Paper jammed @the output/slot or the auto sheet feeder of my Canon PXMA MP530 Printer. I had put UPS Priority Label 2x 3.5" x 4>5" into the auto sheet feeder. I cannot see either label. And thus cannot get them (2 Labels) out. Please help.
    President:
  • 2,110 Answers
Move the printer head with ur hand, slowly and tried ur best to look into the printer and if there appears to be a piece of paper stuck then remove it...
Posted on Dec 04, 2008
Canon MP198 error E3
Issue: ERROR LED: E, 3 Solution: Remove paper jam then press Black or Color button (MP150) If paper is jammed, remove the paper jam then press <Black> or <Color> to clear the error.If paper is jammed in the auto sheet feeder or paper output slot, paper will not feed through the printer. Please follow the instructions for Clearing paper jams from the auto sheet feeder (ASF) or paper output slot.If Credit Card sized or 4" x 6" paper is set in landscape orientation, it will jam. Please follow the instructions below for Clearing credit card-sized or 4" x 6" paper jammed inside the printer.Clearing credit card-sized or 4" x 6" paper jammed inside the printer:Power the printer off.Load the same paper type as the jammed paper in the portrait orientation. Power the printer on. (The printer feeds the paper, resulting in ejecting the jammed paper.) Load paper properly in the portrait orientation to resume printing.TOP Clearing paper jams from the auto sheet feeder (ASF) or paper output slot:Power the printer off.Pull out the paper gently.If torn paper remains within the printer, open the scanning unit (printer cover) to remove it.Caution: To prevent injury or damage to the unit avoid touching inner parts.Power the printer on and confirm that the Alarm lamp is off.Note: Any jammed paper that remains within the printer may be ejected automatically.Load paper properly to resume printing. Issue: ERROR LED: E, 3 Solution: 2 Press ON/OFF switch to reset the multifunction device Reset the device when it is not functioning properly.If the device is not functioning properly or to clear memory, reset it.Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. Click here for instructions to attempt a service reset.On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Wait approximately ten seconds and then press the <ON/OFF> button again.Wait until the device has completed its cycling process before submitting another job request.Service Reset:On the operator panel, press and hold the <ON/OFF> button for one second to power off the printer. (The display will go blank.)Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.Confirm the printer is not on and then unplug the power cord from the back of the printer.If the power cord was disconnected (as stated in step 1) in order to shut off the printer, go to step 3.Press the <ON/OFF> button repeatedly five times.Re-connect the power cord.Press the <ON/OFF> button to power the printer back on.Wait until the device has completed its cycling process before submitting another job request.Important:This procedure will not resolve a physical hardware issue.For example, a paper clip is wedged between the paper feed rollers or gears; or, the scanner assembly is detached from the inside housing. This procedure will not resolve all service errors or LCD related anomalies.Service errors appear as four characters (a combination of alpha and numeric codes).
Oct 13, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Canon ip1800 is experiencing paper jam.whener tries to print, cannot feed the paper properly
Sometimes a printer just needs some cleaning.
Remove the jammed paper following the procedure below. (1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Paper Output Slot, whichever is easier.If the paper tears and a piece remains inside the printer, turn the printer off, open the Front Cover, and remove it. Be careful not to touch the components inside the printer. After removing all paper, close the Front Cover and turn it back on.If you cannot pull the paper out, turn the printer off and turn it back on. The paper will be ejected automatically. (2) Reload the paper in the printer, and press the RESUME/CANCEL button on the printer. If you turned off the printer in step 1, all print jobs in queue are canceled. Reprint if necessary.
Make sure to clean the paper feed rollers if paper is not fed properly. Cleaning the Paper Feed Roller of the Auto Sheet Feeder consumes it, so perform this only when necessary. 1. Make sure that the printer is turned on, and then remove any paper from the Auto Sheet Feeder. 2. Open the Printer Properties dialog box. 3. Click the Maintenance tab and then Roller Cleaning. 4. Confirm the message, and then click OK.The Paper Feed Rollers will rotate as they clean. 5. When the message appears, load three or more sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder.Set the Paper Thickness Lever to the left. 6. Confirm the displayed message and click OK.The paper that is loaded in the printer will feed through the printer and be ejected. 7. When the confirmation message is displayed, click OK. If this procedure does not solve the problem, clean the surface of the roller with applying a slightly moisten cotton swab with water to wipe off dust or stain.
