Paper jam in my Canon PXMA MP530 Printer. Cannot see the Labels 3.5" x 4.5" UPS Priority Labels
Dipu007
  • 2110 Answers
SOURCE: paper jammed @the output/slot or
move the printer head with ur hand, slowly and tried ur best to look into the printer and if there appears to be a piece of paper stuck then remove it...
Posted on Dec 04, 2008
When i on the printer display show paper jam
Hi
First switch off your printer now open the door of printer and remove the paper that jam. checked any small paper pieces is there also removed...................now close the door and switch on the printer..
May 18, 2011 | Computers & Internet
When the printer starts to print, one line gets printed- then the paper sticks. The printer says "Clear the Carrier Stall". what does that mean?
Paper Jam...try to clean your printer, get a can of dust off (compressed air) and blow it out. Then take a damp (unplug printer first) and clean the paper rollers. Keep an eye out for anything sticking to the rollers, ink mist build up, or sticker from labels, or just glue from stickers.
Hope this helps you, please leave a rating.
May 05, 2009 | Computers & Internet
Canon printer iR2016 error E192
HI, The problem could be casused if there was paper jam as the error is related to a non-detection of the Fixing Film/Upper Roller not spinning correctly. Please check the condtion of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error. Good luck Thanks for using fixya proton
Apr 28, 2009 | Computers & Internet
I got Photosmart Pro B8350, that just sits there with red paper jammed light on. I tried several times and it doesn't want move. Things that I tried: 1) Turning on and off 2) Removing the paper from...
so have you successfully been able to remove the acctual jammed paper?
if so try leaving it off for 1/2hr or so. have a read in the manual if there is a reset funcion on this printer
Dec 19, 2008 | HP Computers & Internet
Paper jammed @the output/slot or the auto sheet feeder of my Canon PXMA MP530 Printer. I had put UPS Priority Label 2x 3.5" x 4>5" into the auto sheet feeder. I cannot see either label. And...
Dec 04, 2008 | Computers & Internet
My printer shows error 6000 on the lcd screen. How do I fix it? at the moment I cannot use my pinter scanner fax.
If this is a Canon printer, then this indicates a paper jam. Ensure the paper path is clear and no debris is present and that no sheets of paper have gotten in a bind in the printer. If the paper path is clear, you'll need to contact canon for service/repair of the printer.
Oct 22, 2008 | Computers & Internet
Please give me the name of a printer that WORKS with writing checks in Quicken using Windows Vista 64. My HP all in one does not - printer jams every time.
HP will work. The jam is a paper problem not a hardware or software issue. Try line feeds without printing. HP also makes the best printer paper so don't skimp on that. Moisture in the paper is the most common paper jam problem aside from debris getting into the rollers. If line feed fails then physically inspect the whole paper path. I have Canon, Epson, Dell, HP and Lexmark printers with Quickbooks Pro. They all work. Paper is your problem barring a banana falling into the rollers. Never leave paper in a printer for a long time as it will stick to itself. Steve
Oct 21, 2008 | Computers & Internet
I want to print labels i bought your paper cut 1/3 for 600 labels cannot do it i need help. i have a microsoft office 2007
hi buddy!
check if the printer is really install ok and also check the wire connected to the computer ok
coz i have also using a 2007 microsoft. if you need more help just reply ok im willing to help you.thnx
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Sep 21, 2008 | Computers & Internet
HL-2140 printer: error light on: But, paper is in the tray. I have removed the tray several times and returned it. I have turned the printer on and off. THis problem occurred right after printing on the...
pls. try to download the latest driver from your printers website and upgrade your driver. updated driver will fix the problem.
PS, pls vote. tnx
Sep 15, 2008 | Computers & Internet
Pixma530 printer where inside is thhe serial number?
Go to http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
and type in serial number. The first result shows you exact instructions for finding the number. This assumes that your model is a Pixma MP530 - the only 530 in the Pixma line that I could find. The content of that page appears below (illustrations will likely not appear properly):
Locate the Serial Number The serial number of the PIXMA MP530 is located inside the printer, as shown below.
  1. Lift the Scanning Unit (Printer Cover) until it locks into place.
  2. When the printer is powered on and the Scanning Unit is lifted, the Paper Output Tray will open automatically. If the Paper Output Tray does not open after several seconds, press the Open button to open the tray manually.
  3. Open the Inner Cover.
    The serial number is attached to the back wall inside the printer.
    It starts with four letters (AAGA) and ends with five numbers. Example: AAGA01234
Please post back if you need additional assistance, otherwise thank you for using and rating FixYa!
Jun 02, 2008 | Computers & Internet
Computers & Internet Logo
15 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
