
Jan 02, 2008 | Sony Ericsson Z520a Cellular Phone
Sony STR-DB1070 Receiver Logo
156 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