If the problem still persists, contact a Canon service representative.
Mar 28, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Paper jammed under roller small piece of paper keep saying jam e3
Good day, I will give you the procedure how to clean the roller or canon pixma mp160.
Procedure:
1. Press [On/Off] to turn on the machine, then remove any paper from the auto sheet feeder.
2. press [maintenance] repeatedly until <b> appears.
3. press [black] or [color].
4. repeat steps 2 to 3 twice.
5. open the paper output tray.
6. load 3 or more A4 or letter-sized paper in the auto sheet feeder.
7. repeat steps 2 to 3 times.
the sheet paper is automatically fed in and then out of the machine.
have a nice day.
Aug 01, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper jammed
Paper Jams
Cause 1 : Paper jams in the paper output slot/Auto Sheet Feeder.
a) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will be ejected automatically.
b) Reload the paper into the machine and press [OK].
* If you have turned OFF the machine in step a), you will need to retry printing, because this operation cancels any print jobs in progress.
Cause 2 : Landscape Credit Card-size Paper Jams inside the Machine.
Action : You cannot load Credit Card-size paper in the landscape orientation.
If <PAPER JAMMED> or <E3> is displayed on the LCD/LED, remove the paper following the procedure below:
a) Load Credit Card-sized paper in the Auto Sheet Feeder one sheet at a time.
Do not load it in the landscape orientation.
b) Press [ON/OFF] on the machine to turn OFF the power.
c) Press [ON/OFF] again on the machine to turn ON the power.
The paper is fed and the jammed paper is ejected accordingly.
If you cannot remove the jammed paper or the error still persists, contact a Canon service representative.
Hope this helps
Please rate my response.
Thanks
Have a good day.
Dec 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
The paper is jammed..
Cause and solutions for paper jams
Cause 1 : Paper jammed in the Paper Output Slot, the Auto Sheet Feeder, or the Front Feeder.
Soultion : Remove the paper following the procedure below:
1) Slowly pull the paper out, either from the paper source or from the Paper Output Slot, whichever is easier.
* IF the paper tears and a piece remains insde the machine, open the scanning Unit (Printer Cover) and remove it.
After removing all paper, close the Scanning Unit (Printer Cover), turn the machine off and turn it on again.
-Be creful not to touch the components inside the machine.
*If you cannot pull out the paper, turn the machine off and turn it back on. The paper will be ejected automatically.
2)Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step 1 all the print jobs in queue are cancellled. Reprint if necessary.
if you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after moving the paper, contact your Canon service representative.
Cause 2 : Landscape credit card-size paper jammed inside the machine.
Action : Do not load credit card-sized paper in the landscape orientation.
Slowly pull out the paper from the Auto Sheet Feeder and remove it. If you cannot remove the jammed paper or the paper jam error continus after removing the paper contact your Canon service representative.
Cause 3 : Paper jammed inside the machine at the transport unit.
Action : Remove the paper following the procedure below :
!) Hold the Rear Cover Lever and then press to the right and put to remove the Rear Cover.
2) If you can see the jammed paper, slowly pull the paper out.
* Be careful not to touch the components inside the machine.
* If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
3) Reattach the Rear Cover.
Hold the Rear Cover so that the Rear Cover Lever comes to the left. Align the protrusions at the right edge of the cover with the slots at the rear of the machine and press on the lever ot reattach the Rear Cover.
Important : Press firmly on the Rear Cover until it is fit squarely in the rear of the machine. If the Rear Cover is not reattached properly, paper may not feed properly and cause paper jams.
4) If you were not able to remove the paper out in step 2, remove it from the Front Feeder. Refer to cause 1.
5) Relaod the paper in the Front Feeder and press the OK button on the machine.
If you turn off the machine in step 2, all print jobs in queue are cancelled. Reprint if necessary.
Hope this helps.
Thanks
Have a good day.
Nov 30, 2009 | Canon PIXMA iP1300 Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Not feeding
Have you still getting the problem, have you done cleaning of Cartridge, its nozzle and Contact strip.. then cleaning of Printer roller or carriage rack.. Do a Service of it or get it done by Technician.
Also check the feeder tray.. to grab paper one by one by printer.. Manually
Take all updates for printer and OS.
Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Paper jam
Remove the paper following the procedure below.
(1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
(2) Turn off the machine.
(3) Turn on the machine.
The paper is fed and then pushes out the jammed paper as it ejects.
If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
James Mac
Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
