Question about Microsoft HP Pavilion DV6276US Notebook PC
Hp laptop will not boot fan starts then stops
Hp pavilion enterainment laptop will not boot fan starts then stops
  • 3 more comments
  • cabral_34 Jan 12, 2009
    hi there
    yes that happening to my computer all the lights turn on but it wont boots
  • Anonymous Apr 01, 2009
    Wont power up. Lights turn on for a few seconds and then it powers down. Screen never comes on.
  • jwill239 May 11, 2009
    Pavillion ze2045 - stopped suddenly, now fan spins for a few seconds and then stops. No screen/BIOS visible. I found plenty of dust blocking CPU heatsink, cleaned it and replaced thermal paste. Have even tried a second CPU with the same result. Any ideas?
  • Anonymous May 24, 2009
    WHile trying to install AVG 8.5 it asked to reboot the computer. Now it just starts to boot and then shuts off and then starts again and shuts off. I think it will do this until the battery dies so I shut it down by taking the battery out and unplugging it.
  • ayman farag
    ayman farag May 11, 2010
    hiiiiiiii ther
    how r u ??
    doe teh windos log ?? dose teh screen light up ??
    tell me more about teh problem so i can help u
    if u need any further assistance email me
    aymanlovemai@yahoo.com
    u take care and have fun
    salammmmmm {bye in arabic }
    p.s rate me thanks
COOLING FANS HAS STOPPED WORKING in my laptop. HP Pavillion DV2700 dv 2915nr
If your computer still works, turns on and boots the OS. Then it's most likely just the fan it's self that is bad.
Aug 05, 2011 | HP Pavilion dv4000 Notebook
My cooling fan has stopped working - laptop is a hp pavilion, model tx2000
If you unplug the fan, you can test the connector to make sure the fan is bad and the problem isn't with the power getting to the fan.
You can get a new fan and heat sink assembly here (make sure the model number is the same as your computer):
http://www.sparepartswarehouse.com/HP,Pavilion,tx2000,KX531AV,Laptop,Fans.aspx
But in the meantime, you shouldn't run the computer much because it can easily overheat without the fan.
Jun 06, 2010 | HP Pavilion TX2000Z Notebook
Hp pavilion dv2000 lights switch on but boot or
Hi
Thank you for your query
Please try the folowing
1) Remove ALL wires and then press and hold the power button in for approx 20 seconds
2) Plug everything back in and then rerty
This may sort the issue out however from what you are descrbing, if there is no boot or display it is highly likely the motherboard and/or the CPU is faulty
I would recommend that you book the PC into a reputable PC repair shop if the above does not work
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
Fan shuts off on computer startup, led lights are
The fans are USUALLY controlled by the processor chip reading its internal temp and running fans as needed. Under the varying load during boot, it is not uncommon to have fans starting and stopping..
Nov 30, 2009 | HP Pavilion dv6000z Notebook
Does not appear to be working how do you turn on
Re-install the original driver from
www.hp.com
support,the device drivers
Oct 12, 2009 | HP Pavilion dv6000z Notebook
Display and Boot problem with HP Pavilion DV2125NR
It is normal for the bottom to get hot. The fan should keep it cool enough to run, but it sounds like perhaps your fan is not working very well anymore and should be replaced.
Does the computer act up at all when cool? If not, the first thing I would try is replacing the fan and examining the fan and heatsink assembly for proper installation, perhaps replace the heatsink compound with some Arctic Silver while you have it open.
Jul 10, 2009 | HP Pavilion dv2000t Notebook
On my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Apr 04, 2009 | HP Pavilion dv9000z Notebook
Fan problem with laptop...NOT overheating problem..and it's clean
my fan is just running faster than normal and my laptop get hotter even
Feb 14, 2009 | HP Pavilion dv8000t Notebook
Microsoft HP Pavilion DV6276US Notebook PC Logo
4,777 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
