Remote control for Shinco KFR-70GW air conditioner does not work. Need to buy a new one in Brisbane, Australia or you send me one.
  • 441 Answers
SOURCE: Require instructions and wiring diagrams for Celestial KFR-70GW/K
If you pull the unit out of the case it should have a wireing diagram in a envelope near the compressor
Posted on Jul 17, 2009
  • 289 Answers
SOURCE: Hoffwell Air Conditioner KFR 61GW turned itself off
You may want to check the thermocouple. It should be located on the front coil. You have to remove the front cover to see it. However, close the vents and try it. If is overly humid that front coil will just condense all available outside humidity and the thermostat will be frozen. Pull the thermo stat away from the coil so it is not being frozen. Replace TC after that test Good luck.
Ash
Posted on Dec 08, 2009
SOURCE: Amani Whisper Series Model KFR 70GW keeps turning itself off
Just had the Amani service guy out. Had the same problem. It was the capacitor. Took about 15 mins to fix. The machine turns off to protect itself because it knows something's wrong
Posted on Jan 06, 2010
  • 1796 Answers
SOURCE: How does the Timer and Sleep functions work for
Hi!!
On the timer function, when you press the button, it will ask you the starting time and ending time of when the unit will start and turn off by itself. prior to use this function, the clock on the control has to be set.. On the sleep function, it will give you the option to turn off unit on 30 min. intervals. Just like on a TV.
Posted on Aug 10, 2010
hvac1960
  • 2133 Answers
SOURCE: We have a spit system
Leaking water from indoor is a common problem. Please check the following:
1. Cooling coil and air filter blocked-Clean it. 2. Drain pan and hos dust blocked-Clean it. 3. Non insulated pipelines-Insulate properly. 4.Less rpm of blower motor.-Replace capacitor.
Helpful?
Posted on Jan 01, 2011
The red light is flashing on my air conditioner SHINCO KFR 50GW, and the outdoor unit is off?
Sorry didn't really know how rusty me Japanese was until I went on their support page and could not read but half good luck
Jul 03, 2015 | Heating & Cooling
When i change the batteries the remote control KFR09 Soleus Air P-05-ID-Remote Control KFR-09GW
After battery change, it should be set up with set-up codes to your device again. Programming [set-up] procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Jun 02, 2014 | Soleus Air P-KFR09-05-ID Remote Control...
Remote control required for airconditioner
Not too many units only work with remote control...try using Bing or Google to find your problem and solution to the answers that you seek.
May 18, 2013 | Heating & Cooling
I have an celestial air con unit model KFR-70GW/K it is blowing air refresh out but will not turn on to air con with the remote... help
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
Jan 22, 2011 | Heating & Cooling
We have a spit system air conditioner.Celestial KFR-70GW/K it is leaking water/condensation internally behind the fan.I think it it from therear grill and for some reason it does not go into the drain...
Helpful?
Jan 01, 2011 | Heating & Cooling
How does the Timer and Sleep functions work for the SUMO KFR-70GW Heat Pump
Hi!!
Aug 10, 2010 | Heating & Cooling
I dont have my celestial KFR-28GW\A remote control
Hi, the best way to tell without the manual, would to be to pick up a anolog thermometer, and insert it into the face of the a/c. This will tell you which setting will give you cooler air temperature. They are very inexpensive, and you can get them at most any hardware store or appliance parts store. This will be useful in your auto a/c, refrigerator and so forth. Best of Luck, and Happy Holidays,
Shastalaker7
Dec 17, 2009 | Heating & Cooling
Jul 17, 2009 | Frigidaire FAA065M7A Air Conditioner
Jan 05, 2009 | Heating & Cooling
Heating & Cooling Logo
160 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
