My Panasonic LCD projector has a blinking LAMP light, how do I fix it? Model # PT-AE700U, hasn't ever had an issue before..
  • 934 Answers
Replace the lamp and rest the hours. This procedure is covered in your owner's manual on page 52... If you don't have the manual click here: http://www.projectorcentral.com/pdf/projector_manual_2606.pdf
Posted on Dec 04, 2008
Projector will not switch between eco and normal modes
Hi imustafa
Sounds like the lamp may be on its way out... at least is low on output.
May 05, 2008 | Panasonic PT-AE700U Multimedia Projector
Yamaha LPX-510 projector: There's a large blue circle around the entire image. Bad bulb, lcd panel, needs cleaning...?? Help!
Chances are the lamp was reinstalled and didn't get put in the right position. There could also be a problem with the concentrator/heat shield lens or light pipe (if it has one). Sounds like either someone replaced the lamp and didn't get it back together or the unit has been dropped.
Nov 12, 2013 | Panasonic PT-AE700U Multimedia Projector
Is this blue tinge on the left side of the screen a lamp problem or the projector itself. the lamp for this Panasonic PT-AE700E was replaced only about a dozen hours ago. what is an optical block, and does...
Your problem is the optical block failing. This is very common with the AE700s. It actually happened to me once before and I had it fixed. After having it replaced, it was recommended I run my fan on high mode, run the lamp on low mode and change the back lit color to black from blue to help thwart the issue. The optical block fails due to heat stress from the projector. Doing the things above lower the heat and extend the life of the block. I have a perfeclty good optical block if you would be interested as buying them new are extrememly expensive.
May 10, 2010 | Panasonic PT-AE700E Projector Lamp
PT-AE700E projector appears to have gone kaput - not lighting up.
Because of high voltages and heat, there are many safety circuits inside these units. If you have a spare lamp, try replacing the lamp. Initial checks are made before the lamp is fired and sometimes a defective lamp can cause this. Also, can you descruibe what you mean by "noisier than usual"? Is the fan making more noise? Something elase making a noise?
Thanks,
Dan
Oct 15, 2009 | Panasonic PT-AE700U Multimedia Projector
Permanent blue hue down one side of screen PT ae700 panasonic replaced lamp made no differance tried compressed air no change please help
if the discoloration has a sharp pixelated edge, it may be the lcd panel. if the edge blends, it's the light filter (polarizer) that is burnt from excessive heat and dust. either one needs replacing.
Sep 09, 2009 | Panasonic PT-AE700U-EC HD Cinema Front...
PT-AE700U Lamp led flashes red
Reset the lamp hours. Here is the manual on how to reset lamp time.
Good Luck and Please Rate Fixya!
Feb 28, 2009 | Panasonic PT-AE700U Multimedia Projector
I have a Panasonic LCD projector ( PT-AE700U) - I have had it for 4 years. Recently, I noticed it was projecting "blue" pixels on the bottom right hand side (small size maybe 3 x 8 inches) . Over the past...
your color calibration may be off. see if you can set the red green and blue settings all to "0" and see if that works. may want to refer to your manual and see how you can do that and also see if there is a auto calibration
Jan 23, 2009 | Panasonic PT-AE700U Multimedia Projector
PT-AE700U No Power
Hi ErnieN008
If there is no LED's flashing or even lighting up for that matter , then it could just be the fuse on the Poersupplyboard that has gone.
You can replace this fuse by opening up the top cover and looking for the board with the AC inlet on it.
If the problem however still exists , you will have to replace the powersupply.
May 04, 2008 | Panasonic PT-AE700U Multimedia Projector
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
